DownDraft Box - Page 3 - Router Forums
 57Likes
post #21 of 30 (permalink) Old 09-12-2018, 09:40 AM
First Name: Barry
Originally Posted by Herb Stoops View Post
Barry, you might try enlarging some or all of your holes. The small holes actually cut down on the sir flow. Also they recommend beveling both sides of the holes to increase air flow. You can do that by just using a countersink.
Herb, I will enlarge the holes a bit. Since the top is pegboard the counter sink idea won't work. Had I built something like your impressive box, with a thicker top, I'd do that. Thanks for the suggestion.
Barry747 is online now
post #22 of 30 (permalink) Old 09-12-2018, 09:48 AM
First Name: Barry
Forgot to add a picture of my downdraft table. Not even close to Herb's but it's adequate for my small projects.
Name:	Downdraft table.jpg
Herb Stoops likes this.
post #23 of 30 (permalink) Old 09-12-2018, 01:12 PM Thread Starter
Try it without the mat, or a smaller mat and see if the increases the air flow. Also side boards will help like you never would have guessed.
DesertRatTom likes this.
Herb Stoops is online now
post #24 of 30 (permalink) Old 09-13-2018, 12:53 PM
Sometimes you just have to re-purpose the early designs...
https://3.bp.blogspot.com/-ACoiP8I1w...00/OACGBox.gif
mimac, TenGees and Herb Stoops like this.
DaninVan is offline
post #25 of 30 (permalink) Old 09-13-2018, 01:26 PM Thread Starter
LMAO, Fat cat.
DaninVan likes this.
post #26 of 30 (permalink) Old 09-17-2018, 07:45 PM
Default Whack-A-Mole v3.0
LMAO, Fat cat.
No end to the cat thing...
https://3.bp.blogspot.com/-WKWfJKPgX...OACGBoxe3s.gif
DaninVan is offline
post #27 of 30 (permalink) Old 09-08-2019, 09:16 AM
OutoftheWoodwork's Avatar
First Name: Barb
I think you are right. The mini ones seem to hold fine, it is the large ones like the Irwins that don't hold good, and pinch your hands, good eye.
Glad to see I'm not the only one who has trouble with Irwin! I have a couple of their clamps that I can't get to hold a dang thing! I have better luck with my HF ones, too (some of them, anyway.)
Barb
Get your facts first, then you can distort them as you please.
Mark Twain
There cannot be a crisis next week. My schedule is already full.
Henry A. Kissinger
If you choose to poke at a bee hive, be prepared to get stung.
OutoftheWoodwork is offline
post #28 of 30 (permalink) Old 09-08-2019, 09:50 AM
I discovered Bessy had 4 packs of small and medium clamps a few years ago and have gradually replaced all my plastic clamps with them. Still have quite a few HF clamps, but I find my projects are less likely to be torqed out of square using the Bessy's, which have far heavier bars than the HF models of similar size. I've found the packs ranging from $20-$30, often on sale near Christmas. I have a crazy number of clamps, but the super stars are 4 sets of two Jet parallel clamps ranging from 24 to 60 inches--these make case work easier. Again, I was making far more money in those days. I have to tip toe past the clamp section now, keeping a death grip on my wallet.
Flipsaw likes this.
DesertRatTom is online now
post #29 of 30 (permalink) Old 09-08-2019, 12:03 PM Thread Starter
An update on my downdraft box.
I have been using it a lot for small p[projects and it works great. I have noticed a real change for the better in the amount of fine sawdust on things in the shop. I use it with a small rubber pad under the work,some of that non slip drawerliner. That decreases the noise and also keeps the wood from walking around the table top. I have found that the large holes work very well, and the removable side boards do help with concentrating the airflow on the top of the box.
post #30 of 30 (permalink) Old 09-08-2019, 12:26 PM
Long Board Box Joints Help. Have Incra LS Super System Psychbiker Table-mounted Routing 4 09-03-2014 11:52 AM
simple router table - attach vacuum hose to router box, or use Bosch dust adapter? achoox4 Table-mounted Routing 7 07-07-2014 05:01 AM
A DIFFERENT ROUTER LATHE or “A ROUTER STANDARDIZER” neville9999 Jigs and Fixtures 8 01-04-2013 01:48 PM
box corner joinery almost there Jigs and Fixtures 17 10-15-2012 09:08 AM
Beall Tilt Box Versus Wixey Angle Gauge bennybbc Tool Reviews 4 02-04-2010 01:01 PM
