Novice considering a lathe... - Router Forums
post #1 of 16 (permalink) Old 02-15-2013, 06:51 AM Thread Starter
Nickp's Avatar
First Name: Nick
Default Novice considering a lathe...
Is it possible that I would be making a horrible mistake buying a HF lathe (the 12x33 with reversible head)...? http://www.harborfreight.com/12-inch...ead-34706.html
I am a complete novice...never owned a lathe...have worked with metal lathe and I know high quality means high bucks means high capabilities. I also know it may be easy to outgrow certain tools but am thinking not likely to outgrow turning too quickly as I also don't have enough time to spend turning with all my other interests...
The HF unit seems to have enough features to keep me going for a while...I've read posts where much more experienced woodworkers have used this for many years before they went bigger...
Not sure when I would get to the point of exceeding a much smaller investment than what other lathes are going for with what appears to be same features...
Did I just talk myself into buying the HF...?
Anybody out there have one (or had one) that could share their thoughts...?
Thanks in advance...Nick
Nickp is offline
post #2 of 16 (permalink) Old 02-15-2013, 08:23 AM
First Name: Duane
How about this one? Same money, much better warranty and support(You can actually get parts if needed)!
G8688 7" x 12" Mini Metal Lathe
I assume, since you didn't specify, that you were looking at the 7x12!
Dmeadows is offline
post #3 of 16 (permalink) Old 02-15-2013, 08:32 AM Thread Starter
Nickp's Avatar
First Name: Nick
Sorry...I am actually looking for wood lathe...and to be able to do small stuff (bowls, pens, etc...) and longer stuff like newels, table legs, balusters...
I guess I wasn't clear...so something that will handle the longer pieces...
I did mention the metal lathe but only to describe some experiences with lathe...sorry...
Thanks,
Nick
Nickp is offline
post #4 of 16 (permalink) Old 02-15-2013, 09:23 AM
First Name: Duane
Thanks,
Nick
Nick, I am sorry.. not sure how I got the idea you were looking for a metal lathe. I agree, for the money, the one you are looking at is hard to beat! Don't own one, but I have had good use from the HF machines that I have. It looks like it should serve you well, except maybe for really large bowls!
Dmeadows is offline
post #5 of 16 (permalink) Old 02-15-2013, 09:55 AM
Hi Nick:
There is one problem with that lathe (I have one) and that is the position of the motor.
It protrudes forward and prevents you from making anything bigger than a 6 inch bowl.
It happens when you want to turn it around and finish the bottom. Even though you can rotate the headstock, the motor turns with it. otherwise it is a good lathe.
Maurice Adams is offline
post #6 of 16 (permalink) Old 02-15-2013, 11:34 AM Thread Starter
Nickp's Avatar
First Name: Nick
Originally Posted by Maurice Adams View Post
Hi Nick:
Would i avoid that if i finished the bottom before turning the inside...? With the head still reversed or to the side...?
Nickp is offline
post #7 of 16 (permalink) Old 02-15-2013, 07:39 PM
No because you use the bottom foot to hold the piece in the chuck to hollow the bowl
post #8 of 16 (permalink) Old 02-15-2013, 07:41 PM
This one is much better because the motor is not in the way.
post #9 of 16 (permalink) Old 02-15-2013, 08:47 PM Thread Starter
Nickp's Avatar
First Name: Nick
...got it...thanks
Nickp is offline
post #10 of 16 (permalink) Old 02-15-2013, 08:48 PM Thread Starter
Nickp's Avatar
First Name: Nick
...which one...? Was there supposed to be a link...?
Nickp is offline
A DIFFERENT ROUTER LATHE or “A ROUTER STANDARDIZER” neville9999 Jigs and Fixtures 8 01-04-2013 12:48 PM
Which bit? Duplicating lathe with mounted router msn56 General Routing 5 03-04-2011 02:26 AM
Working with a cheap lathe? Finlander Woodturning and Lathes 18 01-19-2011 09:29 PM
Corect name router lathe tigerhellmaker General Routing 6 01-03-2010 10:47 PM
The new lathe is here and I am hooked! dustmaker Woodturning and Lathes 29 10-11-2009 09:58 PM
