Cedar Bowl - Router Forums
post #1 of 13 (permalink) Old 12-02-2011, 02:54 PM Thread Starter
RouterForums.com User
First Name: Bernie
Default Cedar Bowl
Here is a cedar bowl I made from some cedar I aquired about 2 yrs ago. It has been in log form until last Saturday. The cedar log was 15 1/2" in diameter. I tried a different bowl design for me. It was pretty dry but have a crack or two in it on one of the knots. Had some wild color. Finished with Antique Oil. It is 9 1/2" X 3". This thing has some wild color to it. I have I think 4 more blanks from this log.
Name:	cedar Bowl 1.jpg
Name:	Cedar Bowl 2.jpg
Bernie W.
To succeed in life, you need three things: a wishbone, a backbone and a funnybone.
BernieW is offline
post #2 of 13 (permalink) Old 12-02-2011, 04:04 PM
mark81253's Avatar
First Name: Mark
Bernie- beautiful bowl for sure!! I got into turning just this past summer and all I have turned is red cedar. A friend of mine's neighbor had 7 or so cedar trees he wanted to get rid of. We cut them down and now I have about 6 lifetimes of cedar to my avail. Here's just a couple of my first turnings:
mark81253 is offline
post #3 of 13 (permalink) Old 12-02-2011, 04:10 PM
Bernie that is beautiful. When you make a bowl like this I am guessing you have a stub in your chuck that is parted off after? I have a maple blank that I want to try; I have to glue a piece of pine to it with paper in between it and the plate for my cheapy lathe.
post #4 of 13 (permalink) Old 12-02-2011, 05:25 PM
TwoSkies57's Avatar
Great looking work you guys!! Cedar has always been one of my favorite woods. Beautiful contrast of color within the same piece. I don't think it gets the recognition it deserves.
Skipper the Penguin
TwoSkies57 is offline
post #5 of 13 (permalink) Old 12-02-2011, 08:56 PM Thread Starter
First Name: Bernie
Thanks guys.
Mark those are some good looking turnings. I do love turning cedar and it also makes the shop smell really good.
Bill I love turning cedar. It just turns nicely and finishes really well.
Mike what I do on my bowls is on one side of the blank that will be the bowl opening I use a faceplate. I turn the outside to the shape I want and also turn a tenon on the bottom for the chuck to hold. I then reverse it with the tenon in the chuck and hollow out the bowl. When I am satisfied with the thickness of the walls I sand to probably 320 to 400 grit. I unscrew the chuck with the bowl still in it and put it on a adapter in my tailstock. I put on my vacuum chuck, turn on the vacuum and bring the bowl up with the tailstock so it is perfectly centered and when the vacuum takes hold I release the chuck and finish the bottom including sanding. Bowl is done and finish is applied.
Bernie W.
BernieW is offline
post #6 of 13 (permalink) Old 12-03-2011, 06:21 AM
harrysin's Avatar
First Name: Harry
WOW, I love the shape and the wood, together they become a real work of art Bernie.
Harry
harrysin is offline
post #7 of 13 (permalink) Old 12-03-2011, 10:52 AM Thread Starter
First Name: Bernie
Thank you Harry.
Bernie W.
BernieW is offline
post #8 of 13 (permalink) Old 12-03-2011, 04:33 PM
Community Founder
Mark's Avatar
First Name: Mark
Bernie you never cease to impress with your work, such perfect craftsmanship on all of your projects. You sir have an amazing talent!
Also Mark, thanks a lot for sharing your projects, I just finished checking out your submissions to the contest and from what I can see in there and above there is no limit to your skills. It's a privilege to have another gifted woodworker on our community
Mark,
Founder of RouterForums.com
Mark is offline
post #9 of 13 (permalink) Old 12-03-2011, 04:48 PM
xplorx4's Avatar
First Name: Jerry
Keep the projects coming those are just stunning.
Lamentations 3:22-23
xplorx4 is offline
post #10 of 13 (permalink) Old 12-03-2011, 06:07 PM Thread Starter
First Name: Bernie
Mark and Jerry thanks. I try to make improvements with every piece I turn. The big things and the little things.
Mark keep your turnings coming.
Bernie W.
BernieW is offline
Bowl Returning to Lathe BernieW Woodturning and Lathes 1 12-08-2013 03:44 AM
Roughing a Bowl BernieW Woodturning and Lathes 10 12-08-2013 03:26 AM
Cedar Pergola TRN_Diesel DIY and Renovation 11 06-11-2010 08:49 AM
Re-working the Jacaranda bowl harrysin Woodturning and Lathes 8 10-25-2008 01:44 PM
NE Bowl Presentation Mitch12 Woodturning and Lathes 16 06-13-2008 12:27 AM
