bowl blank material - Router Forums
post #1 of 4 (permalink) Old 06-13-2013, 09:53 AM Thread Starter
First Name: Ben
Default bowl blank material
I'm new to wood turning and need a little advice.
What wood would you recommend for bowl turning? I'd like a well behaved wood while machining with a nice grain pattern.
Your advice on where to buy bowl blanks would also be appreciated.
Thanks,
Ben
Forest Reduction Study Group
Ben in Cypress Texas is offline
post #2 of 4 (permalink) Old 06-13-2013, 10:53 AM
Find a company that specializes in woodturning and they will probably sell them. There is a way to get lots of turning blanks for free or cheap, and some of it could be slightly exotic. In your area of Texas there should be several companies that remove problem trees from peoples yards (tree surgeons or tree removal companies). It shouldn't be hard to strike up a deal with one of them. Even if they have markets for the sawlog part of the tree, there is lots of turnable wood that won't make lumber such as large limb crotches and sections between knots.
post #3 of 4 (permalink) Old 06-14-2013, 07:34 AM
First Name: Art
As Charles mentioned your best bet is to find some local wood. If you are new to turning you will be making a lot of saw dust and buying wood can get very expensive. Check out Lyle Jamieson on Youtube for an excellent source of bowl turning information.
mgmine is offline
post #4 of 4 (permalink) Old 06-14-2013, 08:00 AM
BernieW's Avatar
First Name: Bernie
I agree with the above suggestions. I have a good relationship with our local tree guy. He gave me some wood so in turn I gave him a pen and a bowl. As for a wood suggestion down in Texas I have a friend that sends me mesquite every now and then. It is about the most stable wood I know. I have turned several bowls and hollow forms from it with little if any movement and is a beautiful wood.
Bernie W.
To succeed in life, you need three things: a wishbone, a backbone and a funnybone.
BernieW is offline
Bowl Returning to Lathe BernieW Woodturning and Lathes 1 12-08-2013 03:44 AM
Roughing a Bowl BernieW Woodturning and Lathes 10 12-08-2013 03:26 AM
Bowl blank specials in Northern VA, Southern MD kp91 Woodturning and Lathes 0 02-01-2010 08:56 AM
Re-working the Jacaranda bowl harrysin Woodturning and Lathes 8 10-25-2008 01:44 PM
NE Bowl Presentation Mitch12 Woodturning and Lathes 16 06-13-2008 12:27 AM
