can DC be used inside with Wynn filters? - Router Forums
 2Likes
  • 1 Post By difalkner
  • 1 Post By JFPNCM
post #1 of 6 (permalink) Old 10-11-2019, 07:19 PM Thread Starter
HWK290's Avatar
First Name: Jeff
Default can DC be used inside with Wynn filters?
Could someone confirm for me that the Wynn filters that go on the single stage dust collectors (https://wynnenv.com/products-page/wo...ilter-pricing/) allow the DC to be run inside and that no dust will get vented into the room?
I thought I would set up my DC to my table saw in the garage rather than having to wheel it outside.
HWK290 is offline
post #2 of 6 (permalink) Old 10-11-2019, 10:26 PM
difalkner's Avatar
First Name: David
We use ours inside our two-car garage, Jeff, with virtually no dust around the unit. When we had the 5 micron bag filter I had to clean the mini-split filters at least once and sometimes twice each week and I had to keep the door closed to the house (attached garage). Now I clean the filters to the mini-split every 3-4 weeks and the door to the house stays open.
David
JFPNCM likes this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #3 of 6 (permalink) Old 10-11-2019, 10:39 PM
yes...
when you clean your filter don't clean ''clean'' it ..
make it catch finer dust..
also...
the filter HAS to fit...
post #4 of 6 (permalink) Old 10-11-2019, 10:52 PM
To get the best results, you should use a chip separator before the DC unit. After that, almost nothing gets all the way to the filter and really, nothing gets into your shop air. Rockler makes the chip collector fittings in the picture. It really does a nice job, although the Super Dust Deputy is even more effective, but it costs more. The fiber drum in the picture is from ULine, but you could use a trash can, but it really has to seal well. I cut the holes in the metal top with a metal cutting blade in a jig saw. The fiber drum has a locking lit, but a metal trash can will need some sealing up to stop the leaks. Pictures won't load, will post them in the next post...
post #5 of 6 (permalink) Old 10-11-2019, 11:05 PM
OK, lthe pictures just won't load. Here are links instead. The Rockler setup is a kit of the plastic fittings and the flex hose, which is separate. Do not try to mix different brands of hose and fittings. 4 inches is NOT 4 inches, every brand is different, not interchangeable. I have two units, my garage unit still has the bag, but I can roll it outside until I can get another drum filter. As stick mentioned, don't over clean the filter.
https://www.oneida-air.com/dust-depu...xe-cyclone-kit
https://www.rockler.com/power-tools/...and-separators. The drum is separate, the hardware is about $30.
post #6 of 6 (permalink) Old 10-12-2019, 05:55 PM
JFPNCM's Avatar
First Name: Jon
Agree with all the points above, particularly adding the chip collector. Could not be more pleased with that combination on my old Delat DC system.
DesertRatTom likes this.
Jon
JFPNCM is offline
