Craftsman 351.21717 - Router Forums
post #1 of 12 (permalink) Old 11-05-2013, 04:33 PM Thread Starter
TwoSkies57's Avatar
Default Craftsman 351.21717
Hey all you turners out there, I finally joined your ranks (kinda, sorta, maybe) by picking up a used lathe a couple weeks back. Its nothing special, actually, given
the reviews and comments on the thing it really is "nothing special"
I grabbed up a Craftsman 351.21717. Long story short, if you got a good one, you got a good one!! Otherwise, generally considered a bit of a headache. So far, she's running just fine. The lathe was hardly ever used. In fact, still has the packing grease on the bed and there's barely a nick on the thing. So here's hoping I got a good one.
Not much in the way of accessories came with the thing, however it was pretty complete with the exception of the indexing wheel and 1 38mm wrench..
So if any of you folks out there, have one or run across one, I'd appreciate your dropping me a note and see if we can work something out...Most of the parts for this lathe are NLA via Sears PartsDirect..
thanks
bill
Skipper the Penguin
TwoSkies57 is offline
post #2 of 12 (permalink) Old 11-05-2013, 07:28 PM
As if you don't have enough to do, Bill.......VBG.
Sydney, Australia
jw2170 is offline
post #3 of 12 (permalink) Old 11-05-2013, 08:03 PM Thread Starter
TwoSkies57's Avatar
And there seems to be more coming all the time... soon, too soon I fear, I'm going to have to make some decisions regarding just where to take all of this..
But in the mean time... its from one money pit to another
Skipper the Penguin
post #4 of 12 (permalink) Old 11-05-2013, 08:39 PM
First Name: Duane
Hi, Bill. I have one of those lathes. It's worked reasonably well. I'd sell it, but it would end up costing a lot more than I would get out of it, to buy another lathe. The indexing wheel really doesn't work to well. I need to drill all the holes out a couple/few thousandths. By the way, you need 2 of those 38mm wrenches. Don't know if have one or none!
If you want to turn anything really large, take very light cuts. It's fairly easy to stall that thing.
And you are right, not many parts available for it. I used to change the headstock assembly on them rather frequently years ago. The replacements were the mechanical(reeves) drive, not the electronic speed control. Mine however is still original.
Hope it works well for you
Dmeadows is offline
post #5 of 12 (permalink) Old 11-05-2013, 09:20 PM
A money pit is right.....VBG.
I hear that it costs 10 more for the utensils than it does for the stove.....
Sydney, Australia
jw2170 is offline
post #6 of 12 (permalink) Old 11-06-2013, 09:16 AM
First Name: Paul
PRDarnell is offline
post #7 of 12 (permalink) Old 11-06-2013, 05:58 PM Thread Starter
TwoSkies57's Avatar
Hi Duane... Thanks for the heads up on the indexing wheel. For now, I'm not too worried about the thing, it was just 'missing'.. that and one of the wrench's'. So far, she seems to run just fine. I really have nothing to compare it with, but for what I've attempted so far, I've had good fortune. The biggest obstacle thus far has been the chisels I'm using. I picked up a set from Pennstate Ind. Not a great set, but good enough I suppose. Out of the box, the edge on each one is crap. I"m somewhat surprised by this. I expected to have to do some honing, but gheezzz these things need some serious attention. While at a Rockler store last Friday, I picked up a carbide tipped round. Holly smokes, what a difference!
I"m not really expecting any great things out of this unit, just needed something to turn a couple legs for my rocker and I wanted something to play with to see if turning would be something I'd like to get more involved with. I've gotten several requests for tables with turned legs/spindles so for now, This lathe should fit the bill if she holds up.
Skipper the Penguin
post #8 of 12 (permalink) Old 11-06-2013, 06:02 PM Thread Starter
TwoSkies57's Avatar
Originally Posted by PRDarnell View Post
Thank ya Paul...
I came across that thread "after" having bought the lathe. In fact, I ran across several threads of similar content after having bought the lathe *L*. No so sure I would have picked it up would I have read all of the reviews first. Usually I'm damn near anal about doing my homework, but this popped up on Craigs List and I jumped on it. I will admit however, for the limited amount of use I've given it thus far, I can't complain in the least. There is indeed a certain amount of instant gratification when playing on a lathe...
Skipper the Penguin
post #9 of 12 (permalink) Old 11-08-2013, 03:15 PM
Knothead47's Avatar
If you knew who made it for Sears, you might be able to get some parts. Sears always changes a few things from the OEM product so all parts don't interchange.
John T.
Knothead47 is offline
post #10 of 12 (permalink) Old 11-09-2013, 09:39 AM Thread Starter
TwoSkies57's Avatar
John..
I looked up the Mfg. and found the lathe was contracted out to Sears by a company known as Colovos out of Ill. Tried to dig a little deeper and from what I could gather (and I may be wrong here....)) it appears the lathe was made in Taiwan. I didn't come across any data that woud have told me of any other similar lathes under a different branding.
Alot of the woodworking forums have at one point had a thread or two on this unit...the bottom line when it comes to repair parts Lots of luck
Fortunately, at this point I seem to have one that will at least get me thru the rocker project... and with a little luck, enough play time to determine if I want to invest in a better unit.
Skipper the Penguin
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Craftsman really? brownsfn2 General Routing 25 07-18-2011 12:58 PM
dust extraction for craftsman routers headclansman General Routing 2 08-01-2009 10:29 AM
craftsmen router? rhe8542 Starting Off 21 04-20-2009 10:51 PM
Porter Cable vs. Craftsman rprice54 Tools and Woodworking 7 01-17-2006 10:16 PM
