wood suggestion for a kitchen box - Router Forums
 1Likes
post #1 of 13 (permalink) Old 04-25-2016, 07:14 PM Thread Starter
Question wood suggestion for a kitchen box
I've got a notion to build what's called a 'kitchen box' or 'grub box' for car camping in my VW Westphalia camper. If you don't recognize those terms, it's a sort of portable cabinet to hold cookware and cooking utensils, dishes and cups and flatware, and so forth. You can carry it out and set it on a campsite table, then when you're finished cleaning up you close it up and lock it so the critters can't get in. Folding handles on the sides to carry it around.
Traditionally it would have been built out of pine, but the pine I can get around here is flat-sawn and I don't like the look of it. I'd rather have quarter-sawn wood, for appearance. I'd also like to use a light-weight wood, so that the box all by itself isn't too heavy. It'll be heavy enough with the cookware and so forth in it.
I'd use butternut if I could get it locally, but I can't. Yellow cedar's too yellow, fir is too pink - I'll finish it natural, with no staining on account of the problems matching stain for repairs.
Any suggestions?
Thanks,
Tom
tdacon is offline
post #2 of 13 (permalink) Old 04-25-2016, 07:28 PM
The first thing I would suggest Tom is that you finish filling out your profile so we have an idea where you are because if you live in Florida and some member says you can go to a supplier in north west Washington it won't be very helpful to you.
If you can easily get flat sawn it either means the quarter sawn is somewhere you aren't looking or the trees are so small that there isn't any. Vertical grain can be had most anywhere if you are willing to pay the price. Red oak is probably one of the best choices between hardness, price, and weight.
post #3 of 13 (permalink) Old 04-25-2016, 07:34 PM
frame the box and use dadoed in plywood panels...
post #4 of 13 (permalink) Old 04-25-2016, 08:45 PM
Paulownia wood is both light and strong. But it's not available everywhere.
<Chas>
I'll burn that bridge when I come to it
CharlesWebster is offline
post #5 of 13 (permalink) Old 04-25-2016, 11:16 PM
Contributor of the Month
PhilBa's Avatar
First Name: phil
The first thing you should do is google "camping box plans". Look at the images - lots of designs out there.
Plywood is your best bet - light and strong,
Visit my shop website.
PhilBa is online now
post #6 of 13 (permalink) Old 04-26-2016, 09:59 AM
First Name: Buck
I'd go with the framed plywood too. You can veneer the panels with a wood you like and the frames can be made out of the same wood as the veneers or a contrasting wood. I would think 1/4" ply wood work.
BOjr is offline
post #7 of 13 (permalink) Old 04-26-2016, 11:50 AM
First Name: Ron
Check out this site for plans on camping boxes - good source. Uses ply board (thin) and reinforces with fiberglass.
The camp kitchen chuck box.
alaskagypsy is offline
post #8 of 13 (permalink) Old 04-29-2016, 12:06 PM Thread Starter
Thanks, folks. Those sound like good ideas. Doing 1/4" ply framed panels seems like a great idea to keep the weight down. I'd been thinking of solid wood panels, about 1/2", but the 1/4" ply would definitely be lighter, and would perhaps allow me to use a more durable wood for the framing.
Tom
tdacon is offline
post #9 of 13 (permalink) Old 04-29-2016, 12:13 PM
Tom
and if the ply is Baltic Birch you will be miles ahead of the game...
get it w/ Phenolic Facing will be like moving to the head of the class...
post #10 of 13 (permalink) Old 04-29-2016, 01:14 PM
PhilBa's Avatar
First Name: phil
Tom
One of the things that has surprised me in woodworking is how little wood you really need for strength. I bet if you use 1/4" BB and 1/2" x 1/2" poplar stock for the frame it will be plenty strong. You might be able to get away with 1/2" ply and frameless construction. Not sure which would be lighter. Let us know how it turns out.
Planning projects for wood movement Duane Bledsoe Tools and Woodworking 27 10-13-2015 10:39 PM
Bit Storage Box...Wood Type ?... Nickp Router Bits - Types and Usage 2 01-09-2015 12:27 PM
New to wood working and to this forum. jaithran New Member Introductions 9 11-25-2014 01:50 AM
Wood Species dattashri Wood Species 7 07-26-2012 11:23 AM
How to identify wood species: allthunbs Tools and Woodworking 11 12-04-2008 01:28 PM
