Cartridge filter for a Grizzly 1.5HP Collector. - Page 2 - Router Forums
 3Likes
post #11 of 17 (permalink) Old 03-28-2017, 06:08 PM
I have two stacked one on top of the other and can not even feel any air coming out of them when the DC is running.
The things I have experienced cutting air flow are :
90Deg. fittings, and "T's"
Flex duct, especially the type with ribs on the inside.
small flex,i.e. 2",2 1/2"diam.
ports smaller than the duct, requiring reducers.
any kind of fins in the ports to keep large chunks from passing
longer runs of ducts
The first Dc system I built was when they recommended the filters like an engine filter. Where the air blows from the inside out the filter was to be put into a box and the air blew into the box and then through the box to get out through the center of the filter which vented through a hole in the bottom of the box.The filer had a flange on the bottom of it that bolted to the bottom of the box. The top of the filter was capped so the air had to go through the pleats.
OK fine.
I made the box with a door on it and weather stripped tight when latched.
The first time I had to clean the filter because it was plugged up, it was a real chore. I swore, I would remedy this with the air blowing inside the filter and exhausting through the filter. Can you imagine cleaning the pleats on a vacuum cleaner filter 4' high and 16" in diam with the pleats packed with fine sawdust?
furboo likes this.
Herb Stoops is offline
post #12 of 17 (permalink) Old 03-28-2017, 06:52 PM
Originally Posted by hawkeye10 View Post
I guess my thinking is way off as usual. I was thinking with more filtering surface I would get better suction. I guess not. My bag that came with the collector filters down to 2.5 microns and as I understand it the dust cake that lines the bag filters it more. I may be wrong about that to.
It's true what Stick said. I ran heavy equipment for many years and that was what the equipment manufacturers would say. They suggested that when an air filter got dirty to just keep bumping it against a machine tire to loosen the excess dust until none or very little would shake free. When they got too dirty then I would wash them in a 20 liter pail of soapy water and rinse and dry them but they didn't filter as well until they got a little dirty again.
post #13 of 17 (permalink) Old 03-28-2017, 07:26 PM
furboo's Avatar
First Name: Rob
I think more filtering surface area is better. That's why they Wynn (and lots of filters) use pleats.
As far as dirty = "better filtering", that's correct. But the dirtier it is, the less suction of the overall system.
Wynn discusses this pretty well at this page:
https://wynnenv.com/filter-efficiency/
To cut to the chase, see their table here:
https://wynnenv.com/wp-content/uploa...ata.jpg?x35957
The row across the top is the "Delta P", which is the pressure drop across the filter. The bigger this value, the dirtier the filter, and the harder your DC motor has to work to pump the same air through the system (it generally doesn't work harder, so the airflow decreases). But notice the dirtier it is, the better the "Fractional Efficiency" (the percentage of particles blocked at the specified particle size)... that is, the filtering gets better. Cool stuff.
I would still get the Wynn, because you're going to have to clean any filter, at which point you're breathing what it's not catching. But that's my lungs & budget. Although so far I've survived prostate cancer (you really don't know you've survived until you die of something else), I don't want to try my luck at lung cancer.
Rob
furboo is offline
post #14 of 17 (permalink) Old 03-28-2017, 07:38 PM
furboo's Avatar
First Name: Rob
Originally Posted by DesertRatTom View Post
There more recently was a long string that included swapping out the smaller HF impeller with a Grizzly impeller, which greatly increased air flow, but took a long time to wind down. @Furbo didn't you guys spend a lot time working out air flow? I got two HF units (shop and garage), and am thinking of adding the Wynn finter to the second unit. It will be the 1 micron Wynn.
A "a lot of time" ???? You sound like my wife!
Yeah Tom, that's in another thread, where I compared the Wynn to the stock HF bag:
http://www.routerforums.com/tools-wo...nn#post1443178
I put in a Rikon impeller, not Grizzly:
http://www.routerforums.com/tools-wo...ml#post1474481
Rob
furboo is offline
post #15 of 17 (permalink) Old 03-30-2017, 01:35 AM
First Name: Tony
anything is better than a straight up bag I suppose...
comp56 is offline
post #16 of 17 (permalink) Old 09-04-2019, 10:38 AM
WoodWorkerNewbie's Avatar
First Name: Kaitlyn
True. Bag filters aren't as efficient as cartridge collectors. Aren't they a bit messier than usual as well?
WoodWorkerNewbie is offline
post #17 of 17 (permalink) Old 09-04-2019, 04:42 PM
I believe the Grizzly made 1-micron canister fits the HF unit (call to confirm). It has a rotating interior brush connected to a handle on the outside. Rotate the handle and it knocks the excess sawdust off. $235 https://www.grizzly.com/products/Gri...Series/G0548ZP
I understand it is the same size as the HF unit. If so I'd consider it. The Wynn, you slap on the sides to knock the excess off, and occasinally blow compressed air through it from the outside. The Wynn really cuts the airborne sawdust inside a shop. The bag, to me, is a no no inside the shop. Over time you will regret using it inside. And it will be too late.
Sominus likes this.
DesertRatTom is online now
Grizzly GO513X2 bandsaw TwoSkies57 Tool Reviews 46 04-10-2019 06:05 AM
Grizzly G0703 Cyclone Dust Collector copythat Tools and Woodworking 6 10-21-2016 11:00 PM
Dust Collector Cart timbertailor Portable Routing 18 11-04-2014 04:29 PM
Dust Collection Finally! Willway General Routing 44 05-10-2014 11:59 PM
Grizzly dust collector is on sale Glenmore The Bargain Bin 1 03-29-2006 12:06 PM
