Wanted Suggestion is required. - Page 2 - Router Forums
 25Likes
post #11 of 28 (permalink) Old 11-04-2019, 09:31 AM
chessnut2's Avatar
I've been quite happy with my Wen 6552T 13 inch planer. I don't do much hardwood, but it's done great on soft woods that I use in signs, etc.
https://www.amazon.com/WEN-6552T-3-B...2877589&sr=8-5
Flipsaw likes this.
chessnut2 is offline
post #12 of 28 (permalink) Old 11-04-2019, 09:53 AM
CharleyL's Avatar
First Name: Charley
I also have the DeWalt 735 and I think it's the best portable planer on the market today. The 735X includes the in and out feed tables. I have owned 3 planers, and the previous 2 sniped very badly, so badly that the first and last 6-8" of the boards were 1/8-1/4" thinner. This is a terrible waste when planning an expensive board that is only 3' long. The DeWalt 735 does not snipe when it has the in and out feed tables, and they are adjusted correctly, and I have run pieces as short as 1' through it without problems. I can see a snipe line when planning soft woods, but it's so slight, mabe only a few thousandths, that a few swipes with 150 grit sandpaper witll make it invisible.
Planers make a lot of chips fast, and will fill up a dust collection system very quickly. I use my 735 outside my shop. It's attached to a Miter Saw/Planer Stand, that folds and moves like you would a hand truck, so I can store it with the planer attached to it, on end in my shop, taking only about 3 sq ft of floor space, but I can easily wheel it out into the driveway and lift the stand and planer into position very easily (it's a very heavy planer at 95 lbs). The stand that I have is a Delta, but DeWalt makes a similar and slightly better version of it. It is the DWX726 https://www.amazon.com/DEWALT-Miter-.../dp/B0066N7C74
Because the planer is so heavy, this stand has proven to be the best way for me to move it in and out of my shop, as well as provide support for the planer when in use. Gas springs in the stand help when lifting or lowering the stand, so it's much easier for this old man to do. Because the mounting points of the 735 are not the same as those of a miter saw, I had to use a piece of plywood between the planer and stand with different hole patterns to adapt the planer to the stand, but this was quite easy to accomplish. I made it to fit the planer, and then just added holes to match the rail spacing of the stand. A few bolts and it was done.
With it's internal chip blower, the 735 does not need to be connected to a dust collector. I have the hose and barrel cover accessory originally offered by DeWalt, so I attach the barrel cover to a 55 gallon plastic barrel, and as long as the draw string on the cover stays tight, all of the chips and dust from the 735 end up in the barrel. This accessory is no longer available from DeWalt, but a very similar design is available under the Black & Decker name for use with a lawn and leaf vacuum https://www.amazon.com/BLACK-DECKER-...G1FCFD1KAFAP3G and I believe that it's the same thing as the one originally offered by DeWalt for use with the 735, but I haven't actually tried it.
When the cover doesn't stay on the barrel, I have sometimes had to clean the chips out of my neighbor's pool, which is located behind my shop. Lately, I have added some duct tape to better secure the cover, as I now no longer trust the draw string alone to keep the cover on the barrel. When doing serious amounts of planning, I can fill that barrel in about an hour. As long as they aren't black walnut or treated lumber, or some other wood that is dangerous to animals and plants, I use the chips as mulch in my gardens. The dangerous chips get bagged and put in my trash, to be picked up by the city.
Although a drum sander ,like @JOAT (Theo) posted, can be quite handy, it is not a good way of changing the thickness of boards, unless you only need to remove a few thousandths of an inch from the boards. It will take hours and lots of sandpaper to remove 1/4" of board thickness.
Charley
Central North Carolina
CharleyL is offline
post #13 of 28 (permalink) Old 11-04-2019, 10:00 AM
First Name: JJ
Cast my vote for the Wen 6552T planer also. Works very well and is a 3 blade unit. Have not had any issues with mine.
chessnut2 likes this.
Flipsaw is offline
post #14 of 28 (permalink) Old 11-05-2019, 12:14 AM
Dewalt 735. Hands down the best in their price range.
billyjim is offline
post #15 of 28 (permalink) Old 11-05-2019, 08:43 PM
OutoftheWoodwork's Avatar
First Name: Barb
I also have the DeWalt 735x Ken says *giggle* I just know it's DeWalt, and I like it. Also got the shelix blades to change over to when the originals that came with it dull out.
I disagree with the "once every six months" usage statement, but man, is that thing LOUD. I make sure the ear protectors are on when I use it, and recommend the same to others. I use mine quite a bit, but that's because I make a lot of signs on the cedar dog ear fencing, and they're rough cut. But I've also used it to fix errors on other wood, I run my signs through to get the excess ink off after painting the letters (no comments about dulling the blades; sanding takes too long, and this avoids sanding marks, especially since I can't use hand-held belt sanders. Ruined signs with those.) Also used it to make a piece of wood down to a desired thickness, of course, when I didn't have the right size. Investment was $900 USD including the shelix, but worth it.
JFPNCM, chessnut2 and Herb Stoops like this.
Barb
Get your facts first, then you can distort them as you please.
Mark Twain
There cannot be a crisis next week. My schedule is already full.
Henry A. Kissinger
If you choose to poke at a bee hive, be prepared to get stung.
OutoftheWoodwork is offline
post #16 of 28 (permalink) Old 11-07-2019, 12:30 AM
JOAT's Avatar
First Name: Theo
That stuck in my mind. Actually I think if you made a jig to hold the belt sander, so you could slide it sideways over a piece of wood, it would work. Likely leave marks, but figure a few passes with a ROS would take care of that.
JOAT is offline
post #17 of 28 (permalink) Old 11-07-2019, 08:22 AM
First Name: Art
I'm another vote for the 735. I can't think of anything bad to say about it. It is loud but you should always be using hearing protectors with any power equipment. I save my old blades to use on really nasty wood like old furniture I find at the curb. No need to remove the old finish just put it through the planer. If I'm removing paint I take the planer outside. I've been using a set of $13 dollar blades that I bought of Ebay last December and they are really decent blades.
mgmine is offline
post #18 of 28 (permalink) Old 11-07-2019, 01:20 PM
I only use my planer for cleaning up rough sawn lumber or reducing the thickness of material over 1/16" of an inch. Otherwise I use the drum sander for smoothing and finish sizing boards.
Herb Stoops is offline
post #19 of 28 (permalink) Old 11-11-2019, 10:26 AM
MoHawk's Avatar
First Name: Bob
I went ahead and purchased the DeWalt 735X from Rockler. It arrived last Thursday. Since I recently had cervical spine surgery, I had the UPS driver unload it in my detached shop where it will reside. It will likely be another 2 weeks before I can assemble the base to mount the planer. Can't wait to try it out on some beautiful Ash and Walnut I've had for years.
Bob aka MoHawk & Gigawatt
CNCRP Pro4824, Aspire 10, Mach4
MoHawk is offline
post #20 of 28 (permalink) Old 11-11-2019, 11:52 AM
This seems a good place to post some chip collection solutions I've found for the 735. Since it has such a powerful internal blower, it has clogged my DC unit pretty fast. These solutions are all about letting the air out of a container while keeping the chips inside. I think you could make this with any flat topped 55 gallon drum. Since there's so much air going into the drum, you could line it with a bag for easy disposal. I'd want a very large opening for air to exit so there's no back pressure to deal with. This would be a good project for this coming weekend. Sealing the top on tight would be important. Lots of bunji cords?
OutoftheWoodwork and MoHawk like this.
