The best Dust Collection deal in the universe is back! - Router Forums
 31Likes
post #1 of 43 (permalink) Old 05-28-2017, 02:10 AM Thread Starter
Default The best Dust Collection deal in the universe is back!
Harbor Freight's fantastic deal on their 2HP, 70 gallon dust collector is back. On sale this month at $199, but this weekend with an additional 20 percent off with their coupon.That brings the price down to $160. And on Monday May 29th, there is a that-day-only coupon for 25 percent off! That makes it $150.
Even if you make your own DC system, it will cost you more than this. If you want it to work inside your shop so you don't pump the warm/cold air out, order the Wynn drum filter for it {pix is with the Wynn filter, it comes with a bag filter, much less efficient). And Rockler and other companies make chip collectors (or make your own with barrel or bucket with a cyclone or shop-made Thein unit. That's about as good as dust collection gets for a small shop.
And if you really want something that will suck a golf ball through a garden hose, search the site and find the thread on swapping out the impeller with one from another manufacturer (Rikon). I don't think you need to do that though, this thing really does the job.
If you can't get there for the 20 or 25 percent coupon deals, $199 is still pretty darn good.
I just bought a WEN ceiling mounted filter for less than $90, delivered to my local WalMart with no shipping charge. Found on WalMart.com, but not sure it is still available at that price. It was $130 on Amazon.
This completes the basic DC package for less than half of what the name brand units cost. Really good way to protect your lungs. If they run out, get a rain check!
Name:	DC Wynn filter.jpg
post #2 of 43 (permalink) Old 05-28-2017, 04:46 AM
hawkeye10's Avatar
First Name: Don
Tom if I had it to do over again the HF is the one I would get. I now have the Grizzly 1.5HP dust collector. These lessons cost so much money.
chessnut2 and artman60 like this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 43 (permalink) Old 05-29-2017, 07:04 PM
Everend's Avatar
First Name: Everend
Tom & Don, I hope you are right that this is the way to go, I just went online and got it (plus $22 shipping). It would cost me more in gas to drive into Austin to pick it up.
I say I hope you are right about this one being a good deal because right now I've got a shop-vac in the attic with a shop built dust separator box on the floor of the garage and 2" pvc connecting them. The problem with this setup is the shopvac is under-powered for the job and I've had to replace it twice in the last few years. Also the filtering I've got in place greatly reduce the suction and easily clog. As the box fills the suction has to draw through increasing amounts of sawdust.
I'm not sure where I'll put this new one but it should be a big improvement over what I have now.
DesertRatTom likes this.
Everend is offline
post #4 of 43 (permalink) Old 05-29-2017, 10:07 PM Thread Starter
I just don't think you can go wrong. If you read comments in this and other strings on this specific DC unit, you'll find lots of good comments. However, it won't work at its peak unless you make a chip collector to go in front of it, connected through a 4 inch hose. You can make one of these using a few parts from Rockler (the company I bought from).
Here's the link to the system I use. Dust RightŪ 4" Dust Separator Components | Rockler Woodworking and Hardware You need a flat top trash container, 30-40 gallon will do. I ordered a 30 gallon fiber drum from ULine because it has a perfectly flat top that locks on tight.
You will also need some 4 inch hose, which I bought from Roickler since their 4 inch measurement makes everything fit. Mixing brands doesn't always work. I started with the 27 ft hose and cut off shorter pieces as needed. The unit sits on a base with casters so you can run it right up to each tool. At least that's how I use it. For the one in my small shop, I can't move it, but all my cutting tools are within 12 feet, so the hose reaches everywhere. In my roomier garage, the unit just rolls around.
As noted elsewhere, I put a Wynn drum filter in the shop because it all but eliminates free dust in the small area. I have 4 tools pushed against one wall, with the DC pushed up in the leftover space.
If you have any problem with the unit, take it back to HF. It is a remarkable deal for a very good unit.
post #5 of 43 (permalink) Old 05-30-2017, 01:55 AM
jj777746's Avatar
Tom, what a great bargain.Thanks for sharing.
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
post #6 of 43 (permalink) Old 05-30-2017, 09:04 AM
Everend's Avatar
First Name: Everend
Isn't that a cyclone in the middle of the HF unit? What's the advantage of having two cyclone units in series? Two containers to empty and twice the real estate.
thanks
Everend
Everend is offline
post #7 of 43 (permalink) Old 05-30-2017, 11:19 AM Thread Starter
thanks
Everend
The extra drum is a chip collector. It drops out the chips so they don't hit the impeller, which is both noisy and possibly will damage it. Sometimes you pick up a screw or metalic scrap that falls out in the chip separator, which must come before the impeller.
post #8 of 43 (permalink) Old 05-30-2017, 11:46 AM
Everend's Avatar
First Name: Everend
Of course, that makes sense, that filter and bag need to be on the output end of the impeller or they would be deflated.
Everend is offline
post #9 of 43 (permalink) Old 05-30-2017, 12:25 PM
First Name: Quenten
It just takes some of the load off the HF unit and decreases having to empty the larger bag so often. Also, if you change to the larger impellor, it removes larger chips that might get stuck in the housing.
Tonto1 is offline
post #10 of 43 (permalink) Old 05-30-2017, 02:25 PM Thread Starter
The Wynn drum filter has far more area than the bag, so there is an increase in air flow through it over the bag.
The folded filter surface area is more than 250 sqft. You blow compressed air through the outside of the metal drum to unblock it from time to time. But with the chip collector peeling off most of the sawdust as well as chips, not a whole lot of sawdust makes it into the filter. I'm thinking of adding a drum filter to the second HF unit out in the garage. I like not sucking up sawdust particles.
My current Dust Collection System Herb Stoops Tools and Woodworking 20 10-30-2015 05:11 PM
Small shop dust collection Barry747 Shop Safety 4 10-12-2015 11:04 AM
Dust Collection Balance LAvery Table-mounted Routing 16 08-16-2015 09:30 PM
My Dust Collection System MAFoElffen Tools and Woodworking 19 05-23-2013 03:39 PM
Dust Collection on Table Saw Router Table Extension Guitarman1 Table-mounted Routing 0 10-02-2011 02:32 PM
