avoid warping - Router Forums
 17Likes
post #1 of 14 (permalink) Old 05-27-2015, 10:29 AM Thread Starter
First Name: Woody
Default avoid warping
I need to make some beams out of 1 x 2s in this configuration
I will glue and screw them and they need to be 15 feet long. Any advice on least expensive wood consistent with minimal warping and twisting?
woody1401 is offline
post #2 of 14 (permalink) Old 05-27-2015, 10:43 AM
Is cost a concern, Woody? How durable do they need to be? Interior or exterior application?
For outside stuff, where strength isn't a big deal, I like Western Red Cedar. I always keep a few planks lying around drying, so they're ready for machining when a project pops up, but for 16" lengths you're
really limited to construction material. 1x4 SPF or D. Fir if you can find it. In 16' lengths the quality will be fairly decent in either.
For those small dimension members predrilling the screw holes may save you some grief.
Also, a slight (1/8" deep x 3/4" wide) dado in the face of the bottom member will be a huge help in assembly... it'll keep the whole shebang nice and straight with the vertical leg exactly centred...also you'll know exactly where the glue goes!
DaninVan is online now
post #3 of 14 (permalink) Old 05-27-2015, 10:45 AM
Are you going to buy the 1X2's already made or cut them to size yourself.
The thing about 1X2's is that you need straight grain knot free material and beware that if you buy 1X4's or wider, you don't know what they will do when ripped to 1 1/2". there are all kinds of internal stresses that are released.
If I were doing it I would hand pick 1X2's from the pile, and as a last resort mill them myself.
Not sure what you are going to span /support in 15', but you will have to have intermediate support/hangers because that size will not support itself.
Not knowing what you are making, I have no idea what kind of wood you would use.
Herb Stoops is online now
post #4 of 14 (permalink) Old 05-27-2015, 12:20 PM
rip 2 by material to ¾ thickness...
look to Redwood or vertical grained fir... (VGF)
knotless cedar will be hard to come by..
by studying the ends of your selected material you'll be able to find lumber that has the tightest and most verticaled grain...
the more perpendicular (and the closer together) the grain lines are to the face the better off you will be.. it's the most stable of saw woods...
post #5 of 14 (permalink) Old 05-27-2015, 02:47 PM
Woody your profile doesn't say what area you are from but if you are out west then D fir, spruce, lodge pole pine, and hemlock are all possibilities.
post #6 of 14 (permalink) Old 05-27-2015, 02:55 PM
Wink
That's a great illustration of expected warpage, Stick! That should be a 'Sticky'...
vchiarelli, old55 and Herb Stoops like this.
post #7 of 14 (permalink) Old 05-27-2015, 06:59 PM
it should...
I've asked...
here's another...
File Type: pdf CHARACTERISTICS OF WOOD and DEALING WITH THEM.pdf (485.9 KB, 166 views)
DaninVan, ksidwy, jcayer and 2 others like this.
post #8 of 14 (permalink) Old 05-27-2015, 07:10 PM
I believe I'd pass on the lodge pole...
VGF would be my 1st choice...
post #9 of 14 (permalink) Old 05-28-2015, 07:22 AM
What stick said, plus a dado on the side-ways stringer, plus glue, lots of glue. But I also doubt it will support itself, let alone anything set on top of it. You might get a little more strength if you use three pieces in a U configuraton, or if you put a third stringer on top, like an I beam. The crossed stresses in the three pieces of the I beam should help cancel each other out resulting in less twisting. But sagging will be your main problem, especially over time.
If it is outdoors, use waterproof glue. If outdoors, a water proof coating might be wise.
I have a grid of 2x2s about 14 x 10 feet, on which I stretched shade cloth for an open area over a patio. There are 3 long stringers, one on each side, one in the middle. I used some existing, very twisted 2x2s under the grid that were already in place to span the bottom. Straightened them as much as possible and put one long deck screw in the middle to attach them to the middle stringer. Amazingly the twists have completely straightened out (rains and sun) over time. So depending on what you're making, attaching the T or I beam to whatever it supports may help strengthen it and keep it from twisting.
Personally, I'd make this using shorter lengths of a harder wood and overlap the joints so they don't meet in the same place. I think you are going to have a much easier time finding sufficient material with appropriate grain if you go for shorter pieces. For the top and bottom of the I, or the cross on the T, I'd select grain that was perpendicular to the flat side. For the I or stem of the beam, I'd look for grain that was parallel to the flat surface. With the I beam construction, you could use a really good ply, which will be dimensionally stable as well as very strong. The edges in the vertical piece buried in a groove will protect it from moisture. Screws through the whole beam and into whatever the beam supports will also help prevent warping.
Whatever approach you take, Glue and screws will turn it into a solid piece. If you use a shallow dado to set the tall dimension of the I beam in place, you'll get a little more glue surface, which will help strengthen the final result.
How, exactly will you be using this?
post #10 of 14 (permalink) Old 06-01-2015, 10:50 AM Thread Starter
First Name: Woody
Thank you all for the great and helpful info. Attached is a photo similar to the project I am making. I will replace the aluminum beams with the 1 x 2 ones I was asking about. I think the dado idea would be worth doing also. Again, thank you all.
Name:	Deck Canopy Capture.JPG
MDF router table, warping, continuing saga phillipdanbury Table-mounted Routing 19 07-16-2013 08:07 PM
staircase with winders..how to avoid them? Snickare85 The Finishing Touch 19 12-31-2012 05:43 AM
Help! Warping wood luckydad Tools and Woodworking 10 12-10-2012 08:00 AM
Hitachi M12V2 plunge lock problem to avoid AlanWS General Routing 1 03-25-2011 07:57 PM
avoid warping reds_21 Tools and Woodworking 7 01-29-2006 08:25 AM
