HF dust collector flow measurements - Router Forums
 65Likes
post #1 of 118 (permalink) Old 01-22-2017, 09:39 AM Thread Starter
furboo's Avatar
First Name: Rob
Default HF dust collector flow measurements
I wanted to keep track of modifications to my new HF DC, so I built a very simple manometer this morning. My only mod so far is the Wynn filter. Pictures below.
Initial measurements
As close to the HF inlet as I can measure (see picture staticp.jpg), I get 6" H20, which if my calculations are correct, translates to 975 CFM. Note that I live at 7,200' altitude, so any DC will suffer a lot in performance. I'm also using a 4" pipe, a big no-no according to DC experts, but it makes hooking up to my tools a lot easier.
I then measured at the end of a Rockler 4' long expandable hose. See pic hose.jpg (it's unhooked in the picture) and
Dust Right® 4'' Dia. Expandable Hoses | Rockler Woodworking and Hardware
This drops the performance to 2.5" H20, or about 630 CFM. Ouch. This was with the hose compressed and no bends. So, I guess I gotta change how I bring the DC to my tools.
Anyway, as I modify my DC, I want to keep track of performance changes.
Some details
The manometer itself 1/2" tubing with filled with water, with green food coloring. I step that down to a long section of 3/8" tubing (to reach anywhere in my shop), then to 1/4" tubing. I drilled a 1/4" hole in a 4" hose splice, and that's where I measure static pressure. Again, see staticp.jpg. The markings on the manometer are 1/2" apart. Pretty simple.
My measurements may be a bit off, because I need to seal the attachments. But I doubt that they're off that much.
Converting inches of H20 to CFM requires some assumptions, the biggest being current air density. But that doesn't really matter. The bottom line is you want to maximize inches of H20 (the difference in the water levels), and the manometer lets you measure any changes to the DC system.
Rob
furboo is offline
post #2 of 118 (permalink) Old 01-22-2017, 09:45 AM Thread Starter
furboo's Avatar
First Name: Rob
I should mention that I got the idea for the simple manometer from
where he explains using it for keep track if the Wynn filter needs cleaning. I'll hook it up that way do once I'm happy with my other DC mods.
Danman1957, Daikusan and bwilling like this.
Rob
furboo is offline
post #3 of 118 (permalink) Old 01-22-2017, 12:04 PM
That's a great idea to make one for monitoring the filter's condition Rob. Thanks.
post #4 of 118 (permalink) Old 01-22-2017, 01:04 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Rob, home made manometers arent all that accurate. OK so long as you only use the one and only compare it to your other measurements, but often not transferable to another set up.
Any large plumbing or gas fitting supplier will sell a proper manometer as used for taking gas pressure readings.
This is just the first link I found
https://www.amazon.com/General-Tools.../dp/B001TOHT78
sunnybob is offline
post #5 of 118 (permalink) Old 01-22-2017, 01:05 PM
First Name: Eugene
You might want to make one of these carts but you will have to add a sdd, best thing I did, I have great suction, no loss, I fiddled with my dust collection until I finally bit the cart. I work in a 2 car garage I was going to add ducting but still fiddling with my layout in the shop.
Name:	2017-01-22 14_1485111781986.01.40.jpg
Herb Stoops, bryansong and furboo like this.
Eugd is offline
post #6 of 118 (permalink) Old 01-22-2017, 03:41 PM Thread Starter
furboo's Avatar
First Name: Rob
Bob, I'm not claiming that my measurement of water level or CFM is accurate. I certainly don't want HF to sue me for misrepresenting their DC performance
My motivation is to see the effect of changes in DC setup, and I claim homemade is good enough to do this, at least for changes large enough to have a noticeable effect on dust collection. The fact that I'm doing this at 7,200' altitude will mean my water level and CFM numbers will be far from most others on this forum.
The manometer in your link might add precision to the readout, but will not compensate for the assumptions required to back out CFM from the water height. I suspect these assumptions create bigger errors than from reading the water level. If you really want to increase the accuracy of the reading, save your $27.99, use longer tubing on a tilted table, and a well characterized fluid.
whimsofchaz likes this.
Rob
furboo is offline
post #7 of 118 (permalink) Old 01-22-2017, 03:48 PM Thread Starter
furboo's Avatar
First Name: Rob
Nice setup, Eugene. My DC is on rollers, and it looks like I'll keep it that way when I add a chip collector. It looks like you're using smaller bag than stock, and I was considering the same thing, in order to shorten the DC.
Rob
furboo is offline
post #8 of 118 (permalink) Old 01-22-2017, 03:49 PM
RainMan 2.0's Avatar
Rob I was thinking it wasn't so much about accuracy, but to monitor whether or not an improvement has taken place .
Ok ,I never insulate
RainMan 2.0 is online now
post #9 of 118 (permalink) Old 01-22-2017, 03:53 PM
I certainly never thought of it as being able to take an accurate reading but it is an excellent way to monitor system and filter performance since you'll obviously take a reading when the system is new and that will allow you to be able to track performance over time and with filter cleanings. Since the set up is static it will respond accurately to changes even though it isn't particularly accurate in terms of absoluteness. That's all I would really be interested in knowing, since there is very little I can do to change the system, is to be able to monitor how well it is performing under it's relatively fixed parameters.
post #10 of 118 (permalink) Old 01-22-2017, 04:56 PM Thread Starter
furboo's Avatar
First Name: Rob
Yes, exactly.
RainMan 2.0 likes this.
Rob
furboo is offline
Tips for Installing a Dust Collection System Router Forums Featured Topics 121 02-24-2017 11:20 AM
Small shop dust collection Barry747 Shop Safety 4 10-12-2015 11:04 AM
A Dust Problem rrrun The Finishing Touch 15 01-19-2015 10:44 PM
Index of Dust Collection Solutions and Comments allthunbs Shop Safety 28 03-14-2014 01:40 AM
My Dust Collection System MAFoElffen Tools and Woodworking 19 05-23-2013 03:39 PM
