Delta (Type 1) LA 200 Lathe - Router Forums
 1Likes
  • 1 Post By CGL
post #1 of 5 (permalink) Old 04-03-2019, 10:50 PM Thread Starter
CGL
First Name: Chris
Default Delta (Type 1) LA 200 Lathe
Hi, Some folks say that one company may build lathes for six different vendors. I own a Delta (Type 1) LA 200 Lathe and need a tail stock. Are there any other brand names that are interchangeable with the LA 200 Lathe? Thanks for your assistance.
CGL is offline
post #2 of 5 (permalink) Old 04-03-2019, 11:38 PM
Delta's higher end tools may be unique to them. The lower end ones are Taiwanese. A cousin bought their 13" planer and it was identical to a King Canada I have for all practical purposes and my King uses the same gear box, motor, bed, head, and columns as several others. I'm not familiar with that model you have but I would suggest that you look at Jet and Star if they are still around. Possibly Grizzly too as I thing they may come fro the same factory or factories as King, Jet, and some others. If another one looks really similar then it probably is a clone. It also might not be that critical. If the tailstock is made for a lathe with a given swing diameter then the only other factor that matters is the gap between the rails.
post #3 of 5 (permalink) Old 04-04-2019, 10:37 AM Thread Starter
CGL
First Name: Chris
Thank you for your assistance. I will check the Jet out.
CGL is offline
post #4 of 5 (permalink) Old 04-04-2019, 02:52 PM
I just found this ad which has been deleted but it says that the extension fits a Rikon so that might be another place to look.
Delta LA200 Shopmaster 10" MIDI Lathe - tools - by owner - sale
[Search domain indianapolis.craigslist.org/tls/d/indianapolis-delta-la200-shopmaster-10/6854817220.html] https://indianapolis.craigslist.org/...854817220.html
I have a LA200 Delta midi lathe with bed extension making it a 10" x 36". I am willing to sell this lathe for $200 w/o the extension as it fits right on my Rikon mini. Without the extension it is the standard Delta 10"x14.5" lathe.
post #5 of 5 (permalink) Old 04-04-2019, 05:16 PM Thread Starter
CGL
First Name: Chris
Thanks again Charles!
Cherryville Chuck likes this.
CGL is offline
Flip Top Lathe Bench - Pro's and con's ? bigalscorpio Tools and Woodworking 14 08-25-2014 03:04 AM
New lathe, actually it's a metal lathe Jack Wilson Lobby 9 04-11-2014 12:22 PM
Router lathe or lathe router? Dmeadows Jigs and Fixtures 9 12-30-2013 12:26 PM
Delta lathe pulleys ddutro New Member Introductions 5 06-03-2010 02:37 AM
The new lathe is here and I am hooked! dustmaker Woodturning and Lathes 29 10-11-2009 10:58 PM
