DownDraft Box - Router Forums
 57Likes
post #1 of 30 (permalink) Old 09-03-2018, 09:51 PM Thread Starter
Default DownDraft Box
Here is a downdraft box I just completed today for sanding with my ROS. I used the Rockler plan pdf. that I downloaded off their site .
http://go.rockler.com/tech/25077-Down-Draft-Ezplan2.pdf
I had a part of a sheet of prefinished 1/2"birch plywood I had bought and used for drawer sides. The box is pretty simple to build. I made my own perforated top pieces. I had built one years ago off the same plan, but they had small 1/2" holes and it cut the air flow so much ,I decided to make the holes 1' dia. spaced 1/4" apart.
I tried several drill bits to drill the holes and settled on the spade bit with the scoring ears on it.
I tried a Forstner type bit, and it cut OK from both sides, but it was slower, plugged up,was harder to exactly follow the pilot hole as the pilot point was so short.
The 2 auger type bits were the best cutters, but the threaded pilots would lift the material off table table fast.
The spade bit has a long tapered pilot that centers from both sides easily and the spurs do a good job of scoring the outside cut. I never would have guessed it ,but it worked best for drilling from both sides.
It took the longest to drill and finish all 278 holes.
The pictures tell the story.
Herb Stoops is online now
post #2 of 30 (permalink) Old 09-04-2018, 01:14 AM
World's largest 'Whack-a-Mole' !
Again, Herb, beautifully crafted...have you put it to the test yet?
Just out of curiosity, why does it have to be so deep, top to bottom?
JFPNCM and OutoftheWoodwork like this.
DaninVan is online now
post #3 of 30 (permalink) Old 09-04-2018, 01:38 AM
that's controlled by the thickness of the bed and the dia of the pickup..
JFPNCM, DesertRatTom and jj777746 like this.
post #4 of 30 (permalink) Old 09-04-2018, 01:39 AM
Herb...
you gonna put hardware cloth on the bottom side of the deck for small part loss control???
DesertRatTom, TenGees and jj777746 like this.
post #5 of 30 (permalink) Old 09-04-2018, 05:49 AM
hawkeye10's Avatar
First Name: Don
Herb, that is a very nice build. You might have too many holes or the holes might be too big. My box is I think too big and the holes are too big. I have it hooked up to my big dust collector and it doesn't seem to be pulling enough air.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 30 (permalink) Old 09-04-2018, 06:43 AM
difalkner's Avatar
First Name: David
Nice, Herb. I went with my own design a year ago, still works great and with the DC hooked up it really pulls hard and will hold a piece in place if I block off the rest of the holes (easy to do).
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #7 of 30 (permalink) Old 09-04-2018, 06:52 AM
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
Hmmmmmm!!!
That sure looks like HF gray one handed clamps being used!!
Herb I thought that they went by the wayside a while ago.
smitty10101 is offline
post #8 of 30 (permalink) Old 09-04-2018, 11:24 AM Thread Starter
Originally Posted by smitty10101 View Post
Hmmmmmm!!!
I think you are right. The mini ones seem to hold fine, it is the large ones like the Irwins that don't hold good, and pinch your hands, good eye.
jj777746 likes this.
post #9 of 30 (permalink) Old 09-04-2018, 11:35 AM Thread Starter
Haven't got it hooked up yet, so don't know how well it works. Might have to seal off some holes. I will pick up some fittings and flex to do a hook up this week.
The last one I made with 1\2" holes didn't do the job.
@stick 486
no hardware cloth
Thanks for all the comments, I will have some things to think about.
post #10 of 30 (permalink) Old 09-04-2018, 02:47 PM
Herb's project is a beauty. I wonder if you could make the box, then use one of the plastic or metal grids that go on flourescent light fixtures. Then have a couple of thin, rectangular masks with rectangular openings to lay over it, leaving openings just a little larger than the item being sanded? You could add a small chamber below the unit to slide in and store the masks out of harm's way. Just thinking.
I really like Stick's idea of, say a 1/4 or 1/3rd inch wire screen below the grid to strengthen it and catch dropped small parts. I'd also use very light weight materials wherever possible so I didn't get a hernia every time I hauled it out for use.
I think I'd put some very smooth material on the slanted boards to keep sawdust from hanging up on tiny rough spots.
Long Board Box Joints Help. Have Incra LS Super System Psychbiker Table-mounted Routing 4 09-03-2014 10:52 AM
simple router table - attach vacuum hose to router box, or use Bosch dust adapter? achoox4 Table-mounted Routing 7 07-07-2014 04:01 AM
A DIFFERENT ROUTER LATHE or “A ROUTER STANDARDIZER” neville9999 Jigs and Fixtures 8 01-04-2013 12:48 PM
box corner joinery almost there Jigs and Fixtures 17 10-15-2012 08:08 AM
Beall Tilt Box Versus Wixey Angle Gauge bennybbc Tool Reviews 4 02-04-2010 12:01 PM
