Wood Species Identification - Page 4 - Router Forums
 16Likes
post #31 of 41 (permalink) Old 06-24-2015, 02:32 AM
" I guess I should listen to my wife more."
*shock!*
Bite your tongue, Man; men have been flogged for those kinds of revolutionary ideas.
Heresy...from the Latin Her say
...Heresy is any provocative belief or theory that is strongly at variance with established beliefs or customs. A heretic is a proponent of such claims or beliefs.
jw2170 and Stick486 like this.
DaninVan is online now
post #32 of 41 (permalink) Old 06-24-2015, 09:19 AM Thread Starter
Contributor of the Month
Well maybe just a little bit more.
JIMMIEM is offline
post #33 of 41 (permalink) Old 07-02-2015, 05:17 PM Thread Starter
Default Wood Species Identification
I sent a email to the manufacturer requesting info on the wood species. This was the response.
"This group is made of Primareva veneers, virola, maple and pecan exposed solids."
Are the drawer sides virola?
JIMMIEM is offline
post #34 of 41 (permalink) Old 07-03-2015, 09:23 AM Thread Starter
Originally Posted by JIMMIEM View Post
Would like help identifying the wood species in the attached pictures. All 3 pictures are from the same bedroom set.
JIMMIEM is offline
post #35 of 41 (permalink) Old 07-03-2015, 05:21 PM
can I have one more picture???...
take a picture of the dresser's side and a drawer front w/ the grain going in the same direction for both...
try to limit the glare and incandescent/florescent lighting please...
Virola... virola
I didn't see any...
the drawer sides are oak...
the drawer fronts are Pecan...
WTB the panels are Primavera Veneer...
An interesting fact about Primavera Veneer (also known as Prima Vera): The sap of this tree rises and falls with the phases of the moon, which is what happens in temperate zones. When the trees are cut they will wait until the "Dark of the Moon" when the sap content is down to keep the lumber safe from insect attack.
Prima Vera is found in Central America. It is also known as durango, palo blanco, san juan and roble.
Primavera Wood Veneer,Durango,Palo Blanco,Marfim,White Mahogany,Primavera,Copal
Characteristics....
Color/Appearance: Usually ranges from a pale cream color to a golden yellow. Color tends to darken and redden with age. Can exhibit a ribbon-like chatoyant grain pattern similar to quartersawn Sapele.
Grain/Texture: Grain usually ranges from straight to slightly interlocked. Medium texture and medium sized pores, with a naturally high luster.
Workability: Although Primavera frequently has interlocked and irregular grain, it is overall quite easy to work: most likely on account of its rather low density compared to other hardwoods. It does, however, have a moderate blunting effect on cutting edges, so carbide tools are recommended. Primavera also tends to split when nailed or screwed, so pilot holes are recommended despite the wood’s softness. Turns, glues, stains, and finishes well.
Common Uses: Veneer, furniture, cabinetry, and interior trim.
Comments: Primavera looks similar to a number of other wood species, such as Ceylon Satinwood, and is sometimes also referred to as “White Mahogany.”
Related Species: None available.
post #36 of 41 (permalink) Old 07-03-2015, 05:27 PM Thread Starter
Virola... virola
I didn't see any...
Characteristics....
Do you want me to remove a drawer and stand it on its side so its grain runs vertically and stand it right beside the end panel??
JIMMIEM is offline
post #37 of 41 (permalink) Old 07-03-2015, 05:30 PM
yes, please...
do two drawers if you like...
post #38 of 41 (permalink) Old 07-03-2015, 06:12 PM Thread Starter
yes, please...
Will do. Starting to lose daylight now. I'll do it tomorrow AM when I can use more natural light and try and avoid the use of the camera flash and glare. Stay tuned.
JIMMIEM is offline
post #39 of 41 (permalink) Old 07-03-2015, 06:30 PM
is this where I say roger. wilco, standing by???
if the weather breaks I'm heading back into the mountains for 2 days and nights...
post #40 of 41 (permalink) Old 07-03-2015, 06:54 PM Thread Starter
Affirmative!!!! Be careful in the mountains. I'll be here when you get back.
JIMMIEM is offline
Router bits for Mortise and Tenon project? windhollowfarm Router Bits - Types and Usage 267 08-29-2018 12:19 PM
Reclaiming wood Mike Tools and Woodworking 13 11-18-2012 01:01 PM
Wood species needed for bowls or trays MT Stringer Wood Species 5 10-08-2012 01:18 PM
acrylic stabilized wood gav Wood Species 6 05-31-2012 12:45 PM
Wood species ID bbdiamond Wood Species 5 07-06-2009 06:49 AM
