Shop Vac Cyclone - Router Forums
 20Likes
post #1 of 14 (permalink) Old 12-10-2018, 07:41 AM Thread Starter
Jeff Speedster929's Avatar
First Name: Jeff
Default Shop Vac Cyclone
Finally added a cyclone separator to my Shop vac.. I wanted something simple but sleek so I made a new lower plate for it and got rid of the straight axle and plastic wheel mounts. I cut a circle from MDF and mounted it in the recess under the can and the lower plate is 3/4" MDF sandwiched between 20ga laser cut plates and the bucket plate is laser cut and screwed to a backer board. You don't need the metal plates but I have access to a laser so took advantage of it. Added some larger casters and connected the old 8' hose and the left over 5' pc together and now can reach most of the shop. I use a remote to turn it on and off....
kp91, difalkner, MEBCWD and 3 others like this.
Jeff Speedster929 is offline
post #2 of 14 (permalink) Old 12-10-2018, 08:14 AM
Gotta look good when sucking up dust!!! Nice set up.
Love those things - just got to remember to empty the bucket before it gets full.
Herb Stoops likes this.
HJ
Detroit Burbs
RoutervilleUSA on Etsy
honesttjohn is online now
post #3 of 14 (permalink) Old 12-10-2018, 05:35 PM
CharleyL's Avatar
First Name: Charley
Dust Deputy's work great, don't they.
I have one on a larger re-purposed whole house central vacuum unit in my shop with the pipes run through the shop walls and ceiling, but I had to go with a 20 gallon metal barrel because the vacuum level was so great that it was collapsing the plastic buckets. As a temporary fix, I stacked 3 of the same style bucket together, equaling 3X the wall thickness of the top bucket to eliminate the collapsing until my son found me the metal barrel. I use this vacuum system for all of my lower dust producers, like scroll saws, drill presses, sanders, and hand held tools.
Your setup looks much more compact than other designs that I've seen. I hated my plastic shop vac, mostly because it was so light and tipped over easily. With a metal vac and real casters, your system should be much more stable than what I had. After getting my central vac and Dust Deputy installed, I gave my son my shop vac.
Charley
Central North Carolina
CharleyL is offline
post #4 of 14 (permalink) Old 12-10-2018, 07:55 PM
MoHawk's Avatar
First Name: Bob
Nice clean, easy to move & compact setup. Great work! I wouldn't be without a Dust Deputy.
dirt_dobber likes this.
Bob aka MoHawk & Gigawatt
CNCRP Pro4824, Aspire 10, Mach4, VistaCNC M1 Pendant
MoHawk is offline
post #5 of 14 (permalink) Old 12-10-2018, 08:09 PM
hawkeye10's Avatar
First Name: Don
Jeff, you did a good job building your dust collector. I think you would enjoy a more flexible hose.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 14 (permalink) Old 12-11-2018, 08:24 AM
Stoneface's Avatar
First Name: Frank
Jeff,
I like the job you did to make your dust collector. I have attached photos of the cart that I made to keep the dust deputy and the vacuum together and on casters to make mobile.
Frank
Frank
Stoneface is offline
post #7 of 14 (permalink) Old 12-11-2018, 12:07 PM
Nice, neat job Jeff.
post #8 of 14 (permalink) Old 12-13-2018, 07:42 AM
First Name: ben
Here are plans for something similar to what Frank built. I adapted the plans for my shop vac. It is best to already have the shop vac before building the cart so you can make appropriate modifications.
Name:	final shop vac cart.jpg
bfblack is offline
post #9 of 14 (permalink) Old 12-13-2018, 10:19 AM
Pro4824's Avatar
First Name: Joe
I don't think JET would consider these "appropriate modifications" but it works much better and much easier to empty than their version. 🙂
The garbage can sits on a spring loaded platform so you just step on it and slide the can out. Works great!!
MEBCWD and CharlesWebster like this.
Pro4824 is offline
post #10 of 14 (permalink) Old 12-13-2018, 01:00 PM
I really like all the carts shown so far. Keeping the size down can be a big deal in a small shop.
DesertRatTom is online now
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Group Cyclone Dust Collector Build schnewj Project Plans and How To 99 08-23-2015 09:27 PM
Shop Vac lam23m Tools and Woodworking 17 02-27-2010 09:44 AM
Shop Vac Water Filter Soapdish Tools and Woodworking 15 01-25-2010 12:22 PM
Shop Vac hose mystery? Birch Tools and Woodworking 3 03-13-2009 03:26 PM
shop vac air cleaner eddyjs62 Tools and Woodworking 4 01-06-2008 08:24 PM
