For Sale Whiteside 3390 Fine Finger Joint Router Bit - Router Forums
post #1 of 5 (permalink) Old 07-01-2015, 05:19 AM Thread Starter
Default Whiteside 3390 Fine Finger Joint Router Bit
ImageUploadedByTapatalk1435745920.154559.jpgImageUploadedByTapatalk1435745952.091212.jpg
5/16" - 1 1/4" MATERIAL THICKNESS
1 3/8" LARGE DIAMETER
5/16". FINGER DEPTH
3 1/4" OVERALL LENGTH
1/2" SHANK
I purchased this router bit to make finger joints on the corners of small decorative boxes, however, this bit is not designed for that application. I made 2 test cuts and realized that fact.
This bit is designed to cut finger joints on the ends or edges of two boards, to make them longer or wider.
This bit is very sharp and makes very precise and accurate joints.
This bit sells for $126, but I have found it on sale for $100 plus shipping.
The only comparable bit is the Freud 99-037 which sells for $100 plus shipping, but it could probably also be found on sale.
As good as Freud bits are, I prefer Whiteside, because i always get better results from Whiteside bits.
I have absolutely no use or need for this bit, and They will not take a return because I made 2 test cuts.
Almost Brand Nee Bit (2 test cuts) - $80
Sent from my iPhone using Tapatalk
jvg2259 is offline
post #2 of 5 (permalink) Old 07-01-2015, 04:06 PM
This is my ad, but I had to post from a new profile because I was having problems signing in under this name
jg2259 is offline
post #3 of 5 (permalink) Old 07-01-2015, 08:09 PM
Jim it seems you remembered how to login with your original user name. Would you like to keep the old one and have Admin eliminate the new one or vice versa?
post #4 of 5 (permalink) Old 07-02-2015, 05:44 AM
Yes Chuck, please delete the newer user name jvg2259. Thank you, and sorry for the issue that I caused.
jg2259 is offline
post #5 of 5 (permalink) Old 07-02-2015, 09:31 AM
No prob. I'll let Admin know.
Bos Joint Stack router bit - jig? CR1 Jigs and Fixtures 6 02-14-2013 12:12 PM
Two wrench method- one wrench router Delta6mike General Routing 68 03-26-2012 09:25 AM
How to setup a Finger Joint Assembly Router Bit Bychen Router Bits - Types and Usage 14 12-19-2009 02:18 PM
Ridgid Router Easy Above Table Bit Change shawnpatt Table-mounted Routing 1 03-06-2009 04:58 PM
