Dust Collector Design - Router Forums
 18Likes
post #1 of 43 (permalink) Old 05-20-2019, 08:19 PM Thread Starter
chuckgray's Avatar
First Name: Chuck
Default Dust Collector Design
I haven't been here lately for a number of reasons, most recently I've been going through the hassles of selling my home in TN and buying a new one in Alabama.. The things we do just to be near our grand kids. I am getting a big benefit from the move which has me pretty excited. I will have a large basement located on grade level with one end open to the outside through sliding glass doors. Easy access and a lot of outside light.
But to get to my point, I want to install a dust collector system. This is all very new to me and I'm not sure what I'm planning will work properly. I read the previous posts on this on Routerforums as well as watched a number of videos on YT. See my sketch below. I believe it's fairly typical for the most part. My plan is to use a Harbor-Freight DC along with a Dust Deputy. I also plan on upgrading the DC with a Wynn filter. One of my concerns is the use of 2-1/2" flex hose.
1) Will the 2-1/2" hose be adequate for its intended purpose? The ports on the equipment are 2-1/2" thus the use of 2-1/2" hose.
2) Does anyone else run 2-1/2" hose to their equipment?
3) Would I be better off using 4" flex hose and then reducing down to 2-1/2" at the equipment. Would it make much difference?
4) Any suggestions on what to use to ensure a good seal on the connection of the trash can lid to the trash can?
I'm only showing 4 equipment hook-ups, but will probably add more; one for my miter saw and another for the Rigid oscillating sander.
Any comments, either design or installation, will be greatly appreciated.
Name:	DC System.jpg
chuckgray is offline
post #2 of 43 (permalink) Old 05-20-2019, 08:47 PM
welcome back Chuck...
here's some material to study on...
every question you have and more will be answered..
there is a lot more if you need it...
File Type: pdf Design and Build your own dust collection system.pdf (124.2 KB, 46 views)
File Type: pdf Air Volume at Different Velocities and Duct Sizes.pdf (273.5 KB, 35 views)
File Type: pdf Dust Collection System Design 10 April 09.pdf (274.6 KB, 43 views)
post #3 of 43 (permalink) Old 05-20-2019, 09:01 PM Thread Starter
chuckgray's Avatar
First Name: Chuck
Stick, you never cease to amaze me with the magnitude of information you have. The Library of Congress would be jealous of your collection. Thanks a lot for the info.
papasombre likes this.
post #4 of 43 (permalink) Old 05-20-2019, 10:25 PM
When you are using the 2 1/2” lines you might find it more efficient if you can open up the end of the main tube a bit. Particles are floated on an air stream and the smaller hose starves the main pipe for air volume. The 4” pipe will carry 2.5 times as much air volume as the 2.5 inch pipe will. (Radius of the large pipe squared/ radius of the small pipe squared)
Where in Alabama are you moving?!
MEBCWD likes this.
post #5 of 43 (permalink) Old 05-20-2019, 11:22 PM Thread Starter
chuckgray's Avatar
First Name: Chuck
Thanks for the tips Charles! Hoover, just south of Birmingham.
post #6 of 43 (permalink) Old 05-20-2019, 11:57 PM
I have a similar setup, but decided to get the 5 inch model of the Super Dust Deputy. The problem may be with making the adapters fit, so I suggest you order their metal connectors. The Wynn filter is what I have and it dramatically reduced the fines released into the shop. However, I suggest you check out the Grizzly filter, which has an internal beater arm to knock sawdust down into the collector bag. With the Wynn, you use compressed air to blast from the outside to dislodge the sawdust that eventually clogs the filter.
The Super Dust Deputy SDD, is about $170, more than the 2.5 inch model, but you won't have the problem of the drastically reduced air flow. A 4 inch circle is almost 29 square inches of area, a 2.5 inch circle's area is about 18 square inches. A sizeable difference.
I moved my HF unit out of the shop and into a covered space between my shop and another shed. I am slowly enclosing that space with doors on the end for access, after Stick suggested returning the AC and heated air to the shop after filtration. It is taking me some time to get this done because I tire easily these days. I will install additional filters over the return opening to make sure that air is clean.
I found fiber drums at ULine, online. I have two DC setups, one in the shop, the other in the garage, each has a 30 gallon fiber drum for chip collection. The price has gone up on these, but they are really nice.
The 4 inch Super Dust Deputy comes with a 15 gallon drum, which is just too smal. You can't buy the SDD 4 inch without the drum.
I have several friends living in Alabama. I just don't like the idea of the sweaty summers and hurricanes and twisters. I'll stick with the earthquakes out West.
post #7 of 43 (permalink) Old 05-21-2019, 01:28 AM Thread Starter
chuckgray's Avatar
First Name: Chuck
Thanks for your help Tom. I think I'll go with the Super Dust Deputy and 30 gal fiber drum as you suggested.
I'm kinda getting used to the sweaty summers. I don't believe I'll ever get used to the twisters. I dislike them more than hurricanes.
MEBCWD likes this.
post #8 of 43 (permalink) Old 05-21-2019, 06:18 AM
I still contend that the HF unit is a poor value/investment inadequate money pit when compared to so many better more reliable ready to use units that need nothing...
you can upgrade to 6'' units w/canister and separator included for all that not much more money than a HF reworked unit...
http://www.grizzly.com/dust-collectors
http://www.rockler.com/dust-collection/dust-collectors\
https://www.routerforums.com/tools-w...ale-cheap.html
https://www.routerforums.com/new-mem...ml#post2014547
post #9 of 43 (permalink) Old 05-21-2019, 07:21 AM
My brother lives just north of Columbiana so shouldn’t be too far from you.
post #10 of 43 (permalink) Old 05-21-2019, 08:42 AM Thread Starter
chuckgray's Avatar
First Name: Chuck
Stick, I checked out the links for the DC's and they are less expensive than I thought, but still somewhat outside of my budget. I'll just have to see what I can do. For my clarification though, are you saying the $396 1-1/2 hp Grizzly will perform better than the ~$200 2 hp Harbor Freight? Big price difference.
DW 735 Dust Collection rrrun Shop Safety 9 06-25-2018 08:09 AM
Dust boxes effectiveness revisited barri Table-mounted Routing 56 11-18-2017 02:10 AM
Small shop dust collection Barry747 Shop Safety 4 10-12-2015 11:04 AM
Index of Dust Collection Solutions and Comments allthunbs Shop Safety 28 03-14-2014 01:40 AM
My Dust Collection System MAFoElffen Tools and Woodworking 19 05-23-2013 03:39 PM
