Substitute for Pecan - Router Forums
post #1 of 4 (permalink) Old 03-11-2015, 06:46 AM Thread Starter
Contributor of the Month
Default Substitute for Pecan
I will be making some pieces to match pecan furniture. Pecan isn't readily available in my area. Is there another wood that I can use and stain to look like pecan?
JIMMIEM is offline
post #2 of 4 (permalink) Old 03-11-2015, 07:06 AM
DonkeyHody's Avatar
First Name: Andy
Hickory is a close cousin to pecan. Probably equally hard to get in quantity.
DonkeyHody is offline
post #3 of 4 (permalink) Old 03-11-2015, 07:21 AM
hickory is about as close as you can get to Pecan...
keep in mind there are 6 or 7 different Hickories and one of them should get very close...
look to Pignut Hickory 1st... pignut is often referred to as pecan.
It is very light even in the heartwood and is often referred to as pecan.
Usually hickory and pecan isn't separated at the mills because they both fall into the same species....
post #4 of 4 (permalink) Old 03-12-2015, 08:13 AM
you might try Woodcraft. They have a pretty good selection or would probably order what you require.
pretender74 is offline
Substitute for mahogany/cypress? nematode Wood Species 16 07-10-2012 06:29 AM
