Harbor freight dust collector - Router Forums
 28Likes
post #1 of 31 (permalink) Old 01-16-2018, 10:35 AM Thread Starter
First Name: Ken
Default Harbor freight dust collector
I got an email from HF yesterday to advertise their latest sale. There's a coupon in it for the 2HP dust collector at $169.99 Had I not just given them a bit over $500 for a generator I'd be there buying a new DC. The coupon is good until 1-28-18.
DesertRatTom likes this.
kklowell is offline
post #2 of 31 (permalink) Old 01-16-2018, 11:03 AM
I like mine very well. I have two, one in my small shop another in the Garage where the wood prep gets done. Stick suggest checking out name brand units for long term superior performance, and yet so far, I don't recall seeing any other negative post on the HF unit. Some have replaced the stock impeller with one from Rikon (about $90) to increase flow. A few of us have replaced the bag with a Wynn canister filter (about $160) which lets you vent the air back into the shop. Grizzly makes a canister filter with a built in paddle to knock accumulated sawdust off the filter. I just knock the heavy stuff off by slapping the canister, then blow air back through the outside of the canister to refresh it. You will also want to set up a chip collector to catch larger items, screws, etc. before they bang into the impeller.
difalkner likes this.
post #3 of 31 (permalink) Old 01-16-2018, 11:05 AM
I bet they sell a few of those, that is cheaper than a good Vac, a guy could have one for every machine, and a couple of extras for future machines he hasn't bought yet.
Herb Stoops is online now
post #4 of 31 (permalink) Old 01-16-2018, 11:56 AM Thread Starter
First Name: Ken
If I could, I'd buy one. My 1hp and shop vac systems get some of the dust, but this one would help get even more.
kklowell is offline
post #5 of 31 (permalink) Old 01-16-2018, 12:23 PM
Gene Howe's Avatar
First Name: Gene
I've had mine for about 15 years. First thing I did was get a cyclone type lid for 35 gallon trash can. With that placed close to the collector, it catches the chunks that could damage the impeller plus about 90%+ of the dust. Then, I got rid of those bags and vented the DC to the outside. Doing that saved a ton of space and a whole lot of hassle. Some have said that my system would pull heated air out of the shop and/or create negative pressure in the shop. Not so, in my case.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #6 of 31 (permalink) Old 01-16-2018, 12:50 PM
Gene if you don't have negative pressure in your shop it's because you have enough air leaking in to replace what the DC is pushing out.
post #7 of 31 (permalink) Old 01-16-2018, 01:31 PM
difalkner's Avatar
First Name: David
We got one about 15 months ago and I finally replaced the 5 micron bag with a Wynn 0.5 micron filter - much, much better. I only use it on one machine at a time so it's all I really need right now.
David
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is online now
post #8 of 31 (permalink) Old 01-17-2018, 08:05 AM
Gene Howe's Avatar
First Name: Gene
That is undoubtedly true, Chuck. Hermetically sealed, it aint.
A caution, though. I don't have a furnace or hot water heater sharing my shop. Although, there is a flameless heater. I've been told that my system could cause cause a pilot light to go out if the shop were tight enough to cause negative pressure. That could be dangerous. My heater's pilot isn't affected.
Gene Howe
Snowflake, AZ
post #9 of 31 (permalink) Old 02-17-2018, 07:04 PM
If the pilot goes out, doesn't the bimetal controlled valve shut off the gas? I have to manually hold the gas on when lighting the pilot until the valve gets hot enough to stay open by itself. I think that is a standard safety feature.
Sent from my SM-G900V using Tapatalk
Herb Stoops and hawkeye10 like this.
Mycrossover is offline
post #10 of 31 (permalink) Old 02-17-2018, 11:50 PM
Yes it should stop the gas flow. The pilot uses very little as it is. Back about roughly 30 years ago when the move to seal buildings better started there were and can still be issues with gas burning appliances because vent fans can reduce the pressure inside a house to the point that flames may not burn properly and those appliances not vent properly.
Dust collector quieting Keith C General Routing 18 05-10-2017 03:28 PM
dust collector exhaust grandfatherto11 Starting Off 22 12-23-2014 07:03 AM
Swirling hands in my dust collector. JudgeMike Tools and Woodworking 6 05-01-2013 07:03 AM
How to get HF 20A Dust Collector working at 15A or less? JavaGeek General Routing 22 11-15-2011 11:04 AM
Rockler Dust Collector Terry Pepper Tools and Woodworking 4 12-21-2008 08:48 PM
