European Hardwood Grading Standard - Router Forums
post #1 of 2 (permalink) Old 03-24-2011, 10:40 AM Thread Starter
Engine44's Avatar
Country: Netherlands
First Name: Bob
Default European Hardwood Grading Standard
I will be building blanket chests in The Netherlands using solid hardwoods. I would like to make sure I order the proper wood grade for this furniture. So far my research has led me to believe that the proper grade would be A1 but I am not sure.
The wood I will use will be about 18 mm and 24 mm in thickness. What are the industry standard thicknesses in that range before and after planing?
May The Lord Give You Peace
Engine44 is offline
post #2 of 2 (permalink) Old 03-25-2011, 09:20 AM
woodjoiner's Avatar
First Name: Leon
Hello Bob
I don't know if this helps or perhaps you've already seen it but I found this link.
http://www.forestry.gov.uk/pdf/MTG-WEB.pdf/$FILE/MTG-WEB.pdf
Just copy and paste it in your browser.
I hope it helps.
woodjoiner is offline
Hardwood flooring for router table top sofasurfer Table-mounted Routing 5 01-13-2010 01:51 PM
Guide Bushings rberry Portable Routing 40 02-20-2009 11:21 PM
5 Tips When Choosing Hardwood Flooring John_smith Project Plans and How To 0 10-17-2008 06:19 AM
Trimming mitered hardwood edging Drew Eckhardt General Routing 5 10-11-2008 07:59 PM
Gathering hardwood to work with... popeyebedford Lobby 1 07-16-2007 09:19 AM
