Any pen turners out there? - Page 2 - Router Forums
 12Likes
post #11 of 17 (permalink) Old 11-20-2016, 09:07 PM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Originally Posted by Semipro View Post
Brian
Harry i believe had a tutorial on finishing pens with super glue.
By the sound of it Brian you aren't using an accelerator after each coat of CA glue. If you watch my video again you'll see that a quick squirt above the rotating pen dries the CA glue instantly.
BrianS and Rogerdodge like this.
Harry
harrysin is offline
post #12 of 17 (permalink) Old 11-21-2016, 02:08 AM
First Name: Bruce
Originally Posted by BrianS View Post
Thanks Bruce. That would probably explain the dull finish then... I'm sure I didn't wait near long enough for each coat to dry. In a video Harrysin posted a while back, he was using an accelerator in a spray can. Would that speed the process up any?
And, since you mentioned seam rippers, what kits have you found to be the best? I purchased the one I did from Woodcraft, and the nylon insert that holds the blade of the ripper in place doesn't seem to tighten up enough. The blade moves in it.
I will keep your process in mind when I turn the next one.
I get all of my pens and seam rippers from either www.pennstateind.com or or www.WoodTurningz.com
The seam ripper I purchase use a sping steel insert to hold the seam ripper in place. I make both the double end and necklace seam rippers. As far as using an accelerator for the CA glue, I have found that it gives me a false sense that the glue is really dry when it's just the very top layer is dry. Puting on the CA medium because of the thickness that is applied it's not truly dry. I learned this last summer to truly get a good finish that patience is your best friend. I ruined a few really nice pens because I was rushing and relying on the Accelerator to speed things up. Also if you end up finishing a pen and later discover that the finish is not to your liking. PenState industries has just come out with a new assembly / dis-assembly tool that works great for tearing apart pens. www.pennstateind.com/store/PENPRESSXL.html I used the PENPRESSXL on 2 pens that I knew I would not be able to repair the PENPRESSXL worked as advertised. The 2 pens together cost more the the PENPRESSXL cost so it was a break even score for me.
CAD-Man
BrianS likes this.
CAD-Man is offline
post #13 of 17 (permalink) Old 11-21-2016, 07:12 AM
harrysin's Avatar
First Name: Harry
Because I'm always in a hurry because of my advanced age (I no longer buy green bananas) an accelerator is essential and possibly by good luck, I've never had a failure.
Unfortunately, because of my poor photography, the pen shown doesn't do justice to the high gloss finish which is as deep as it was when I made it despite it being on my desk since then and in daily use. It's on it's third refill.
I must stress that the accelerator must not be sprayed directly onto the pen, but one or two inches above.
Name:	Rosewood pen0001.JPG
BrianS likes this.
Harry
harrysin is offline
post #14 of 17 (permalink) Old 11-21-2016, 10:53 AM
MEBCWD's Avatar
Originally Posted by Shop guy View Post
Brian, I use spray accelerator between coats. And like Cad-Man island between coats of glue. I polish up to 12000. On the last coat. The trick is to play around, keep notes and find what works for you. I don't think it is an exact science.
I can't do it the way some videos show but have taken bits and pieces from each one and came up with a way that works for me.
Weather will affect how the CA sets up, how deep the first coats penetrate the wood and different polishes produce different results.
I make sure I don't let the polish get hot and dry on the cloth I'm using because it with bind together and change the grit size causing it to scratch the finish instead of polishing it.
BrianS and Shop guy like this.
MEBCWD is offline
post #15 of 17 (permalink) Old 11-22-2016, 08:56 AM
Knothead47's Avatar
Thanks to all for their input. Answered some questions that popped into my mind while reading a book on turning while eating breakfast. Wife is out of town so I have that luxury without her comments on reading at the table.
Harry, we are in the same boat! Oh, to be 50 again! My father always said it's too bad that youth is wasted on the young!
BrianS likes this.
John T.
Knothead47 is offline
post #16 of 17 (permalink) Old 11-23-2016, 07:23 AM
harrysin's Avatar
First Name: Harry
Oh to be fifty again John, I'd settle to be seventy again, I'm eighty three in a few days. On December 1st. I have the right eye cataract removed and a lens fitted then on the fifteenth of December the same to my left eye, but other than still recovering from left shoulder major surgery I reckon I'm not too bad but looking forward to getting back to work in my shed which has lots of spider webs hanging from the roof.
Harry
harrysin is offline
post #17 of 17 (permalink) Old 11-23-2016, 03:17 PM
A good friend lived to be either 92 or 93. This was a man of legend. He went to the local yearly community fair and won the ax chop contest in the logging events at the age of either 80 or 81 against guys in their 20s. At the end he had both a bad heart and cancer and knew the end was soon. He said to me that it's a pretty good engine that runs for for over 90 years without a major breakdown. At 83 yours is a pretty good engine too Harry even if some of the parts are starting to wear down.
AVAILABLE, curly maple for pen turners Jack Wilson Lobby 2 08-04-2013 09:28 AM
Top Quality Pen Kits BigJimAK Woodturning and Lathes 3 10-11-2009 04:28 AM
Making a pen - Photo shoot (Very picture intensive) Bob N Woodturning and Lathes 25 03-06-2009 01:42 PM
My first acrylic pen Glenmore Woodturning and Lathes 26 08-30-2007 10:34 PM
So...you want to make a pen Bob N Woodturning and Lathes 4 09-14-2006 07:37 PM
