carvers mallet - Router Forums
post #1 of 11 (permalink) Old 06-01-2014, 02:55 AM Thread Starter
carl.p's Avatar
Country: South Africa
First Name: carl
Default carvers mallet
Hi all some advice would be most welcome I would like to make a carvers mallet I am not sure of the best type of wood to use. regards carl
Classical music is food for the mind and soul.
carl.p is offline
post #2 of 11 (permalink) Old 06-01-2014, 03:41 AM
beech, rock maple, elm, hickory, purple heart, walnut.......
Stick486 is offline
post #3 of 11 (permalink) Old 06-01-2014, 04:43 AM
Iron woods will give you a heavier tougher mallet head..
Acacia estrophiolata, Southern ironwood
Androstachys johnsonii, Lebombo ironwood
Carpinus caroliniana, American hornbeam
Caesalpinia ferrea, Brazilian ironwood
Casuarina equisetifolia, Beach ironwood from Australia
Casuarinaceae (she-oaks) in general
Chionanthus foveolatus, Pock ironwood from South Africa
Choricarpia subargentea, Giant ironwood
Copaifera spp., Diesel Tree, Kerosene Tree, Kupa'y, Cabismo, or Copaúva
Diospyros blancoi, Mabolo, Velvet Apple, or Kamagong native to the Philippines
Erythrophleum chlorostachys, Cooktown ironwood from Australia.
Eusideroxylon zwageri, Borneo ironwood
Guaiacum officinale, Lignum vitae
Guaiacum sanctum, Holywood
Holodiscus discolor, Ocean Spray or Creambrush
Hopea odorata, White thingan, Ceylon or Malabar ironwood
Krugiodendron ferreum, Black Ironwood
Lophira alata, Red ironwood
Lyonothamnus floribundus, Lyon tree
Mesua ferrea, Rose chestnut or Ceylon ironwood or Nahar
Nestegis apetala, Coastal maire, Broad-leaved maire or Ironwood
Olea spp., Various olive trees
Olneya tesota, Desert ironwood
Ostrya knowltonii, Knowlton's hophornbeam
Ostrya virginiana, Hophornbeam
Parrotia persica, Persian ironwood
Pemphis acidula, Maldivian ironwood
Tabebuia serratifolia, Ipê, "Brazilian Walnut", Lapacho, Yellow poui
Vepris lanceolata, The White ironwood tree of South Africa
Xanthostemon verdugonianus, Philippine Ironwood or Mangkono, endemic to the Phili
a wooden boweling pin is some kind of serious mallet....
youtube is ate up with how to's...
BTW.. fishing has been outstanding the last several days...
Stick486 is offline
post #4 of 11 (permalink) Old 06-01-2014, 05:45 AM
Default Crown green bowls
I don't know if they do crown green bowling in SA but old fashioned bowling balls are often lignum vitae. If you can find a set in a charity shop/thrift shop you can turn a great mallet out of one.
Fraise is offline
post #5 of 11 (permalink) Old 06-01-2014, 05:54 AM Thread Starter
carl.p's Avatar
First Name: carl
Default carvers mallet.
thanks Stick been to busy making hives and frames for up coming spring bee season but will try some fishing end August. carl
carl.p is offline
post #6 of 11 (permalink) Old 06-01-2014, 08:05 AM
Are you getting some thaw come down?
Sydney, Australia
jw2170 is offline
post #7 of 11 (permalink) Old 06-01-2014, 08:10 AM
depends on what elevation yur at...
Stick486 is offline
post #8 of 11 (permalink) Old 06-01-2014, 09:10 AM
Wildwood's Avatar
First Name: Rob
Hi Carl - I have one made of Beech, but I think a heavier wood would be better. By the way, a carver's mallet is usually round with the handle in line, as in this pic.
Wildwood is offline
post #9 of 11 (permalink) Old 06-01-2014, 12:06 PM
JOAT's Avatar
First Name: Theo
Yep, that is quite true. The ones with square, or rectangular, heads are carpenter mallets. Personally, I much prefer the carving mallets, much easier and faster to make, and can use in place of carpenter mallet
Back when I still had my wood lathe I made a dozen or more carving mallets. Used whatever wood I had on hand - pine, dogwood, holly, hickory, I think some oak, and I don't know what all. Turned them various sizes, from a small, quite light weight from pine (great for more delicate cuts, with the light weight you can whack it, and not much cut at once), to a long, large, heavy, one made from dogwood - you can really get a large cut when you whack a chisel with that one. Then I discovered those were all I liked to make on a lathe, so later got rid of the lathe, and still use the same mallets. I'd recommend making a lot, various sizes, whatever wood you have on hand, or can get free.
Oh yes, there are actually plans out there for turning mallets, and they are totally not necessary. Just turn the handle portion until it feels comfortable, then the head. Tip - cut the large end flat, that way you can stand it on end, so it won't roll off your bench.
JOAT is online now
post #10 of 11 (permalink) Old 06-01-2014, 04:46 PM
First Name: MIKE
Burl makes a nice mallet head, turned or sawed.
mikelley is offline
Classic Mallet Project GulfcoastGuy Show N' Tell 21 11-27-2012 03:04 PM
Mallet Removing Paraffin Wax From It Gaia Pyrography and Carving 3 01-14-2011 04:39 PM
Lets go for a spin - Wood Mallet RMilgie Woodturning and Lathes 5 08-14-2009 08:55 PM
A companion for curiousgeorge's mallet harrysin Lobby 8 04-28-2009 07:39 AM
The Mullet got a new Mallet curiousgeorge Show N' Tell 12 04-20-2009 08:48 PM
