Old Balls? - Router Forums
post #1 of 12 (permalink) Old 12-11-2013, 08:33 AM Thread Starter
First Name: Al
Default Old Balls?
Hi to all,
I have been given a couple of lawn green bowls which I have always believed to be made from Lignum Vitae. They are wet damaged and scuffed so are no good as bowls any more.
My question is that I am not sure of the wood type beyond what I always thought.
Then a further question is if they are Lignum then what would it be useful for?
It seems a shame to just burn them so any info or ideas would be welcomed.
Thanks, Al
PS Hi to Mike, hope you get sorted with the problem.
bigalscorpio is offline
post #2 of 12 (permalink) Old 12-11-2013, 04:14 PM
You can find quite a few websites on identifying wood if you google just exactly that. Here's one The Wood Database | Hardwood and Softwood Lumber Identification
I held some lignum vitae about 40 years ago. It was the heaviest wood I've ever seen and I really wasn't sure what I was holding was wood. It was very dark and slightly oily feeling. What it would be like after years of being outside I don't know. The old timer who showed it to me said he used a hacksaw to cut it, he said it was too hard on his wood cutting tools. Even back then it was very precious and getting hard to come by. If it hasn't become pinky and has retained any oiliness it would be good for bandsaw guides. Once you have cut into it you may decide other uses.
post #3 of 12 (permalink) Old 12-12-2013, 09:11 AM
Wood Chip's Avatar
First Name: Gary
Lignum Vitae is one of the few woods you can make an anchor out of. No kidding!
Wood Chip is offline
post #4 of 12 (permalink) Old 12-12-2013, 11:08 AM Thread Starter
First Name: Al
Thanks Guys, anyone need a small round anchor?
What would be the best approach as to using the wood?
All I can think is to try and split the ball along the grain, if I can find the grain, it looks so close! And kills tools according to the link Chuck left me.
Or do I just use the metal bandsaw I have and hope for the best?
Seriously I'm baffled about cutting up a ball, its way stranger than when someone gives me a chunk of 6 x 6 or a log. I know where to start on those.
Al
post #5 of 12 (permalink) Old 12-12-2013, 11:20 AM
Not sure here if we are talking about bowls or balls!
Lignum Vitae was once in high demand for bearings in very large machines - like the shaft bearings on ocean going ships. My dad was on a destroyer in WWII that had lignum vitae bearings. I used to manage several very small hydroelectric plants that dated from about 1910 and they had lignum vitae bearings as well. It will not rot, holds oil well, and absorbs vibration much better than anything else. When we tried replacing the old wood bearings with their synthetic clones, the machines developed uncontrolled vibrations and we had to go back to wood. Super expensive even back in the 1980's.
It is reported to make great mallet heads and impact blocks for driving items into place and was once a staple in a mill wrights tool box. Not sure you can finish it as it is so dense nothing will likely penetrate the surface.
Have fun, a rare find.
senebraskaee is offline
post #6 of 12 (permalink) Old 12-12-2013, 10:33 PM
First Name: Jeff
I doubt that they would be lignum vitae if they are water damaged as the wood is naturally oily. If they were mine I would try to split them then make various mallets from them.
Regards Jeff
c3jrf is offline
post #7 of 12 (permalink) Old 12-14-2013, 04:58 PM
MAFoElffen's Avatar
Are these balls or bowls? Photos please?
>> "scuffs and water damage"
And why would that make them unusable? So bad that it can't be refinished?
MAFoElffen is offline
post #8 of 12 (permalink) Old 12-31-2013, 09:30 AM Thread Starter
First Name: Al
Pics of the Bowls! When I said water damage I was probably wrong, one of these looks as if its been run over by a big rig or something that has done some damage.
Sorry the pics are late but we've had the family here and its been hectic.
Al
post #9 of 12 (permalink) Old 12-31-2013, 11:58 AM
I see why youcalled them bowls now. They were lawn bowling balls. The grain appears to run with the striations in the missing chips. I am not sure that is lignum vitae as what I remember was much darker but there may be variations that I never saw because I only saw some once. It is also possible that it is ebony. I've seen pictures recently that resemble that a bit. Apparently only about one ebony tree in 10 is totally black in color and the loggers in the countries where it grows have been leaving the other 9 after cutting them down and finding that they don't make the grade so there is a movement to stop demanding all black ebony now. Of course I'm sure that there are some other possibilities.
There is still a split next to the missing chip that you could pop off and try splitting. If you break it across the grain it will break jagged. If with the grain it will split much more smoothly.
post #10 of 12 (permalink) Old 01-01-2014, 06:33 AM Thread Starter
First Name: Al
Hi Chuck,
I have split some off and the splits are as you describe. However the grain is strange on the biggest piece I got off. On the outside the grain is running say 8 to 2 on the clock face and inside seems to be running 4 to 10 or so. Almost like plywood but without the ususal joints and voids. Can grain run like that?
Al
Joke a Day bobj3 Lobby 4294 09-17-2020 12:58 AM
Would our academic members like to comment harrysin Lobby 2096 01-30-2015 01:54 PM
Room divider finished jigger Jiggers Gallery 17 09-26-2011 11:05 PM
Space Balls ccmnova Table-mounted Routing 7 10-30-2010 06:43 PM
Drilling balls??? Chipper Jigs and Fixtures 14 07-13-2006 06:44 AM
