Remote Switch for Shop Vac - Need sugestions - Page 2 - Router Forums
 44Likes
post #11 of 40 (permalink) Old 02-23-2019, 06:25 PM
Nickp's Avatar
First Name: Nick
Originally Posted by Herb Stoops View Post
I use the same beside my bed to turn off the air compressor in the shop if I hear it start up when I jump into bed.
I also have a remote switch on the DC to start it and shut it down when I go to use any tool. The remote hangs on my apron. Also there are 3 low voltage wall switches on the shop walls in case I forget the remote.
Go Harbor Freight.
Okay, Herb...just a quick clarification...you don't wear your apron to bed, do you...?
Nick
Nickp is online now
post #12 of 40 (permalink) Old 02-23-2019, 07:59 PM
Originally Posted by RainMan 2.0 View Post
I went full retard and and bought this system . I had to build a contactor because it wouldn’t accept the in rush current .
But I’m sure loving it , as I’d forget to turn the fan on otherwise.
iVAC Pro Dust Collection Control System - Lee Valley Tools
That is a neat system, Rick. The one I have on the Cyclone DC is connected somehow to the magswitch on the fan motor. the magswitch is 110v. and the motor is 220v. The mag switch is powered by the shop lights and if the lights are not on it will not start the DC. this is a safety mode installed by the electrician so that the DC would not start if I wasn't in the shop and had the lights on, the remote is on a 12v. wall wart that trips the magswitch. The electrician said he had hears of cases where the DC's would start when no one was in the shop.
@Nickp HAHA, no, I have the push button switch by my bed, it only controls my compressor and bedroom light, the DC remote is on my vest.
My shop is on the other side of the bedroom wall and I got tired of getting in bed and then the compressor starts and I would have to get up dress and go outside to the shop to shut off the compressor.
Nickp, RainMan 2.0 and jj777746 like this.
Herb Stoops is offline
post #13 of 40 (permalink) Old 02-23-2019, 08:01 PM
kp91's Avatar
First Name: Doug
kp91 is online now
post #14 of 40 (permalink) Old 02-23-2019, 08:07 PM
RainMan 2.0's Avatar
That’s interesting Herb. I don’t think it’s happened,but hey , I may not have been in the shop if it did.
I may have to install an outlet from the light switch to make a series circuit just in case .
Good to know.
See it’s a good thing I haven’t insulated and put the plywood up yet
Ok ,I never insulate
RainMan 2.0 is online now
post #15 of 40 (permalink) Old 02-23-2019, 08:10 PM
Originally Posted by kp91 View Post
But your smart, I don't know the difference between a volt and an amp. That looks very professional Doug.
kp91 likes this.
post #16 of 40 (permalink) Old 02-23-2019, 08:46 PM
Originally Posted by OCEdesigns View Post
https://www.amazon.com/Century-Wirel...gateway&sr=8-1
Like this? I was looking at these the other day.
That's what I use with a remote at the table saw, router table, and miter saw. I burned up a couple because the startup current of the HF dust collector exceeded 60A! After the 2nd one burned up from the surge, I rewired the 120V side with real wire instead of printed circuit conductors, and all is well.
OCEdesigns likes this.
<Chas>
I'll burn that bridge when I come to it
CharlesWebster is offline
post #17 of 40 (permalink) Old 02-24-2019, 12:03 AM
Fastcap has one. Sorry, but canít post link yet.
Jerry
Sent from my iPad using Tapatalk
Jerry8888 is offline
post #18 of 40 (permalink) Old 02-24-2019, 12:12 AM
Welcome to the forum Jerry
post #19 of 40 (permalink) Old 02-24-2019, 09:15 AM
chessnut2's Avatar
Originally Posted by difalkner View Post
HF has a 3 set remote control with wireless 3 button switch, about $20. I use it for turning on the HF DC, shop vac, and exhaust fan for the window. Seems like I hooked these up about two years ago.
David
I'm glad you mentioned this, David. I've seen those, but wondered if they were heavy enough to handle the startup amps for the HF dust collector. I have the 1 hp model, so if it's working ok for you, it should do fine for me. Thanks.
sgcz75b likes this.
chessnut2 is offline
post #20 of 40 (permalink) Old 02-24-2019, 10:15 AM
First Name: Ray
I have been using wireless remotes purchased either at a Big Box or Amazon for many years. When shopping for the remotes, look for their current rating. I purchased only the ones that can handle 15A and I have never had an issue with either my 6.5 HP or 5 HP Dewalt vacs. The remotes have never failed.
I have however made a new change that I like even more - I am now using Amazon Alexa to control parts of my shop including the two vacs mentioned above. We use a Dot and an Echo in our home and use Alexa to control lights, ceiling fans etc. So I simply purchased a new Dot for my shop along with a couple of their "Smart" plugs (rated at 15A) and added them to Alexa's repertoire of devices. Now, I simply say "Alexa, turn on vacuum 1" and she carries out my command. Even with the loud vacuum going on she can hear me say "Alexa, shut off vacuum 1." She also keeps me company by playing my favorite tunes. And we use our Alexa system as a whole-house intercom system.
rayk2 is offline
Dust collector stop/go remote switch jj777746 Project Plans and How To 36 05-24-2018 09:46 AM
Bosch 1617 switch repair reikimaster General Routing 37 06-18-2017 09:33 PM
Dust collector remote DIY option Bikeworks Tools and Woodworking 22 02-17-2017 07:43 PM
Problem with NVR switch wiring tyro General Routing 10 04-15-2016 01:48 AM
Table mounting questions for a Craftsman router. tdsapp Table-mounted Routing 25 12-17-2009 08:58 PM
