For Sale Whiteside 3390 Fine Finger Joint Bit - Router Forums
 6Likes
post #1 of 21 (permalink) Old 08-05-2016, 06:31 PM Thread Starter
Default Whiteside 3390 Fine Finger Joint Bit
Whiteside 3390 Fine Finger Joint Router Bit
5/16" - 1 1/4" MATERIAL THICKNESS
1 3/8" LARGE DIAMETER
5/16". FINGER DEPTH
3 1/4" OVERALL LENGTH
1/2" SHANK
I purchased this router bit to make finger joints on the corners of small decorative boxes, however, this bit is not designed for that application. I made 2 test cuts and realized that fact.
This bit is designed to cut finger joints on the ends or edges of two boards, to make them longer or wider.
This bit is very sharp and makes very precise and accurate joints.
This bit sells for $126, but I have found it on sale for $100 plus shipping.
The only comparable bit is the Freud 99-037 which sells for $100 plus shipping, but it could probably also be found on sale.
As good as Freud bits are, I prefer Whiteside, because I always get better results from Whiteside bits.
I have absolutely no use or need for this bit, and they will not take a return because I made 2 test cuts.
Almost Brand New Bit (2 test cuts) - $70
Paypal
Sent from my iPad using Tapatalk
Jim Gallo is offline
post #2 of 21 (permalink) Old 08-05-2016, 10:26 PM
Interesting bit. Looking at the top of my workbench, I see how they've taken short pieces of Maple and used this kind of bit to join them. But that means jointing and planer work to get every piece of scrap exactly the same width and thickness. Glue, pressure and you get long pieces.
post #3 of 21 (permalink) Old 08-06-2016, 12:34 AM
I'm guessing that you were mislead by the manufacturer's name for that bit Jim. If you look at texts from a century ago that profile was called a splice joint which is what it is and the only thing it's good for. It is occasionally referred to as a tapered finger joint but a true finger joint is what many refer to now as a box joint.
Your options for small boxes is a true finger joint, 45* miter joint, miter joint with splines, lock miter joint, or small dovetail.
Nickp likes this.
post #4 of 21 (permalink) Old 08-06-2016, 02:46 AM
hawkeye10's Avatar
First Name: Don
I feel your pain Jim.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #5 of 21 (permalink) Old 08-06-2016, 02:51 AM
hawkeye10's Avatar
First Name: Don
Jim when in doubt about something I ask questions here on this forum. Someone always knows the answer to my stupid questions and has saved me from making a mistake.
post #6 of 21 (permalink) Old 08-06-2016, 03:01 AM
welcome to the forums Jim...
Stick486 is offline
post #7 of 21 (permalink) Old 08-06-2016, 10:53 AM Thread Starter
Thanks all. I should have researches further, but to me, finger joint means just that. Finger joint and box joint terms are intertwined all throughout woodworking articles, videos, and forums. I just need to be more careful.
I make boxjoints on the tablesaw and router table all the time. This bit just seemed like it would be easier. They do make a bit for finger/box joints by those names, however the cutters are not tapered.
Thanks for the welcome, but I have been a member of this forum for a good while now, under different names, because I either forget my name or my password, and I'm too brain dead to document that info somewhere.
I have gone by jg2259, [email protected], jimgallo37, and a few others.
When will I learn?
Sent from my iPhone using Tapatalk
post #8 of 21 (permalink) Old 08-06-2016, 01:07 PM
Nickp's Avatar
First Name: Nick
Jim...there is a forgot password feature (in case it happens again) that allows you to enter your email address and a temporary password will be emailed to you...then you enter the temporary password, log in, go to Account Settings and change the password to a new one...(don't ask me how I know this)
When you log in and don't enter the right password you will get a long error message that ends in something like this "if you forgot your password click here"...click on the "here"...you're good to go...
Welcome again...wish I had a need for your bit but don't see one in my future...but thanks for offering it to the Forum...
Nick
Nickp is online now
post #9 of 21 (permalink) Old 08-06-2016, 01:29 PM
you need that bit Nick...
you really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really need that bit Nick..
trust us...
Stick486 is offline
post #10 of 21 (permalink) Old 08-06-2016, 01:51 PM
SteveMI's Avatar
First Name: Steve
For small boxes and drawers I use the MLCS box joint. If you look on the link, they have a "finger joint" bit same as Whiteside.
MLCS Box Joint and Finger Joint Router Bits
Steve.
Herb Stoops likes this.
SteveMI is offline
Reversible Glue Joint Bit and Lock Miter bit Shells Router Bits - Types and Usage 35 03-10-2014 08:11 PM
Fine Tapered Finger joints jn_capili New Member Introductions 8 01-14-2009 09:26 PM
Fixed finger bit Bill Pierson Router Bits - Types and Usage 1 06-01-2007 04:35 PM
Chipout when using finger joint jig jihhwood Jigs and Fixtures 3 01-03-2007 07:33 AM
