Wood for Cutting Boards... - Router Forums
 23Likes
post #1 of 32 (permalink) Old 02-01-2016, 08:58 PM Thread Starter
Nickp's Avatar
First Name: Nick
Default Wood for Cutting Boards...
A bunch of mahogany and maple fell in my lap...can I use for cutting boards...? Or am I going to wind up with a bunch of boxes...
The pieces are mostly 1x2 and 2x2...maple is unfinished, mahogany seems oil finished...
Thanks in advance...
Nick
Points to Ponder...
LEARNING - the decision you make to know and
understand more about some thing.
TIME - the thing that gets in the way of learning.
Nickp is offline
post #2 of 32 (permalink) Old 02-01-2016, 09:09 PM
No problem with the maple, the oil finish on the mahogany might pose a problem for cutting boards, But you could make some fancy trays out of it and seal any of the oil finish with shellac or lacquer.
Nickp, Semipro and Murtu01 like this.
Herb Stoops is offline
post #3 of 32 (permalink) Old 02-01-2016, 10:12 PM
DonkeyHody's Avatar
First Name: Andy
The problem I see with wood that's already oiled is that it may interfere with the glue adhesion. Put a drop of water on the wood and see if it soaks in and changes the color of the wood, or does it just sit there. If it soaks in, you can use Titebond or similar. If it doesn't, you'll need to use polyurethane or epoxy. Messy messy . . .
Nickp likes this.
DonkeyHody is offline
post #4 of 32 (permalink) Old 02-01-2016, 10:24 PM
Maple is harder, mahogany is prettier. Dealer's choice...
maple is harder and some mahogany don't do water well...
some mahogany tends to be more akin to pine in softness but it is very workable...
how ever Santos mahogany tends to be dense and oily...
which mahogany do you have...
could that oil finish be natural oils...
for glue up, suggest you treat it as oily tropical wood...
Nickp likes this.
post #5 of 32 (permalink) Old 02-01-2016, 10:42 PM
First Name: Keith
Nick if you're concerned about what appears to be oil on the mahogany, you could try a couple of things.
First see what happens when you try and take the oil out with paint thinner or something similar. It might take a few cleanings before it wants to stay clean.
Then try a light pass through your planer and compare the colour of the planed surface to one of your cleaned surfaces. Now you will have an idea of how successful you were in the removal process. That will be your judgment call. Try a 10x eye loupe to get a closer look.
Next, you might try taking 1/16" to 1/8" off one side to see what that comes out like. If it is similar to your cleaning/light planing system, then you should know that the cleaning method is working OK. I don't suppose that you want to waste too much of the mahogany.
If you are still fearful of there being oil in the wood, resort to epoxy to glue it up. That will keep it together.
The maple shouldn't present any significant problems.
Nickp likes this.
cocobolo1 is offline
post #6 of 32 (permalink) Old 02-02-2016, 07:05 AM
First Name: frank
Mahogany.....denatured alcohol will remove the surface oil,but glue up quickly
Nickp and Roy Drake like this.
frankr4ever is offline
post #7 of 32 (permalink) Old 02-02-2016, 08:26 AM
First Name: Keith
Yes, and therein lies the hitch. More of the oil (depending on how far it has penetrated) will try to migrate to the outside of the wood again if you don't glue it very shortly. Which is why you may well need to repeat the treatment a time or two.
I doubt that most of us would cut or plane something and be gluing up in the next few minutes. Typically, when I'm on a project, I do a dry run first, then disassemble again to do the glueup.
I've never actually tested a piece of oiled wood to see how far it gets into a surface. No doubt it would depend on the porosity of the wood in question. Cocobolo, for example, is so loaded with oils that you cannot get it out. Epoxy to the rescue.
Nickp likes this.
post #8 of 32 (permalink) Old 02-02-2016, 10:02 AM Thread Starter
Nickp's Avatar
First Name: Nick
Thanks, Herb...you've got me started on a new path. I wanted to make something out of some of the wood as a gift to my benefactor...so I came up with cutting board. A tray is a fabulous idea.
I will still pursue a cutting board for SWMBO's kitchen...
Nick
Points to Ponder...
Nickp is offline
post #9 of 32 (permalink) Old 02-02-2016, 10:17 AM
First Name: Keith
Nick, we'll all be looking forward to seeing what you come up with.
post #10 of 32 (permalink) Old 02-02-2016, 10:19 AM
I agree with Herb. No problem at all with the maple but I would be reluctant to use the mahogany for making any food item.
Bill
Nickp and Herb Stoops like this.
billyjim is offline
Router bits for Mortise and Tenon project? windhollowfarm Router Bits - Types and Usage 267 08-29-2018 12:19 PM
New to wood working and to this forum. jaithran New Member Introductions 9 11-25-2014 01:50 AM
Air dry small quantity of wood indoors? Barry747 New Member Introductions 12 10-21-2013 08:07 AM
acrylic stabilized wood gav Wood Species 6 05-31-2012 12:45 PM
Choosing the best wood for outdoor projects Hamlin Wood Species 5 07-21-2009 08:40 PM
