Dust collection - Router Forums
 15Likes
  • 3 Post By qulevrius
  • 2 Post By Stick486
  • 5 Post By Cherryville Chuck
  • 2 Post By difalkner
  • 1 Post By qulevrius
post #1 of 7 (permalink) Old 07-02-2019, 01:44 AM Thread Starter
First Name: Dennis
Default Dust collection
Finished tuning up a Cyclone unit today:
Works just as well as the Dust Deputy, for a 1/3 of a price. Did require some hands-on though. Also, by sheer luck, my Stanley vac hose fits in perfectly. The triple gasket prevents any loss of suction, I’m quite happy with the result.
Now, for the questions:
What do you gents and ladies recommend for hoses ? Diameter, adjustments, material, manufacturer ? I plan on installing a series of T or Y connectors with blast gates, for at least 4-5 ends.
Sent from my iPad using Tapatalk
qulevrius is offline
post #2 of 7 (permalink) Old 07-02-2019, 01:58 AM
you don't want T's or elbows.. Wye's and sweeps instead..
File Type: pdf Fundamentals of Workshop Dust Collection.pdf (44.5 KB, 18 views)
File Type: pdf Installing your air handling system.pdf (281.8 KB, 26 views)
kalopsia and qulevrius like this.
post #3 of 7 (permalink) Old 07-02-2019, 02:16 AM
I used flex hose from Lee Valley to get from the machines to 4" galvanized ducting that are the main runs. The metal ducting is cheaper, smoother, and allowed me to ground them more easily.
JFPNCM, TenGees, Nickp and 2 others like this.
post #4 of 7 (permalink) Old 07-02-2019, 02:36 AM
the LV hose is some upper class hose... good stuff..
I did the same as you excluding the sizes..
I also used saddles instead of fittings...
this allowed me to put a tap exactly where I wanted/needed a take off and I used longer sticks of pipe resulting in fewer joints which the longer sections reduced cost......
the saddles made for way easier changes and lowered the fitting count drastically...
also, I put the trunk line close to the floor...
this made for a way shorter runs which used less material which saved quite a bit of money as in a lot...
and the efficiency of the DC improved markedly...
some reading... https://www.routerforums.com/feature...tml#post697514
JFPNCM and Nickp like this.
post #5 of 7 (permalink) Old 07-02-2019, 09:05 AM
difalkner's Avatar
First Name: David
Am I missing something or is this gasket supposed to go under the flange?
Name:  Cyclone gasket - cropped.jpg
David
TenGees and Nickp like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #6 of 7 (permalink) Old 07-02-2019, 10:38 AM Thread Starter
First Name: Dennis
Attachment 371191
David
I put 3 gaskets there. 1 between the flange and the throat, 1 between the flange and the lid and the last one between the supporting plate and the lid. No loss of suction whatsoever.
Sent from my iPhone using Tapatalk
OCEdesigns likes this.
post #7 of 7 (permalink) Old 07-13-2019, 06:57 AM
This is really a nice idea.
Jontaylor is offline
