dust collection for a small shop - Page 5 - Router Forums
 28Likes
post #41 of 48 (permalink) Old 09-24-2019, 02:33 PM Thread Starter
HWK290's Avatar
First Name: Jeff
I cleaned up my table saw. It is full of small openings! I thought I might plug them with either the silver tape used in duct work or some sort of caulk. For the bigger ones I thought I would make cover plates out of aluminum. I thought this might increase the suction. Otherwise, the sawdust either falls down and eventually gets sucked up, or still gets thrown off the saw. It's not as bad with the DC running, but not by much.
Anyone ever do this (plug the holes to increase suction)? Does it work?
HWK290 is offline
post #42 of 48 (permalink) Old 09-24-2019, 06:43 PM
Bob Adams's Avatar
First Name: Bob
A couple of years ago I went through my table saw and plugged the gaps where the base met the top, put a magnetic sheet over the blade tilt slot, put in a sloping floor, drilled 3 more holes in the access door. Last June I had to take the saw apart to fix an arbor problem, and could not believe the amount of accumulated sawdust! Without a monster DC I think it is a waste of time.
DesertRatTom likes this.
Bob Adams is offline
post #43 of 48 (permalink) Old 09-24-2019, 11:15 PM
you actually want a lot of those vent holes...
DesertRatTom and Sominus like this.
Stick486 is offline
post #44 of 48 (permalink) Old 09-25-2019, 12:15 AM
More air flow means less sawdust sticks around. Also use dry lube to help keep it from sticking so badly.
post #45 of 48 (permalink) Old 09-30-2019, 10:52 PM Thread Starter
HWK290's Avatar
First Name: Jeff
I have a DC that I can hook up to the table saw. I thought sealing it up would increase flow at the throat plate. Right now, it draws air from all the holes. Seems like it needs to be sealed up to just draw air (and sawdust) from where the cutting happens.
Why? Seems like the opening where the blade angle adjuster is (it's harder to seal up, so I thought I'd leave it) would let in enough air.
HWK290 is offline
post #46 of 48 (permalink) Old 09-30-2019, 11:25 PM
closing up the holes restricts/cuts down the air flow (FPM)...
air flow is what you want...
if your DC is doing a poor job of removing sawdust; you have inadequate airflow...
JFPNCM and DesertRatTom like this.
Stick486 is offline
post #47 of 48 (permalink) Old 11-25-2019, 11:57 AM Thread Starter
HWK290's Avatar
First Name: Jeff
So I looked at getting a Wynn filter. It states I should get a 17.5" diameter one, even though my DC has a 15" OD. Did I miss something? I made sure I answered the questions about size correctly, by the way!
Also, what else do I need? I couldn't download the instructions to see how it's installed.
I currently have the DC hooked up to my table saw. Works fairly well; I get a little dust on the saw, but there doesn't seem to be much dust settling on anything a day or so later. I use my router outside and wear a dust mask.
I have a Leigh dovetail jig. I was thinking of getting the Leigh attachment that sucks up dust, but thought it might impede my vision. People seem to like it, though. Anyone have this jig with the dust collection attachment? Does it impede vision at all?
HWK290 is offline
post #48 of 48 (permalink) Old 02-02-2020, 11:48 AM
I have also the same problem regarding dust and suffering from cough.
Frank Kerman is offline
