What kind of wood is this? - Router Forums
post #1 of 9 (permalink) Old 07-16-2012, 10:54 AM Thread Starter
Country: Sweden
First Name: Fredrik
Question What kind of wood is this?
Hi!
I got this wood from my wood supplier who got it from their supplier and no one knows what it is. First I thought that it was pau ferro, but it seems to heavy. One of the pieces is 20mm x 100mm x 350mm and weighs 900g. That makes a specific gravity of 1,285 at the current moisture content, wich is around 10-12%.
The pieces in the pictures, including the mallet, are all natural, no finish is applied.
Does anyone have a clue what this could be?
abergguitars is offline
post #2 of 9 (permalink) Old 07-16-2012, 10:53 PM
MAFoElffen's Avatar
Goncalo Alves? (Also known as Tiger Wood or Jobillo.)
Same coloring and grain structure as Cocobolo and Pau Ferro...
But Pau Ferro is 55 lbs/ft3 (880 kg/m3). Cocobolo is 67 lbs/ft3 (1,070 kg/m3). Goncalo Alves is 62 lbs/ft3 (995 kg/m3) and matches the closest to your pictures.
MAFoElffen is offline
post #3 of 9 (permalink) Old 07-17-2012, 05:52 AM Thread Starter
Country: Sweden
First Name: Fredrik
Thanks for your reply!
Yes, it could definately be Goncalo Alves. Most features seem correct. It's just the weight that doesn't make sense. My boards ar too dense. A piece of this wood will sink like a rock in water. On the other hand, I read somewhere that the specific gravity of Goncalo Alves can differ greately.
post #4 of 9 (permalink) Old 07-17-2012, 06:40 AM
First Name: Keith
I would quess by your desription it is Tiger wood.
Woodshaper67 is offline
post #5 of 9 (permalink) Old 07-17-2012, 07:50 AM
skiroy56's Avatar
First Name: Laurence
Ipe??
skiroy56 is offline
post #6 of 9 (permalink) Old 07-17-2012, 10:49 AM
Lignum Vitae has a huge range of colour, and the specific gravity is spot on...
How to Tell Genuine Lignum Vitae from Argentine Lignum Vitae | The Wood Database
Have you eliminated it from the possibles?
DaninVan is offline
post #7 of 9 (permalink) Old 07-17-2012, 11:03 AM
First Name: craig
Tiger wood id say, take it to home depot or lowes and look at it next to a piece of their tiger wood flooring and see if it looks like it. without having a visiual to compare it too, its hard to tell, esp. by comparing weights and moisture content. does it seem to be treated with anything?
zack is offline
post #8 of 9 (permalink) Old 07-17-2012, 01:51 PM Thread Starter
Country: Sweden
First Name: Fredrik
Thank you for your thoughts guys!
I live in Sweden so I can't visit Home Depot or Lowes and I've never come across any of those species in Swedish flooring shops. I still think that Tiger Wood/Goncalo Alves is the most likely alternative as the appearance is extremely close. I also read somwhere that the weight of Goncalo Alves could range between 50-80 lbs/cu.ft, even though the guy who wrote it didn't really believe that it would get as heavy as that. His pieces usually stayed around 60 lb/cu.ft.
80 lb/cu.ft would actually match my meassurements.
post #9 of 9 (permalink) Old 07-24-2012, 02:06 AM
First Name: Marylin
These Species are new for new....and thank you Guys for the info you gave about Tiger Wood. Hope it will sure come handy when i need it the most.
Thanks a lot.
marlinjenson is offline
acrylic stabilized wood gav Wood Species 6 05-31-2012 12:45 PM
I like to work with wood. Gary Denton New Member Introductions 3 01-14-2012 08:05 PM
WoodLine Wood Gear Clock Tom in indy Guide Bushings and Templates 2 01-05-2012 12:13 PM
Best Places to buy wood? big wes New Member Introductions 12 01-26-2010 05:34 PM
I need help to choose type of wood dane5547 Wood Species 4 07-25-2009 08:04 PM
