New dust collector not working very well - Router Forums
 8Likes
post #1 of 29 (permalink) Old 03-07-2020, 08:54 PM Thread Starter
Default New dust collector not working very well
Hey guys I just bought a 1250 cfm dust collector and canister filter from Rockler. It sucks great but dust seems to come out of the filter when its on. You can watch the dust in the clear bag strapped at the bottom start swirling and make its way out of the filter. It is not coming out of the bag it's literally through the canister it self. Any thoughts ? Thanks !!
lylesvegas is offline
post #2 of 29 (permalink) Old 03-07-2020, 08:59 PM
welcome to the forums N/A...
what's the make/model of the DC and micron rating of the canister???
post #3 of 29 (permalink) Old 03-07-2020, 09:05 PM
Marco's Avatar
check the Rubber gaskets for a tight seal to your collector?
DesertRatTom likes this.
Galatians 5:13
Marco is online now
post #4 of 29 (permalink) Old 03-07-2020, 09:06 PM Thread Starter
Rockler wall mount dust collector 1250 cfm and 1 micron on the canister
post #5 of 29 (permalink) Old 03-07-2020, 09:58 PM
this is this it???
where does the optional canister mount???
post a picture of your setup..
you can post pictures if the picture is on the hard drive of the computer you are posting from
https://www.rockler.com/rockler-wall...ector-1250-cfm
post #6 of 29 (permalink) Old 03-07-2020, 10:07 PM
this is the usual canister and collection bag set up...
dirt_dobber likes this.
post #7 of 29 (permalink) Old 03-07-2020, 10:11 PM
is this more like your set up???
how new is the unit???
what size input lines do you have installed???
are you using the 30 micron collection bag or a clear plastic one???
post #8 of 29 (permalink) Old 03-08-2020, 12:03 AM
This machine has no separate filter the bag catches the chips and the bag is the filter. If there is leakage it will be through the bag, or the hose clamp at the top.
I would put the Dust Devil and dust bin between the fan and the filter .
HErb
Name:	Dust Right 2.png
Name:	Dust Right 1.png
Name:	Dust Right3.png
Herb Stoops is online now
post #9 of 29 (permalink) Old 03-08-2020, 08:08 AM
First Name: rob
Could I have subscribed to this thread without posting on it? I had never seen this dust collector set up though it is similar to my portable delta and holtz-her units that have a ''dust bag''
Rob
tooler2 is offline
post #10 of 29 (permalink) Old 03-08-2020, 08:48 AM
sreilly's Avatar
First Name: Steve
Lyle (just guessing at the name) if you are referring to a cloth bag as the filter then you should know that these bags are rated to a certain micron size. Some as large as 5-7 microns which won't stop fine sawdust at all, chips yes but not so much the finer particles. Cut something like MDF and you'll have plenty of dust floating in the shop. Check the rating of the bag/filter. My CV1800 is rated to .5 micron and captures almost all of the sawdust. Filter Efficiency: 99.999% at .5 micron (MERV 15)
sreilly is offline
