Time to collect some dust... - Page 2 - Router Forums
 19Likes
post #11 of 55 (permalink) Old 09-15-2014, 10:48 PM Thread Starter
Country: Argentina
First Name: Pablo
Stringer, my saw has something like this in the dust exit:
The dust does not fall in the floor, but it is contained inside. When that thing gets filled with dust, the air generated by the blade rotating throws dust to my face , sounds funny but it's not .
I just saw an article about how a cyclone is and the concept behind it, interesting, and it's homemade-able, which is cool.
But, I got a doubt, how powerful my shop vac has to be in order to actually extract dust?, because after I finish cutting MDF it's a mess..
(Also maybe my blade has a little wobble and it has a broad kerf, that probably doesn't help either)
Artemix is offline
post #12 of 55 (permalink) Old 09-15-2014, 11:35 PM
MT Stringer's Avatar
Hopefully, someone with your saw will post up their thoughts. I say some dust collection is better that no dust collection.
In the mean time, rig up a fan to help filter the air you are breathing. Just a simple 20 x 20 inch fan with an air conditioner filter fitted over the inlet side. You will be surprised at the dust that will collect on the filter.
Name:	2014-05-08 14.27.11.jpg
Name:	2014-05-08 14.27.30.jpg
Name:	2014-05-08 14.27.40.jpg
MT Stringer is offline
post #13 of 55 (permalink) Old 09-15-2014, 11:59 PM
Originally Posted by Artemix View Post
So, it's time to take care of all that dust making my *I wont say where I put the saw" uninhabitable.
My saw (DW745) has a little tube that I supposed is used to put there a hose from a vacuum.. but, since I'm totally new to this, I'd like to know if is only that or there is something else I should consider before doing that.
I googled a bit and there are some complex thingies called cyclone, and some woodworkers have also big-flashy-expensive setups to collect dust... wont work for me.
Any help is appreciated!.
these are examples.. these method of hook up seems to work the best...
BTDT w/ the vac.. just too much BS to put up w/...
so hook the 2.5 port to the the Wye.... don't use a T, use a Wye..
stick one these under the saw and hook that to the Wye..
hook the Wye to the at least a 600CFM, 1.5HP DC w/ 2 micron or finer filtration...
Done!!!
post #14 of 55 (permalink) Old 09-16-2014, 05:33 AM
Exclamation dw 745...
I believe this is that saw that N/a is talking about:
Dewalt 10" Compact Jobsite Table SAW DW745 NEW | eBay
For many years I used an old Hitachi small home vacuum cleaner as my main source of dust collection passing through a Triton Dust collection bucket. I still use this system for general dust collection in the 'shed'.
Triton Tools | Saw Table | DCA300 | Dust Collection Bucket 20Ltr
IMHO, a home vac running through a Thien dust cyclone should handle the dust from a saw such as this. The thein can be home made. The only proviso is that the vac should not be run continuously for any length of time. [make sure you unwind the internal cord when in use].
Thien Cyclone Separator - small cheap easy version - DIY - baffle top hat dust-separation work-shop - YouTube
I only had to upgrade when I purchased a jointer and thickness planer.
If you run vac without a separator system, the vac will clog up very quickly.
Sydney, Australia
jw2170 is offline
post #15 of 55 (permalink) Old 09-16-2014, 12:41 PM
MAFoElffen's Avatar
Would be there any problem to just connect the hose of the vacuum to the dust pipe of the saw?.
No and yes.
Hooking your saw to Just a shop vac is better than to nothing at all in that it will collect sawdust. But being a shop vac, they end up in blowing fines all over your shop. (unless you add a pleated or drywall filter. The end effect may be better or worse. So then something better may be needed.
A separator is most useful to separate pieces before an impeller, likr how it is in a DC. Used with a shop vac, it separates more of the fines and can expand the capacity of the collection before you have to empty it.
You could certainly build one, but somethings, it's easier or cheaper just to buy something already finished and working. (Especially if you don't know how they work or how to build one.) A percentage of people want to spent project time on actual projects.
MAFoElffen is offline
post #16 of 55 (permalink) Old 09-16-2014, 01:45 PM Thread Starter
Country: Argentina
First Name: Pablo
Ok, so now I'm beginning to understand things a little bit better, I need a separator (cyclone or thien) to avoid my shop vac to get instantly filled with saw dust, makes sense.
Now, about the fine dust (MDF produces a very fine dust that clouds the air) and the potency of the shop vac, what are my options?, how can I make my vac to suck almost everything?.
Artemix is offline
post #17 of 55 (permalink) Old 09-16-2014, 03:03 PM
As you've already mentioned, there's a big difference (including price) between a shop vac and a dust collector. As your shop grows, you should budget for a DC in the future.
Meanwhile, as previously posted, any dust collection is usually better than none. A shop vac is relatively inexpensive, and you'll always have use for one in your shop, for general clean up, and for use with handheld tools, such as routers and sanders.
Make sure the shop vac has a good filter (preferably HEPA-type), or it will end up blowing a lot of small particle dust back out into your shop (and lungs). BTW, IMO the box fan/furnace filter setup is a mixed blessing. While it does indeed trap a lot of air borne dust, a furnace filter is not fine enough to filter the smallest (and most dangerous) particles, which the fan blows back into the shop air.
From what I can tell, the DW745 dust port is sized for a shop vac hose, so the simplest solution is to connect the shop vac hose directly to the saw. A better solution is to get a Dust Deputy, connected between the vac and the saw. You'd be amazed at how much dust it traps, which will make keeping your shop vac filter clean a lot easier. An alternative to buying a Dust Deputy would be making a Thien separator.
Finally- or first- get a good respirator mask. Wood Whisperer has some good recommendations. Good luck, and keep cutting!
jdonhowe is offline
post #18 of 55 (permalink) Old 09-16-2014, 05:08 PM Thread Starter
Country: Argentina
First Name: Pablo
Alright, to summarize (correct if Im wrong)
1- get a powerful shop vac (something like 2hp)
2- buy/make a Dust Deputy (cyclone) or a Thien separator (simpler cylone?)
3- connect shop vac to the DD/Thien, connect DD/thien to the exit of the saw.
4- profit.
About the respirator mask, I thought about it but it will only be useful as long as I have my air clean, and the only way to achieve that is if my dust collection system works. Otherwise I would have to live with the respirator mask forever!, like in one of those post-apocalypse movies .
Artemix is offline
post #19 of 55 (permalink) Old 09-16-2014, 05:48 PM
4- profit.
I think you got it. About that cheap box fan...I set it on the table saw wing. It is amazing how much dust it captures out of the air. I don't use cheap filters, even though I have to change them more often. I also have a Grizzly air filtration machine hanging over the work bench.
Good luck.
post #20 of 55 (permalink) Old 09-20-2014, 05:59 PM
On vacation
First Name: Charlie
I would imagine that the Owners Manual would say what to hook the saw up too. And since it has got brought up about the port being shop vac size, my guess is it was made to be hooked up to a shop vac. Lets not over think this. I'd also use a separator, I'm a Thien fan and have made several different sizes. I'd also like to mention that dust collection from a shop vac or even a dust collector isn't a guarantee that you will capture every spec of dust, thinking so is just plain unrealistic. But they do generally keep the dust down quite a bit, and cleanup time at the end of the day is reduced.
Woodchuck1957 is offline
Miscellaneous Dust Collection Stuff MT Stringer Show N' Tell 9 12-01-2014 12:54 PM
New to routers (and wood working) P.A. Gosselin New Member Introductions 4 09-02-2014 11:21 AM
Dust Deputy Cyclone Dejure Tool Reviews 3 06-16-2014 09:46 PM
My Dust Collection System MAFoElffen Tools and Woodworking 19 05-23-2013 04:39 PM
Dust control with Dovetail jig 603Country Jigs and Fixtures 6 12-06-2010 02:29 PM
