A Dust Collection Story - Router Forums
 39Likes
post #1 of 22 (permalink) Old 05-30-2020, 10:37 AM Thread Starter
First Name: Michael
Default A Dust Collection Story
Years ago I purchased a Jet DC1100 from my brother when he moved. It sat unused in storage while my hobby was inactive. A year or so ago I decided it was time to get it out of storage and put it to use after having completing multiple projects, creating lots of dust and doing loads of cleanup. The cleanup was getting old....again.
Honestly, I did not truly expect what I experienced. What I was Not Expecting was more overall dust throughout the shop (in fact the whole building), plus daily sinus, respiratory and throat irritations. What I Was Expecting was less cleanup in the shop. I got that!
I am familiar with all the irritations I referenced. I associate them with past days of heavy sanding or heavy miter saw use. On those days I knew to wear some form of dust mask respirator. The difference now was that regardless of what I was doing, when the dust collector was active, it was like a sanding day. Leave it off and no problem.
Fast forward.
The DC1100 I have I believe is one with the 30 micro filter bag, similar to this one. I refer to it as a ‘Chip Collecting Dust Generator’. It became immediately evident that I needed to upgrade the filter.
Since my intent for dust collection has always been installed system rather than portable, I quickly ruled out a direct canister filter replacement for the bag. I wanted external so I could mount it where I wanted, and so that I could reuse the filter when I upgraded to more powerful blower. I opted for a pair of Wynn Environmental 13F230NANO filters.
I knew that I wanted a cyclone separator of some sort. I opted for a Super Dust Deputy XL. I went with the XL over the standard because I know a larger blower is in my future.
I wanted the DC system to occupy little or no floor space in the shop. I knew I would need to install it up high, perhaps even in the loft, if I were going to achieve this.
And finally, before I made a 3HP or greater DC blower purchase, I really wanted to experience just how useful (or ineffective) the existing 1-1/2 HP version would be when hard piped to just a couple of tools. You know, there is nothing like first-hand experience.
With the SDD, filters, and blower in hand, it became my mission to install them. Here is what I came up with.
I removed the blower from the Jet stand and mounted it on a frame within the dead space I have up between the floor joists and rafters as can be seen here. This dead space is high above the bottom of the stairs that lead up to a storage loft.
I mounted the SDD cyclone directly beneath the motor and secured it to a purpose built shelf. Like everyone else, I located a collection can directly beneath the cyclone for chips and dust. I added foam gasket between lid and can. The can ended up being the only thing that occupied floor space.
For the filters, I installed the two flanged filters atop a custom plenum box up in between the joists as well, right near the blower. And as you can see, the filters stand vertical like the Twin Towers. Again, no floor space consumed, but filters easily accessible from the loft.
The bottom of the filter box is itself a box. It is on hinges and is latched in place. It can be opened and dumped as needed. Filters can be cleaned from loft above by rapping on them with the hands or using compressed air like the manufacture says, or, if desired, they can be vacuumed from below using a soft bristle brush attached to the end of a vacuum wand. Filters can be easily removed from above by removing 4 screws. The bottom can be opened when standing on the 3rd step of the stairs.
In its final form, I expect my final DC system will have 6” mains ducting run to major tools in the shop. For now, I opted to use some existing stock of 4” DWV pipe to connect up the table saw and router table so I could get back to work and use it. I just needed to buy some 45s to connect things together.
I purchased and installed an iVac wireless control system with three remotes. One handheld and two current-sensor type. The current-sensor versions were installed on the table saw and router table. The DC now turns on and off automatically. They work so nicely that when I complete my installation, the current sensors will be installed on other fixed position tools.
OK. So how does it work?
I am no longer experiencing the sinus or throat irritation when the DC is running. So I know the filters are doing their job quite well.
The cyclone definitely works. Using a 4” hose connected at the table saw end of the pipe, I completely vacuumed out a 3/4 full trash can of saw dust to see just how well. I was able to empty the can without issues. The pipes did not clog but the filter box ended up with <=1/32” of super fine dust in the bottom. This suggests that the SDD XL is still useful at lower CFMs, just not as good as it would likely be at higher CFMs. I am glad I made the XL decision.
As configured, the DC is collecting all the dust that the table saw and router table throw at it. Saw dust is effectively being extracted from the table saw cabinet and router table dust collection box when only one blast gate is open. Nothing within the airflow path of either remains. I am thrilled with router table DC performance. Down flow DC through the bit opening into box is great. Still need to check DC performance dado glade is being used on TS.
For testing, I disconnected the table saw and added another 20’ of 4” flex to the end of TS pipe and hooked it up to my Delta 12” planer and then ran some 2x4 through it. DC seemed to as effective as it was when I had it hooked up directly to the planer. But I could definitely tell there was not as much air flow as when I previously hooked up directly to portable DC. Maybe collection with wide boards may not be as good.
A larger blower is definitely in my future so I can effectively hard pipe to all stationary tools. But for now I know I am better off than I was before I started the project.
Here are a few photos of the piping.
Sent from my iPad using Tapatalk
mbrun is offline
post #2 of 22 (permalink) Old 05-30-2020, 10:50 AM
excellent execution and write up..
thanks...
post #3 of 22 (permalink) Old 05-30-2020, 11:01 AM
difalkner's Avatar
First Name: David
I agree with Stick, Michael - great job and write-up! That looks like a very well thought out solution. We found the same thing with our 5 micron bag filter on our HF unit - fine dust everywhere around the DC. I switched to the Wynn 0.5 micron filter and now the shop no longer has that fine film of dust.
David
JFPNCM and Herb Stoops like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #4 of 22 (permalink) Old 05-30-2020, 12:52 PM
I had my DC inside the shop, but even with the Wynn filter, it was too dusty. So I moved it outside. Built a sealed chamber between the shop shed and office shed. Made it pretty air tight, put a Super Dust Deputy on a fiber drum and placed that with the HF DC unit inside the chamber. Linoleum on the floor sealed the bottom of the chamber and doors on each end holds air in. I have a little more to do to seal the chamber completely.
Doors on each end can be opened to blow out any stray dust on a windy day.
Rockler makes a connector that's long enought to go through a wall, and a 4 inch hose runs from tool to this connector, and anothe flex hose connects the pipe to the SDD. I shortened the second hose to increase air flow.
Being desert, we have extremes of heat and cold, so this chamber allows me to recirculate conditioned air back into the shop through yet another 20x20 filter. You can see the white, metal filter holder on the wall just back from the Wynn filter on the DC unit. This blows the return past the AC and Heater.
I will be suspending the round lid on the 30 gallon chip collection fiber drum to make it easier to empty the drum, Probably will use bungi cords for that (KISS).
I ran wiring through the wall with an on/off switch to control the DC unit, but can add a remote on/off at any time.
The final item is a WEN hanging dust filter that has a timer and power levels. I can leave the shop and have it run for up to 4 hours unattended. This unit is physically smaller than the Jet unit, but has identical stats and uses the same filters. I paid $99 on sale from Walmart and have a second for my garage. Hang this near a wall to creat a circular air flow.
This system performs very well and now the only sawdust in the shop is from the small amount of uncollected dust from the table saw when I forget to open the blast gate for the over the blade DC Shark. And once in awhile, I just forget to turn on the DC unit. At some point, I hope to build a deck on the front of the shop shed so I can pull the sliding miter outside. That thing is a horrible sawdust producer and I avoid using it as much as possible. A shower curtain surrounds most of the sliding miter saw, and collects into a box with a 4 inch connector on the bottom, but it is not a great solution.
Pix 1 is the interior of the chamber as it sits now.
Pix 2 is the chamber under construction. Nothing was square, so it was a chore getting the doors hung properly.
Pix 3 is the WEN hanging filter box.
Name:	DC setup new shorter.jpg
Geevesmac and dirt_dobber like this.
DesertRatTom is online now
post #5 of 22 (permalink) Old 05-30-2020, 01:08 PM
I also use the 5 micron Winn filters and are very happy with them, The only caution that I have is that winnn recommended not using an air hose nozzle to blow air from the outside to clean the filter, it can blow holes in the filter fabric. I reverse the hose on the shop vac and blow mine out, and hitting it with an old tennis shoe before I open the door. You will be surprised at how much fine dust is trapped in the pleats. Some of the commercial units have a rotating brush inside the filter to clean them. But overall a nice job, well thought out. When you get to stage 3 and install 5"-6" ducting you will be amazed how much more the increase in airflow helps. But for now , this will be quite an improvement from before. Don't expect to choke it down to 1 1/2" to use on a sander or other power tools as the airflow will really be reduced to almost nothing, a vac is better for that with the small DD in line. I found that dust Collection comes in stages I went through 4 before I was happy.
Good job.
HErb
Marco and dirt_dobber like this.
Herb Stoops is online now
post #6 of 22 (permalink) Old 05-30-2020, 01:59 PM
Nickp's Avatar
First Name: Nick
Outstanding installation and the writeup is second to none...Great work...you obviously put a lot of thought into the installation meeting each of your requirements...AWESOME...! ! !
...and, of course, gonna copy some of your install...I really like the SDD going straight into the blower. I'll be looking into that for my Jet 1200VX...Thanks for sharing your work...
...but your shop is way too clean and organized...
Marco, Roy Drake and dirt_dobber like this.
Nick
Nickp is offline
post #7 of 22 (permalink) Old 05-30-2020, 02:27 PM
difalkner's Avatar
First Name: David
Good job.
HErb
Herb, I'm pretty sure you mean 0.5 micron, not 5 micron. And as for cleaning, Wynn DOES recommend using compressed air blown from the outside to clean their filters. That's the way I've been doing it since day one and it works great. Here's their FAQ page - and about 1/2 way down the page you'll see this - Our woodworking filters are cleaned-down from the outside with about 60 PSI of compressed air. Just use your blow-off nozzle.
David
Herb Stoops and dirt_dobber like this.
David
Romans 3:23
post #8 of 22 (permalink) Old 05-30-2020, 03:33 PM
Yes you are right,David, .5 Micron, my error. Thank you for the correction, it has been a long time since I read their FAQ page, years ago they did not recommend Compressed air, not sure they listed a pressure limit then, but your information is good to know. I know they have improved the filters since this first ones I bought 15 years ago that didn't have the mesh screen both inside and out.
HErb
difalkner likes this.
post #9 of 22 (permalink) Old 05-30-2020, 03:40 PM
No wire mesh....
No compressed air....
post #10 of 22 (permalink) Old 05-30-2020, 03:54 PM
No wire mesh....
The first one I bought years ago when the wood workers were first starting to use them instead of the 30 micron bags they came with were for commercial trucks. They were built to take air from the out side and exhaust it through the center. The mesh was on the inside and the outside had bare pleats. So you had to build a box to enclose the filter and have a exhaust hole in the center of the end of the box to exhaust the air out. one side of the box was hinged so that the filter and box could be cleaned. It was a messy job to clean.
