Tasmanian blackwood tree - Router Forums
post #1 of 8 (permalink) Old 05-02-2011, 11:52 PM Thread Starter
Country: New Zealand
First Name: ROGER
Smile Tasmanian blackwood tree
Hi - My name is Roger and I am new to this site so not sure what actually goes on, however, I have a question ( and I feel sure someone out there knows the answers) recently I felled a Tasmanian Blackwood tree - it was a fine specimen and I would like to make the most out of it. I have cut the trunk into logs approx. 60cm/70cm long and average 1.50mtr. round I would like to make some furniture such as stools & small cupboards plus bowls/boxes/vases etc - which is the best way to cut these logs up? I would appreciate any helpful advice please. Many thanks Roger
ROGER1734 is offline
post #2 of 8 (permalink) Old 05-03-2011, 01:40 AM
gav
Country: Croatia
First Name: Gavin
Look in your yellow pages and see if someone has a portable mill service. They are becoming relatively common these days. A bandsaw mill will yield more timber, but a chainsaw mill will do.
gav is offline
post #3 of 8 (permalink) Old 05-03-2011, 10:21 AM
Roger, you will find videos on the home milling process posted on web sites like Wood magazine or Popular Woodworking. Paint the ends of your logs to seal them and help prevent splitting as the wood dries.
post #4 of 8 (permalink) Old 05-03-2011, 10:21 PM
Also, Roger, remember that timber only dries out at 1" thickness per year?
You will need to cut the timber into planks, seal the ends with paint and let them dry for a few years before they will be really useful
Sydney, Australia
jw2170 is offline
post #5 of 8 (permalink) Old 05-29-2011, 05:34 PM
Is Tasmanian blackwood the same as Australian blackwood? I have the impression it is a bit darker?
Name:	Oz blackwood.jpg
post #6 of 8 (permalink) Old 05-31-2011, 11:32 AM
RJM60's Avatar
First Name: Robert
Milling lumber is not as easy, or simple, as you might think. If you're only going to do it once in a while, the most economical and simplest way is to hire someone with a portable mill. These people may not be prevalent where you live and in many large cities, they're pretty much non-existant (supply demand thing I guess). You'd probably have better luck finding someone to do tis in more rural areas.
So if you still want to mill your own lumber, here's a few things to consider.
1. If you're only going to do this occasionally, or if you're just starting out, a chainsaw mill is the way to go. Chainsaw mills waste a lot of wood (about 3/8" or 9 mm kerf) but band saw mills are expensive to build (and more expensive to buy), take a big time investment, are very large (compared to a chainsaw mill), and must be stored (you need a parking space sized spot).
2. To get decent boards, you need something to attach to your chainsaw. You can make something yourself in a weekend but you'll need access to at least a drill press. Some designs require welding equipment. Alternately, you could buy an attachment like this one:
Lumber Mill Attachment
... but you'll also need a straight guide board, a way to support the guide board, and a way to hold the log your cutting. Also, an attachment like this does not clamp the chainsaw bar very well (i.e. it comes lose in 10-15 minutes) and if you're not very careful, you will immediately dull your chain when it hits the metal clamp.
3. The first couple of cuts with this type of an attachment are relatively easy and you can get a couple flitches (i.e. bark still on edges) from the center by cutting the log in half, then taking a slab off each half (kind of like quarter sawn) but as the log becomes smaller, it becomes more and more difficult to support the piece that's left.
4. Usually, the attachment above is used to cut square sides after a flat top surface is cut (look at the video here: Three sided cant.
5. Flat sawing flitches is realatively easy with a "ladder" mill. This is the easiest, cheapest thing you can make yourself. You'll need to buy, or make an attachment. These webpages explain it well: "Ladder Chainsaw Mill". The homemade attachment, shown on these web pages, bolts to the chainsaw thru holes that were drilled in the bar (don't drill thru the tip like he did - you'll ruin the bar sprocket). You can buy (or make) an attachment that clamps to the bar too. Granberg makes the best ones I've seen: Granberg Small Log Alaskan Mill. The Granberg website has an online store but I've found their products cheaper on other websites (e.g. Bailey's). Shipping to New Zealand might be an issue.
6. For milling quarter sawn lumber yourself, the best info I've found on the web is here (it features a modified "Granberg Mini Mill"): Quartersawn Lumber With a Chainsaw. I've just finished making an attachment like this using bed frame angle, which I don't recommend since it's really tough stuff to drill (use plain steel instead). I still have to build some stands (mine will be made of dimensional lumber).
7. You can always just hack up the logs by eye but you'll waste a lot of wood and then you'll have to flatten and square the resulting flitches, which will be flat sawn (by definition). There are ways to use a router to flatten boards, so this might be the way to go but you'll have to cut the boards thick enough to account for what you'll lose when you flatten them. This will add to the drying time which was already posted (i.e. 1 year per inch). Also, once the logs are small enought, you can finish up with your bandsaw.
Have fun!
ďThe single biggest problem in communication is the illusion that it has taken place.Ē
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #7 of 8 (permalink) Old 06-06-2011, 02:46 PM Thread Starter
First Name: ROGER
Hi Robert
So many thanks for all your most helpful advice I will be putting some of your ideas into practice soon and will let you know how I got on - once again many thanks - Roger
PS. Many thanks to everyone else for their comments also - much appreciated
post #8 of 8 (permalink) Old 06-13-2011, 11:42 PM Thread Starter
First Name: ROGER
Smile
Originally Posted by ROGER1734 View Post
Hi Robert
Hi Robert
Just to let you know I have ordered an Alaskan chainsaw mill from Bailey's and once it arrives with me I will let you know how I got on . kind regards Roger Kiwi Land
Wood Tree Swings wood tree swing New Member Introductions 3 07-04-2010 10:01 PM
Drum sander Xmas tree ornament plans? Nickbee Project Plans and How To 0 12-13-2009 11:29 AM
Hello.... Pecan tree question Gunner65 Tools and Woodworking 3 11-16-2009 09:46 AM
If you were growing trees, what kind would you grow? Jeremiah Lobby 37 03-08-2009 01:54 PM
Pecan tree to lumber Drugstore Cowboy Lobby 4 06-27-2007 10:18 PM
