Rockler plastic blast gates - Router Forums
 11Likes
post #1 of 12 (permalink) Old 06-05-2020, 08:04 PM Thread Starter
First Name: jaody
Default Rockler plastic blast gates
Kudos to Rockler. I ordered 4” blast gates on Tuesday, I received them on Friday. Beats other suppliers hands down. Great product
roxanne562001 likes this.
jaody is offline
post #2 of 12 (permalink) Old 06-06-2020, 07:15 AM
Contributor of the Month
Bushwhacker's Avatar
First Name: David
I agree, Rockler is fast on delivery. I ordered some red wood and it arrived in no time.
David
When the enemy is in range, so are you.
Bushwhacker is offline
post #3 of 12 (permalink) Old 06-06-2020, 09:10 AM
Check the Diam, they have a couple different 4".
Just saying,
Herb Stoops is online now
post #4 of 12 (permalink) Old 06-06-2020, 09:42 AM
Actually, Rockler DC stuff fits together really well. ID and OD are very consistent with Rocklers connectors. They are the only woodworking store within driving distance for me. When I bought my table saw from them, they had an employee who worked in their store in Orange county but lived closer to my store, and the guy brought the saw up with him and dropped it at the store. Really like to go watch demos on Saturday mornings, well, at least some of them. In a pinch, they even have decent hardwoods in a pinch. Don't have much experience with other suppliers.
DesertRatTom is online now
post #5 of 12 (permalink) Old 06-06-2020, 12:40 PM
JFPNCM's Avatar
First Name: Jon
Tom's point about consistency of the ID and OD measures on their products is critical. Regrettably, they don't match up with parts from other stores.
The inconsistency across manufacturers defies logic.
Nickp and Herb Stoops like this.
Jon
JFPNCM is offline
post #6 of 12 (permalink) Old 06-06-2020, 04:14 PM
Marco's Avatar
Hey Jaody... keep an eye on the blast gates.. the plastic ones (At Least Mine) tend to hold dust in the gaps and won't let the gate all the way closed.
Herb Stoops likes this.
[B“It’s not a mistake, it’s a design feature”][/B]
Marco is offline
post #7 of 12 (permalink) Old 06-08-2020, 02:39 AM Thread Starter
First Name: jaody
Thanks Marco I will keep an eye on them to make sure they close completely. The reason I went with the plastic gates is I have the metal gates already and they leak around the slide really bad. You can actually hear them rattle at times.
jaody is offline
post #8 of 12 (permalink) Old 06-08-2020, 09:34 AM
I have the ones from Lee Valley and they work well. I guess the message is to stick with one supplier and you should be okay with the fit. The only issues I've had is keeping the hose on the gates which a layer of duct tape on the fitting helps with and I had one come apart because I put too much stress on it but they glue back together with ABS glue.
Keep in mind that if you are going to a reduced size outlet like for a router table that the DC will work better if you open a gate upstream from that outlet. The DC needs at least a 4" opening to have enough air flow to work properly and the air from past the reduced line actually helps suck more air from the smaller one.
JFPNCM, Nickp and Stick486 like this.
post #9 of 12 (permalink) Old 06-08-2020, 07:33 PM
Marco's Avatar
Mine didn't used to.. checked them tonight and one developed a leak at the bottom of the gate... metal heat duct tape stopped it.
Nickp likes this.
Marco is offline
post #10 of 12 (permalink) Old 06-08-2020, 07:35 PM
UHMW tape works great for that too...
Nickp likes this.
