Rose Engine Lathe using Router - Router Forums
post #1 of 7 (permalink) Old 06-03-2014, 06:58 PM Thread Starter
First Name: Jerry
Default Rose Engine Lathe using Router
I am new to Router Forum and I am thinking about building a Rose Engine Lathe that will use a Router for the cutter head.
Has anyone done this?
You comments please.
Thanks Gerald
[email protected]
post #2 of 7 (permalink) Old 06-03-2014, 09:50 PM
Thanks for posting, Jerry.
You have been in the background for some time.....
Sydney, Australia
jw2170 is offline
post #3 of 7 (permalink) Old 06-04-2014, 06:47 AM
First Name: Richard
Send a message via Skype™ to rwbaker
Interesting concept, should work. The only item that I can suggest is search Popular Mechanics Mag on Google. They have all on line and searchable (1900 on and much more technical before 1980). I remember 1 issue (1940s) that shows how to make the rotational and X movement device to fit a drill press to create ornamentals. Lindow Machine Works - Makers of Modern Rose Engine Lathes shows a modern version of your idea and considering that these machines cost 4500 to 14500, your idea is definitely worth exploring.
I would appreciate updates from time to time if you proceed with your project.
Good Luck - Baker
rwbaker is offline
post #4 of 7 (permalink) Old 06-04-2014, 07:08 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I'm not aware of anyone who has one of these lathes and I can't help wondering what specific purpose you have for one. I don't see any reason why a router couldn't be used for the cutter head.
Harry
harrysin is offline
post #5 of 7 (permalink) Old 06-04-2014, 07:10 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Jerry all the Rose Engine builders that I know use small bench grinders like the little Ryobi Bench Grinder, or small sowing machine motors as the engine, there would be no reason why you could not use a small Router like a laminate trimmer, I am using a long nose electric die grinder for some cuts and it is very handy as it already has a 1/4 collet, I have had a quick look for some of the photos I have of these Rose Engines and just now I can't put my hands on them, I do have them so if I can find them then I will post them on your thread, OK forget all that I found three, there are more but on these then you can just see the front of the Ryobi bench grinder. N
Harry I am friends with some guys here in Sydney Called "The Ornamental Wood Turners' These old guys are as cool as and they make these Rose Engines from scratch, they rock and tilt and roll, OK they wobble as well and they do create the neatest designs in plates and other things, some of the rose engines took hundreds of hours to build, they also use them to create the nicest engraved urns, I met them when I was researching design details for my router lathe and my shaft design came totally from them, they also pointed out to me the benefits of using a wood lathe chuck (as you see in the photos) to hold the work piece, they meet once a month and if I had the time then I would hang out with them a lot more. Neville
neville9999 is offline
post #6 of 7 (permalink) Old 06-04-2014, 09:57 AM
First Name: Larry
Neville
Do you have a drawings of your lathe?
woodie26 is offline
post #7 of 7 (permalink) Old 06-04-2014, 04:13 PM
First Name: ray
Jerry
I have a friend that has made one he is a machinist by trade. His used a small motor to turn the project and a router to make the cuts. He said he has over 3000.00 in parts and close to 200 hours labor. The last time I talked to him he said there were a lot of bugs to work out and several more things he wants to make or get before he considerers it complete. I personally canít justify all the work and expense for what it can do, itís just another toy to spend money on and collect dust it takes up a lot of counter space. But heís happy with it I guess thatís what counts.
Ray
rayschimpf is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Router Lathe without gears Clemo Jigs and Fixtures 6 06-18-2012 06:06 PM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
New here burlboy New Member Introductions 9 01-15-2009 11:53 AM
