Completed Table Overhead Dust Collection - Router Forums
 4Likes
  • 1 Post By Stoneface
  • 3 Post By Stoneface
post #1 of 5 (permalink) Old 09-25-2018, 10:50 AM Thread Starter
Stoneface's Avatar
First Name: Frank
Default Completed Table Overhead Dust Collection
I have had under the table saw dust collection for years using a Penn State DC-250 dust collector. Under the saw I used Rockler's Table Top Dust Hood, item number 26412, mounted under the saw in the cabinet. A 4" hose is connected at the back of the saw. See the first two pictures. The other picture show the above saw collection system which is found in a you tube video by Jim Jackson. I purchased the Rockler Universal Dust Collecting Port, item number 63508. I found that the amount of air moving at the dust collection hood was lacking. I stuck my hand up the hood and found that I have ample air movement, so my first solution was to add a this wall 4" plastic pipe in the center of the hood. It worked, but my visibility was reduced, so I thought that I would just eliminate the hood. You can see this in the pictures. It worked as I wanted and my visibility is better and a lot of the overhead sawdust is being collected.
Frank
TenGees likes this.
Frank
Stoneface is online now
post #2 of 5 (permalink) Old 09-25-2018, 12:36 PM
What a difference collection above the blade makes, eh? I popped for a Shark Guard and added a 4"/2 1/2" splitter so I now have both above the blade and below the blade removal as well. The over arm method you're using makes a lot of sense and is a really good option to keep cost moderate. I have an over-arm type collector sitting in a box that one of these days I'll likely sell.
Any collection device must stop the swarf that comes over the top of the blade. Not always so easy since it's coming out at close to 100 mph. Not much time for the air flow to catch them. The Shark guard stops these with an angled lucite block that reaches almost to the table or workpiece. Even then, a little bit of sawdust still gets away. Can you drop your collector down to just above the table or workpiece, or is the height fixed?
post #3 of 5 (permalink) Old 09-25-2018, 02:17 PM
I'm looking at doing something to mine to catch what's getting thrown in my face. My original concept was similar to yours except I was going to hang it from four hooks in the ceiling and on chains which would allow some movement and height adjustment then I though I might be better with an overarm type. I would be interested to hear a full review of your effort Frank with what you find to be the pros and cons.
post #4 of 5 (permalink) Old 09-26-2018, 07:49 AM
sreilly's Avatar
First Name: Steve
The Sawstop system works well [I]except[I] when you are taking just barely anything off. Of course there's no pickup when the sled is used either because the overhead isn't installed as it also has the riving knife and guard.
sreilly is online now
post #5 of 5 (permalink) Old 09-26-2018, 08:53 AM Thread Starter
Stoneface's Avatar
First Name: Frank
Tom,
The Rockler bracket allows for up and down movement. It also has a knuckle that allows you to swing up 90 degrees to get out of the way if necessary. The track on the ceiling allows me to move the table saw forward if I am ripping longer lengths. With the track, I can move the hood over the blade. The only movement not available is side to side. This is generally not a problem.
Steve,
Will post an update as I continue to use it and learn more about how it works.
Frank
Frank
First box joints Debbie Show N' Tell 39 04-10-2018 07:35 PM
Polk ultimate portable workbench roofner Tools and Woodworking 21 06-22-2017 09:09 AM
First time poster, long time reader greasyfingers New Member Introductions 17 06-03-2017 05:42 PM
Above The Table Dust Collection JIMMIEM Table-mounted Routing 16 03-31-2017 11:53 AM
can you lift the router+plate above the table if you use a dust collection adapter? achoox4 Table-mounted Routing 3 11-27-2014 08:41 PM
