Cherry Laurel - is it useless? - Router Forums
post #1 of 6 (permalink) Old 08-15-2011, 01:48 AM Thread Starter
First Name: Kristian
Default Cherry Laurel - is it useless?
While it's supposed to be a shrub, Cherry Laurel (link omitted as I don't have ten posts) grows here in the Pacific Northwest like a weed. Over last winter, I've pulled a lot of it out of our back yard to the point where I have well over half a cord of it piled up.
In all my searching, I've found that it splits really badly so that making planks or turning bowls ends in heartache. I've tried sawing it a bit after leaving it over the winter, and it gummed up any blade used pretty badly. Apparently it pops a lot when burned (I haven't tested this as we don't have a fire pit). The only use I can think of is to make some 'rustic' furniture like willow furniture for the yard. Too bad I thought of this after I cut up most of the 1-2" diameter bits into the yard waste bin!
Has anyone tried to do anything with cherry laurel? Should I cut it up and have it hauled off, or is there some sort of redemption to be had with it?
eryops is offline
post #2 of 6 (permalink) Old 08-15-2011, 02:27 PM
First Name: del
i did a google search go here and pick and read
Google
del schisler
port st. lucie, florida
del schisler is offline
post #3 of 6 (permalink) Old 08-15-2011, 04:11 PM
dutchman 46's Avatar
First Name: Howard
Thishttp://thebarktree.typepad.com/the_bark_tree/page/2/Might give You a bit of informatoin! It is in the same folder, and may be another name
John 3:16
dutchman 46 is offline
post #4 of 6 (permalink) Old 08-16-2011, 01:48 AM Thread Starter
Thanks Del & Howard,
I guess my initial post wasn't as clear as I'd hoped. I've removed a lot of cherry laurel from my yard, with some of the stems (trunks) being 6-8" in diameter. The stems are in a big pile in my yard, and I'm wondering if anyone in the community has tried to use this wood (or wood from something similar) for anything. All avenues I've checked have turned up dead, as the wood isn't good for woodworking or even burning, but thought I'd double check.
eryops is offline
post #5 of 6 (permalink) Old 08-16-2011, 04:53 PM
I've tried a couple of shrub species with mixed success. One is Douglas Maple which may be in your area. It will not make a board, or at least, it will not make a flat board. It will make nice turnings on a lathe. It has nice colors and nice grain. Maybe cherry laurel will too. I've also considered trying to make some inlay strips out it.
Two others I've tried, which may also be in your area are hawthorne and juniper, Both of those will make lumber.
post #6 of 6 (permalink) Old 08-17-2011, 05:40 AM
First Name: Howard
Give it a try, and report back. If they come back. Try the oldest piece first then We all will get an idea of what it is like! Thanks
John 3:16
Cherry Chest Engine44 Tools and Woodworking 6 03-23-2011 05:44 PM
Need help on Cherry stain Jimmy Ross Tools and Woodworking 8 11-23-2010 07:02 PM
Stain Maple to look like Cherry? NGR Maybe? AUFAITHFUL The Finishing Touch 12 12-20-2009 12:48 AM
Cherry 8 Sided Bowl mit-ch Woodturning and Lathes 10 11-12-2007 12:26 AM
What color of stain for cherry Jimmy Ross Lobby 0 03-28-2005 03:18 PM
