Any pen turners out there? - Router Forums
 12Likes
post #1 of 17 (permalink) Old 11-19-2016, 09:53 AM Thread Starter
BrianS's Avatar
First Name: Brian
Default Any pen turners out there?
Anyone here turn pens? Any hints, tips, or tricks that you have found work better than others? Different finish or polishing methods?
Brian
(Origin uncertain)
BrianS is offline
post #2 of 17 (permalink) Old 11-19-2016, 06:45 PM
Semipro's Avatar
First Name: John_*
Brian
Harry i believe had a tutorial on finishing pens with super glue.
Semipro is offline
post #3 of 17 (permalink) Old 11-19-2016, 09:36 PM Thread Starter
BrianS's Avatar
First Name: Brian
Originally Posted by Semipro View Post
Brian
Thanks John. Yes, I watched Harry's video, and LOTS of other ones as well. I've done a couple pens, and then SWMBO wanted a seam ripper, so did one of those as well when I was at Mike's on Sunday. I'm a bit disappointed in the finish on the seam ripper... pen's all turned out nice and shiny. The seam ripper started out that way, but it's dulled now for some reason.
Brian
(Origin uncertain)
BrianS is offline
post #4 of 17 (permalink) Old 11-19-2016, 10:03 PM
First Name: Richard
@BrianS : Did you use super glue on the seam ripper? Are you using any polish after the glue? I have he'd glue cloud up if I put on to much. I use two different super glues to finish with. One thin and one thicker. I get it from Woods and Whimmies. They have a web site.
Shop guy is offline
post #5 of 17 (permalink) Old 11-20-2016, 12:17 PM Thread Starter
BrianS's Avatar
First Name: Brian
Hi Richard. Yes, super glue, or friction polish with CA, which I understand to be the same thing. Several coats, rubbed until I felt the heat. No polish other than that. The same process I followed when I made the pens.
I now have a list of projects, (Imagine!!) so I want to find out what I did, or maybe did NOT do, to loose the shine on the finish. Would the CA maybe be too old?
Brian
(Origin uncertain)
BrianS is offline
post #6 of 17 (permalink) Old 11-20-2016, 05:45 PM
First Name: Bruce
I make 40 to 50 pens a year and almost as many seam rippers. I use CA glue on most finishes, after applying several thin coats (6 to 10) I sand them with 400 grit mesh and then run through with the wet sanding pads that go from 1200 to 12000 grit and then Meguiar's G12310 PlastX Clear Plastic Cleaner & Polish for headlights. Then I use a buffing wheel mounted on my lathe and a buffing rouge. I also use EEE-Ultra Shine Paste Wax and Shellawax Cream for a softer sheen. I make most of my pens using deer antler, also do some with acrylic pen blanks. There is a demand now for wood that has just started this year, I use several different wood species The most time consuming part is getting a good smooth finish on the deer antler. I sell my pens through one of the gift shops in town to tourist and they want the deer antler because it is something that is not a typical item where they may be from.
The reason you are getting the dull finish using CA glue, you must let each layer dry fully. If it s not fully dry between coats it will shine up nicely but after the underlying coats dry fully it causes them to become dull. I only do the first couple of coats with CA medium and make sure they are fully dry and then follow up with CA Thin for the remainder coats.
CAD-Man
BrianS, Gaffboat and bwilling like this.
CAD-Man is online now
post #7 of 17 (permalink) Old 11-20-2016, 06:24 PM
Brian,
I do some pen turning, but my wife is the pro pen turner around here. I got a lot of good information from: Kurt Hertzog Home. Scroll through his articles that were printed in Woodturning Design Magazine. They are on his site and gave me lots of hints and ideas. I usually use Shelawax for a finish, but it's not as durable as CA glue. Have fun and good luck with your pen turning.
Tom
BrianS likes this.
tbahorski is offline
post #8 of 17 (permalink) Old 11-20-2016, 07:29 PM Thread Starter
BrianS's Avatar
First Name: Brian
CAD-Man
Thanks Bruce. That would probably explain the dull finish then... I'm sure I didn't wait near long enough for each coat to dry. In a video Harrysin posted a while back, he was using an accelerator in a spray can. Would that speed the process up any?
And, since you mentioned seam rippers, what kits have you found to be the best? I purchased the one I did from Woodcraft, and the nylon insert that holds the blade of the ripper in place doesn't seem to tighten up enough. The blade moves in it.
I will keep your process in mind when I turn the next one.
Brian
(Origin uncertain)
BrianS is offline
post #9 of 17 (permalink) Old 11-20-2016, 07:39 PM Thread Starter
BrianS's Avatar
First Name: Brian
Originally Posted by tbahorski View Post
Brian,
Tom
Thank you Tom. WoW, took a quick look at Kurt's page. LOTS of information there..
Brian
(Origin uncertain)
BrianS is offline
post #10 of 17 (permalink) Old 11-20-2016, 09:33 PM
First Name: Richard
Brian, I use spray accelerator between coats. And like Cad-Man island between coats of glue. I polish up to 12000. On the last coat. The trick is to play around, keep notes and find what works for you. I don't think it is an exact science.
MEBCWD likes this.
Shop guy is offline
AVAILABLE, curly maple for pen turners Jack Wilson Lobby 2 08-04-2013 10:28 AM
Top Quality Pen Kits BigJimAK Woodturning and Lathes 3 10-11-2009 05:28 AM
Making a pen - Photo shoot (Very picture intensive) Bob N Woodturning and Lathes 25 03-06-2009 02:42 PM
My first acrylic pen Glenmore Woodturning and Lathes 26 08-30-2007 11:34 PM
So...you want to make a pen Bob N Woodturning and Lathes 4 09-14-2006 08:37 PM
