Strange Stains on White Oak - Router Forums
 3Likes
post #1 of 12 (permalink) Old 06-07-2016, 09:21 AM Thread Starter
First Name: Phillip
Default Strange Stains on White Oak
Hello all,
On my most recent project, I noticed some black stains appear during milling. The stained area intensified as I milled more. Of about 15 boards, about 4 have a few stained areas. The stains were adjacent to the grain, which suggests that the stains are not naturally occurring in the grain. From the surface, I couldn't tell which boards would have stains. Occurred on 4/4 and 8/4.
See the attached photos. Is this a known phenomenon or did I get a freak batch?
To change the world, change your mind.
phillipdanbury is offline
post #2 of 12 (permalink) Old 06-07-2016, 12:36 PM
Kind of looks like the steel forklift fork imprint, or a steel rack or cart, or bunk imprint.
Herb Stoops is offline
post #3 of 12 (permalink) Old 06-07-2016, 03:33 PM
looks like the oak came in contact w/ iron or steel...
oxalic acid may clean it up...
bcfunburst likes this.
post #4 of 12 (permalink) Old 06-07-2016, 03:34 PM
TwoSkies57's Avatar
wondering if barbed wire might have caused that?? this is an interesting one
Skipper the Penguin
TwoSkies57 is offline
post #5 of 12 (permalink) Old 06-07-2016, 05:19 PM
Maybe steel banding on the sling, if it was bundled. Or if it was kiln dried, maybe the cart or rack support made it as the moisture was drawn from the wood., if it was the bottom layer of the stack.
Is it on both sides of the board, and in the same spot on other boards?
post #6 of 12 (permalink) Old 06-08-2016, 01:41 AM
Another but slightly lesser possibility is that the lumber was stickered with some wood that maybe had too high a moisture content.
paduke and Herb Stoops like this.
post #7 of 12 (permalink) Old 06-08-2016, 01:53 PM Thread Starter
First Name: Phillip
The steel banding on the stack was my first thought. Strange though that I didn't see any markings on the outside of the wood. I only noticed something when I begin milling. Also, the markings intensified as I got deeper. Any way I might anticipate this for the future?
post #8 of 12 (permalink) Old 06-08-2016, 02:11 PM
bcfunburst's Avatar
First Name: Reg
Default Staining in White Oak
Is it possible the staining is a type of mould inside the wood, just like the blackish staining in Maple?? I have seen this sort of staining in many different hardwoods and I was told it was a type of mould caused by prolonged moisture retention. There may be a product to bleach out the stain if you do a Google Search.
"Even bad decisions make good stories"
<bcfunburst>
bcfunburst is offline
post #9 of 12 (permalink) Old 06-08-2016, 02:17 PM
If it got worse as you went deeper makes me think it may have been on the verge of starting to rot. Rots start out as a stain and the stain that's there is too wide for banding. Banding is only normally 1/2 to 1" wide. Is there any indication that that area was close to a knot? Broken limbs are the usual entry point of wood fungi and since knots go to the heart of the tree they follow the heart and then work their way back through other knots back out to the surface of the tree.
post #10 of 12 (permalink) Old 06-08-2016, 05:29 PM
Looks to me like it was bunked on a steel bunk or rack to dry and the moisture in the wood migrated to the steel and as the wood dried it absorbed it and turned dark. It probably only showed up on the bottom boards of the pile, is my guess. If it was fungus seems to me it would be following the grain.
Those little white plastic panel guides for Oak Parks Router Table dkpender Table-mounted Routing 9 05-21-2012 07:52 PM
Cheap white oak at Home Depot kp91 The Bargain Bin 0 02-02-2011 08:12 PM
Red oak or White Oak splinters12 Wood Species 2 09-03-2010 07:38 AM
White oak routing Puumies General Routing 3 12-15-2007 09:31 AM
