Wanted Craftsman Jointer 113.206801/206931 Parts (Linkage Assembly / Cutter Guard) - Router Forums
post #1 of 4 (permalink) Old 07-19-2018, 01:35 PM Thread Starter
Default Craftsman Jointer 113.206801/206931 Parts (Linkage Assembly / Cutter Guard)
I've spent the last month restoring a Craftsman Jointer 113.206801 and I'm looking for two parts:
Part#21204 Linkage Assembly. Specifically, a single piece of the assembly. I've attached a picture of the missing part. Unfortunately, I had accidentally adding to the part to my vinegar bath along with other parts. Looks like it was found at the bottom of the sea now (unusable). It's for a 5/8" shaft, 9 tpi, and left threaded (Some models are 11 tpi but the part looks exactly the same). I could use an 11 tpi one if someone has a matching 8" shaft to go with it.
Part#67009 Guard, Cutter. All the parts that hold it in place I have but didn't realize this was missing when purchased. Simple part to make for use but would like to get the original part to complete the build.
Pictures attached for both.
I appreciate any assistance you can provide!
steinmetzma is offline
post #2 of 4 (permalink) Old 07-19-2018, 03:08 PM
vehicle mirror mounting bracket...
post #3 of 4 (permalink) Old 07-23-2018, 08:10 PM
CharleyL's Avatar
First Name: Charley
If you post a photo of jour assembled joiner you might find someone who will recognize it and has one to help you with the needed parts, or maybe combine the two to make one. Old Craftsman parts are very hard to find. You might also get a machine shop to make you what you need, but it may be cost prohibitive to go this way.
Good luck,
Charley
Central North Carolina
CharleyL is online now
post #4 of 4 (permalink) Old 07-24-2018, 11:58 PM Thread Starter
Thanks Charley for the advice. Attached is a picture of it before I started restoring. There are a few fabrication shops in town I plan on checking with to get pricing. I check various selling sites daily for either the part or a whole additional jointer if I can find one at a decent price.
Thanks again,
integrating INCRA jig parts & Craftsman TableSaw & Router:Part2 [Router Coping Sled] SimonHartropp Jigs and Fixtures 0 09-14-2015 12:39 PM
Profile Cutting Cutters and their Bearings neville9999 Jigs and Fixtures 7 12-10-2012 01:11 PM
The use of a Router table as a Profile Copier neville9999 Jigs and Fixtures 4 12-06-2012 11:44 AM
Cutter Bit for Craftsman Biskit? Milt & Carol Lane Router Bits - Types and Usage 6 02-29-2012 05:12 PM
