Uses for Brazlian Apitong? - Router Forums
post #1 of 10 (permalink) Old 06-16-2012, 11:22 PM Thread Starter
MAFoElffen's Avatar
Default Uses for Brazlian Apitong?
I have some left-overs from a Heavy Equipment trailer deck I put on... I remember I had to use carbide blades and pre-drill any holes in it for screws. I also remember that the first winter, I had to rough-up the ramps with a chainsaw because tracked dozers and excavators couldn't get enough grab to get onto the trailer.
I still have some left-overs. I love the smell it has when you cut it, sort I like how I like cut mahogany. Was thinking it would be nice pieces for some homemade shop equipment. I know it holds up real well under my anvil.
It it does look real nice when sanded... I know it's dense enough that it doesn't take stain.
Has anyone here ever made anything with it? (other than buildings, bridges and trailer decks)
MAFoElffen is offline
post #2 of 10 (permalink) Old 08-13-2012, 08:46 AM
neiltsubota's Avatar
First Name: Neil
Could you post a photo of this wood ?
neiltsubota is offline
post #3 of 10 (permalink) Old 08-13-2012, 09:37 AM
OPG3's Avatar
First Name: Otis
Hey Bozo, it would make a great workbench and should be fine even in harsh winter conditions outdoors! Mike, I know you do a ton of outdoor work and you have many areas to place it. Have fun, Tater Head (a.k.a. Otis)
OPG3
Tweak everything!
OPG3 is offline
post #4 of 10 (permalink) Old 08-13-2012, 12:44 PM
First Name: Scott
Mike; I have used Apitong lumber in many truck beds and have used a lot of cutoffs. The stuff is 1 and 1/8 inch thick shiplaped. I most reciently needed to make some box dividers 3 inches wide. I ripped it to 1/2 inch and thickness planed it to 1/4 inch and it worked excellent. As you know when screwing it in to steel it needs to be drilled and don't go too close to the edge because it will split. have thought about glueing a bunch up for turning. If someone tryes it let me know how it turned out.
Smokindog is offline
post #5 of 10 (permalink) Old 02-20-2013, 10:24 PM
jeffjacob's Avatar
First Name: Jeff
Yeah it smells really very good.
jeffjacob is offline
post #6 of 10 (permalink) Old 02-20-2013, 11:22 PM
BRAVOGOLFTANGO's Avatar
First Name: Bravo
Mike that good for nothing with no-uses wood is only worth shipping (at my cost) to me.
Found this link too...pretty wood indeed, sounds brutally strong.
Apitong Hardwood Decks and Decking Lumber
BRAVOGOLFTANGO is offline
post #7 of 10 (permalink) Old 02-21-2013, 12:51 AM Thread Starter
MAFoElffen's Avatar
Fresh cut wood that smells good freshly cut- My favorites, apitong, mahogany and cedar...
Very expensive. Very dense and hard. When seasoned, have to drill pilot holes for screws. A 2x8 piece feels about 5 times heavier than the same sized piece of douglas fir. Hard enough that when used as decking for heavy equipment, an 80,000 pound excavator wasn't digging into the wood enough (at all) to get traction... so I had to go back and rough up the ramps (kringe!).
But beautiful grain and look to it!!!! Think it would make great tool handles.
post #8 of 10 (permalink) Old 06-16-2013, 10:44 PM
First Name: Scott
I work at a very large sawmill. We use apitong as stickers for air drying lumber. It is very strong and leaves no sticker shadow.
ScottM80 is offline
post #9 of 10 (permalink) Old 06-17-2013, 12:47 AM
I can't believe you would use wood like that to walk an excavator up. You can buy all the Douglas fir or hemlock you need from BC instead.
post #10 of 10 (permalink) Old 06-17-2013, 05:12 PM Thread Starter
MAFoElffen's Avatar
Not me = my boss... I wasn't there when he did it. Just the ramps. Golly- I think I remember that being around $4 a board foot. I think I would have been fired if it was just me doing that.
I did use a piece for a bush knife handle, a chisel handle, a cabinet cutting board ends (handles) and in my anvil stamp under my anvil. And it does look great stained and finished. Although it doesn't take satin very readily.
It does not do well as a hammer handle. It is "too" strong and stiff. As a hammer handle, there is no life to it. It just felt dead to me.
