My First Lathe - Router Forums
 15Likes
  • 10 Post By schmitt32linedrill
  • 4 Post By schmitt32linedrill
  • 1 Post By schmitt32linedrill
post #1 of 9 (permalink) Old 10-12-2020, 12:16 PM Thread Starter
First Name: art
Default My First Lathe
I built my first lathe at about the age of about 14. I hammered a piece of copper tubing over the end of an old motor's shaft. I used hacksaw and file to shape teeth for a spur chuck. I made the tailstock center from a large spike driven through a 2x4 and clamped to the plank that the motor was screwed on to. Tools were made from old files, you get the idea. No photos.
With this I was able to replicate the spindle / spokes of my mom's old spinning wheel, which I had wrecked as a younger child.
I built several larger and very productive lathes over the years, No photos here either. I had been making small turned boxed, bowls etc. on a $50 lathe salvaged from the rust bin. I began to loose interest and decided I wanted to do something more significant. I built a large face plate only, bowl turning lathe and made a few plates and bowls including a 22 inch tray in which I tried to incorporate bits of all the species of woods I had laying around.
Take a look. Is there a limit to the length of my posts?
Art S
Art S www.schmitt32.com
Drilling for cabinet construction and hardware installation
schmitt32linedrill is offline
post #2 of 9 (permalink) Old 10-13-2020, 08:02 AM
sreilly's Avatar
First Name: Steve
Beautiful turnings Art. I'm trying to get into lathe work and am setup to use my Shopsmith, at least to get started anyway......
sreilly is offline
post #3 of 9 (permalink) Old 10-13-2020, 10:32 AM
roxanne562001's Avatar
First Name: Roxanne
Very nice
roxanne562001 is offline
post #4 of 9 (permalink) Old 10-13-2020, 11:29 AM
Contributor of the Month
First Name: thomas
Art S
A limit to the length of posts ? I'm not sure but I would make them twice as long as the length from the middle to either end.
thomas1389 is online now
post #5 of 9 (permalink) Old 10-13-2020, 12:18 PM
First Name: mary
Very nice work
marecat3 is offline
post #6 of 9 (permalink) Old 10-14-2020, 01:34 PM Thread Starter
First Name: art
Here's a little box I made for my grand daughter. It's amazing how much color you can get with just varnish on Wisconsin Red Cedar.
Turned on my old lathe which purportedly came a workshop owned by Henry Ford in Michigan. I took it apart, every nut, bolt and screw. I cleaned it , painted it, replaced the wood components, lubed it and went to work. I'll see if can show a photo next time.
Art S
post #7 of 9 (permalink) Old 10-18-2020, 05:26 AM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi Art.
I am not sure if there is a limit for the posts but I´d like an endless picture collection about your turning projects.
Thanks for posting those.
We, woodworkers are everywhere!!!
papasombre is offline
post #8 of 9 (permalink) Old 10-18-2020, 10:13 AM
RainMan 2.0's Avatar
Very nice work Art . Never got into lathes , but probably should have . Just finding room now
Ok ,I never insulate
RainMan 2.0 is online now
post #9 of 9 (permalink) Old 10-18-2020, 08:23 PM Thread Starter
First Name: art
Thanks I'm glad you liked it. As you might have guessed, all the work is in the glue up. I unfortunately have a ton of videos showing the complete process, but not much I can show here.
Here is an older cherry bowl that the bottom fell out of while it was still on the lathe. I cut out the bottom with a slight taper to the sides of the cut, then made a walnut plug with matching taper to the outside edges. I was able to just push the glued up plug in, let it dry, and then continue turning.
marecat3 likes this.
