Remote Switch for Shop Vac - Need sugestions - Router Forums
 44Likes
post #1 of 40 (permalink) Old 02-23-2019, 11:11 AM Thread Starter
sgcz75b's Avatar
First Name: Steve
Default Remote Switch for Shop Vac - Need sugestions
I'm looking for a remote-controlled outlet that I can use to plug in my shop vac dust collection unit.
There seems to be several such outlets on the market, but has anyone had experience with them?
For now, it makes more sense for my working conditions to have such a unit rather than an automatic switch at the tool.
Thanks for any help.
Steve
Danman1957 likes this.
"What can be asserted without proof can be dismissed without proof." Christopher Hitchens
sgcz75b is offline
post #2 of 40 (permalink) Old 02-23-2019, 11:44 AM
Do you just need a switch that turns it on for one tool such as your RT or do you need something with a remote control you keep in a pocket that turns it on for DC to a bunch of machines? Ivac makes a few different switches that will turn on a vac when you fire up a router.
post #3 of 40 (permalink) Old 02-23-2019, 12:14 PM Thread Starter
sgcz75b's Avatar
First Name: Steve
I need it to just turn on the shop vac. That way whether I'm dust collecting from a router, table saw, band saw, or drill press I can start the vac before using the tool. I setup DC at each tool as I use it.
Now I walk over to the vac switch, turn it on, then walk back to the tool, cut, route, or drill, then walk back to the vac to turn it off.
This would help me stay at the tool and remotely turn the vac on and off.
Thanks.
Steve
sgcz75b is offline
post #4 of 40 (permalink) Old 02-23-2019, 12:50 PM
difalkner's Avatar
First Name: David
HF has a 3 set remote control with wireless 3 button switch, about $20. I use it for turning on the HF DC, shop vac, and exhaust fan for the window. Seems like I hooked these up about two years ago.
David
sgcz75b likes this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #5 of 40 (permalink) Old 02-23-2019, 12:58 PM
David
I use the same beside my bed to turn off the air compressor in the shop if I hear it start up when I jump into bed.
I also have a remote switch on the DC to start it and shut it down when I go to use any tool. The remote hangs on my apron. Also there are 3 low voltage wall switches on the shop walls in case I forget the remote.
Go Harbor Freight.
difalkner, Nickp and sgcz75b like this.
Herb Stoops is online now
post #6 of 40 (permalink) Old 02-23-2019, 01:07 PM
OCEdesigns's Avatar
First Name: Chad
https://www.amazon.com/Century-Wirel...gateway&sr=8-1
Like this? I was looking at these the other day.
CNC Shark HD4 Extended. Water cooled Spindle. VCarve Pro 10
Maker of many chips!
OCEdesigns is offline
post #7 of 40 (permalink) Old 02-23-2019, 01:40 PM
difalkner's Avatar
First Name: David
Yes, but the HF remote is far simpler. It only has 3 buttons. Push once to turn on, once to turn off. Right in my wheelhouse! LOL!
David
roxanne562001 and OCEdesigns like this.
David
Romans 3:23
post #8 of 40 (permalink) Old 02-23-2019, 01:57 PM Thread Starter
sgcz75b's Avatar
First Name: Steve
Thanks for the response. At first search, I found those outlets that automatically turn on the vac when you start the tool and the price for most of them ranged from 75-100.00.
I was thinking that a simple remote operated unit would be cheaper, but I had no idea just how cheap
Sometimes I don't know what I think I know!
Thanks again.
Steve
sgcz75b is offline
post #9 of 40 (permalink) Old 02-23-2019, 04:58 PM
vchiarelli's Avatar
First Name: Vince
I use the same remote switches that David has - bought at Harbor Freight for $20 - have one plugged into my dust collector, air cleaner and shop vac - has worked flawlessly
sgcz75b likes this.
vchiarelli is offline
post #10 of 40 (permalink) Old 02-23-2019, 05:13 PM
RainMan 2.0's Avatar
I went full retard and and bought this system . I had to build a contactor because it wouldn’t accept the in rush current .
But I’m sure loving it , as I’d forget to turn the fan on otherwise.
iVAC Pro Dust Collection Control System - Lee Valley Tools
coxhaus, jj777746 and sgcz75b like this.
Ok ,I never insulate
RainMan 2.0 is online now
Dust collector stop/go remote switch jj777746 Project Plans and How To 36 05-24-2018 08:46 AM
Bosch 1617 switch repair reikimaster General Routing 37 06-18-2017 08:33 PM
Dust collector remote DIY option Bikeworks Tools and Woodworking 22 02-17-2017 06:43 PM
Problem with NVR switch wiring tyro General Routing 10 04-15-2016 12:48 AM
Table mounting questions for a Craftsman router. tdsapp Table-mounted Routing 25 12-17-2009 07:58 PM
