yellowheart update - Router Forums
post #1 of 12 (permalink) Old 04-10-2013, 01:54 PM Thread Starter
timthetooolman's Avatar
First Name: Tim
Default yellowheart update
Now that i can load pictures here are a few of the wood.The picture with all the other wood was to give contrast to the color the bottom is birch plywood with red oak ply on one side a small piece of walnut on the other. The picture of the single dark piece of wood is the back side of the yellow piece anywhere that air got to this wood it turned to this brown color the only way to expose the yellow is to sand or cut. even the end grain turned brown. So Any Ideas? Is it Yellow Heart?
timthetooolman is offline
post #2 of 12 (permalink) Old 04-10-2013, 08:33 PM Thread Starter
First Name: Tim
Could it be brazilian mahogany?
post #3 of 12 (permalink) Old 04-11-2013, 06:36 AM
First Name: Dick
Hi Tim, I think you said this was a local wood someone had stored, so I'm pretty sure that it is Osage Orange, or here in the south Bodark (short for Bois d'arc), or in other places Hedge Apple. This has some great color photo examples so you can compare.
bodark wood photos - Google Search
Where there's a Willis there's a way!
Willway is offline
post #4 of 12 (permalink) Old 04-11-2013, 06:43 AM
Wildwood's Avatar
Country: South Africa
First Name: Rob
Tim, it looks a lot like Iroko, which does darken to a brown, but not at the fast rate you imply.
I have used this wood to make a lounger, and it did change from yellow to brown over time. Google "Iroko wood" and see what you think. Rob
Wildwood is offline
post #5 of 12 (permalink) Old 04-11-2013, 06:49 AM Thread Starter
First Name: Tim
What are the length of the boards from osage orange. The most common I see on the link are just short sticks there are a couple that are decent size, the sticks I have are atleast 8 foot long 10-12 inches wide and no knots. But looking at the grain in the pictures it does look alike.
post #6 of 12 (permalink) Old 04-11-2013, 07:00 AM Thread Starter
First Name: Tim
I believe that you are correct.
post #7 of 12 (permalink) Old 04-11-2013, 07:34 AM Thread Starter
First Name: Tim
Ok the one website I was reading said that if you take shavings from the wood and put them in water if it is Osage Orange it will turn the water yellow because of a water soluble dye in the wood. I did this and guess what color my water is....Yellow.. it was The Wood Database it also said that its South American counter part comes in longer lengths and less knots.I think it should be called osage yellow not orange. Thanks Willway
post #8 of 12 (permalink) Old 04-11-2013, 07:38 AM
First Name: Richard
Send a message via Skype™ to rwbaker
are you sure that some one did not soak a piece of popular in Transtint? Dip it in 100% Methanol and if the color bleeds, then you know.What are the dimensions and weight - the specific gravity will tell a lot.
Good Luck - Baker
rwbaker is offline
post #9 of 12 (permalink) Old 04-11-2013, 10:28 AM
Wildwood's Avatar
First Name: Rob
I yield - the piece shown here looks exactly like yours
Osage Orange | The Wood Database - Lumber Identification (Hardwoods)
Wildwood is offline
post #10 of 12 (permalink) Old 04-11-2013, 12:27 PM
First Name: Dick
Hi Tim, where I was brought up this wood was commonly used as fences for cattle, in the old days. I don't mean the wood but the trees themselves. When planted close together they would make a large hedge that would keep livestock in. If planted alone the trees can become quite large and make decent lumber. On the left side of that Google images page scroll way down and you will see a trailer load of rough cut lumber with the caption "Re: what to do with 30" dbh osage orange/bodark tree? ". DBH means 'diameter breast height' or the chest height diameter of the tree. You won't see the caption until you click on the image. Click on it, then click on 'go to webpage', I think the log was actually 40". Some of the fence post my father and I put in over 55 years ago are still there, now that's some tough wood!!!
Willway is offline
MLCS Horizontal Router Table Update bobj3 Table-mounted Routing 4 01-24-2012 09:41 AM
update Melvin Table-mounted Routing 2 11-07-2009 10:24 PM
Kreg K2000 Update bobj3 Jigs and Fixtures 3 09-13-2007 08:07 PM
Toggle Clamps (Update) Pop_pop1 Table-mounted Routing 1 08-29-2005 06:52 AM
Cisco 1841 Router & Windows Update Error Hel27n Lobby 8 03-05-2005 06:22 PM
