link belt for delta mini lathe - Router Forums
post #1 of 5 (permalink) Old 07-24-2009, 06:50 AM Thread Starter
Default link belt for delta mini lathe
I need to replace my rubber drive belt on my mini lathe and need a narrow link belt replacement - i am having some issues finding a supplier ..most have only the wider saw type --anyone have a ideas? Thank you
wuzfuzde is offline
post #2 of 5 (permalink) Old 07-24-2009, 07:59 AM
Glenmore's Avatar
First Name: Glenmore
I have link belt haven't tried to use it yet for my lathe. Don't know if it will work or not on my rikon lathe I have grooves on the pulleys.
Glenmore
Mountain Top PA
Glenmore is offline
post #3 of 5 (permalink) Old 07-24-2009, 08:33 AM
levon's Avatar
First Name: levon
hi Glenmore
i have a ridgid ts and it has grooves on the pulley and you cant use a linkbelt on it. but you can change the pulleys and then use the linkbelt. this is what ive been told several times.
levon
levon is offline
post #4 of 5 (permalink) Old 07-24-2009, 09:47 AM
dutchman 46's Avatar
First Name: Howard
I believe i may be able to help. Give this a try. I can only guess, i didnt have any #
John 3:16
dutchman 46 is offline
post #5 of 5 (permalink) Old 07-24-2009, 10:09 AM
Have you looked at McMaster-Carr ?
I buy a lot of odd belts there.
Billat908 is offline
Which bit? Duplicating lathe with mounted router msn56 General Routing 5 03-04-2011 02:26 AM
Link Belt vs V belt RobW Tools and Woodworking 8 05-06-2009 01:37 PM
