Wanted Freud FT 2000 E Guide Bush - Router Forums
post #1 of 12 (permalink) Old 08-05-2015, 03:51 PM Thread Starter
oldyam's Avatar
Country: Ireland
First Name: Nigel
Default Freud FT 2000 E Guide Bush
Hi Guys
As the title I'm looking for a guide bush for my Freud FT 2000 E router the original has gone missing so a std will do.
Thanks for looking
Nigel
oldyam is offline
post #2 of 12 (permalink) Old 08-06-2015, 09:21 AM
PhilBa's Avatar
First Name: phil
I had one but it sat for years and when I pulled it out to look at it, the ring was locked so tight to the bushing that it wouldn't unscrew. Pliers just wrecked the aluminum so I tossed it. It was pretty bad anyway - wasn't centered in the base - off by about 4 mm. The design is pretty bad as well - only 2 points of contact.
But, the good news is you can make a new sub base out of acrylic or lexan that will that take standard bushings. In the states that means Porter Cable format. Not sure what that is for Eire.
Here is a link to a template that you can use to make the sub base. Though, I just use the one that's on the router.
PhilBa is offline
post #3 of 12 (permalink) Old 08-06-2015, 02:09 PM
I thought I might still have one if they came with the router but if it did I've lost it. The Hitachi is very similar to it for the M12V.
post #4 of 12 (permalink) Old 08-06-2015, 02:50 PM
threw my FG ruler away...
the whole ruler was inaccurate...
post #5 of 12 (permalink) Old 08-08-2015, 12:28 PM Thread Starter
oldyam's Avatar
Country: Ireland
First Name: Nigel
Thanks for the information guys, I would prefer to retain the original base for the additional features it has over the replacement, so I will persevere for a while and see if I can get a guide bush that will fit the original base.
I will check out the bushes for the Hitachi MV12 as a possible alternative.
I dont understand the reference to the FG ruler however, thats probably my lack of knowledge on the subject.
Again thanks
Nigel
oldyam is offline
post #6 of 12 (permalink) Old 08-08-2015, 01:25 PM
PhilBa's Avatar
First Name: phil
You don't replace the base, just attach the new one when you need to use bushings.
PhilBa is offline
post #7 of 12 (permalink) Old 08-08-2015, 03:20 PM Thread Starter
oldyam's Avatar
Country: Ireland
First Name: Nigel
Hi phil
My misunderstanding of the base use.
How thick is the material the sub base is made from
How do you fix the bushes to the base ?
TIA
Nigel
oldyam is offline
post #8 of 12 (permalink) Old 08-08-2015, 09:34 PM
PhilBa's Avatar
First Name: phil
I use 1/4" (actually .233", about 6mm) lexan (polycarbonate) but acrylic would work. The standard Porter Cable style bushings require a 1 3/16" (1 1/4" works) hole and a 1 3/8" rabbit for the retaining nut. I swap bases all the time on my routers. Like I said, I'm not sure how this all works in metric-land.
This should give you a better idea
PhilBa is offline
post #9 of 12 (permalink) Old 08-08-2015, 09:39 PM
PhilBa's Avatar
First Name: phil
By the way, here's one I made out of 1/2" (well, 12mm) plywood. You might recognize the router... I threw it together to make some dados and mortices.
PhilBa is offline
post #10 of 12 (permalink) Old 08-09-2015, 06:27 AM Thread Starter
oldyam's Avatar
Country: Ireland
First Name: Nigel
Thanks for the info Phil, I'm not familiar with that type of bushing as all of the ones I've seen before have been clamped in place with 2 or 3 screws, I'm assuming that one uses a screw on lockring on the back ?
As for the metric I'm well used to switching back and forth to / from imperial as its what I grew up with, I still work things out in feet & inches etc and convert to metric ... lol. I guess its an age thing.
And I like the dado attachment, my Freud was bought by me in 95 so Im reluctant to bin it because its old as it hasn't done a great deal of work compared with some of you guys on here
oldyam is offline
7/16" guide bush for the Freud/Casals FT2000VCE??? Alf Beharie Guide Bushings and Templates 7 06-01-2015 04:03 PM
Freud Edge Guide Mystery Chappmann Jigs and Fixtures 4 12-26-2011 01:36 PM
Erbauer Router and Guide Bush Template for Leigh D4R Jig OneDs Guide Bushings and Templates 14 11-29-2011 04:18 PM
Trend Guide Bush Collars jamesbbuk New Member Introductions 3 03-06-2010 07:47 PM
Guide bush for portercable 517 TomB Portable Routing 7 03-20-2005 11:40 AM
