RT Laminate damaged. - Page 2 - Router Forums
 13Likes
post #11 of 15 (permalink) Old 12-09-2015, 10:48 PM Thread Starter
jj777746's Avatar
Originally Posted by TheCableGuy View Post
I'd start new , but that's just me . Did you not build a template to guide your router?
I followed the instructions exactly,sticking 5 inch wide boards down with double sided tape etc.But still managed to stuff it up.Thanks for all the advice.jj
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
post #12 of 15 (permalink) Old 12-09-2015, 10:52 PM Thread Starter
jj777746's Avatar
Originally Posted by neville9999 View Post
Stick may be correct and it could just be easier to start again, here's a tip and a photo from my workbench thread, when you want to have an exact cut then make a jig to keep the router trapped, this box will never let a cutter get loose. I included the photo of how I made it/ N
Thank you Neville,your's is a much better method & I shall do it your way next time
jj777746 is offline
post #13 of 15 (permalink) Old 12-09-2015, 11:01 PM
RainMan 2.0's Avatar
Don't feel bad James as I'm sure most of us have done it . I finally gave up on making a template and bought a top from Incra lol . I'm going to build the stand though, as this way I can design it for my storage needs .
Bit by purchasing a top the plates hole is already done and a perfect fit , plus it has a miter slot .
I am going to build a double router table though , and will see how that goes
Ok ,I never insulate
RainMan 2.0 is online now
post #14 of 15 (permalink) Old 12-09-2015, 11:09 PM Thread Starter
jj777746's Avatar
I only use Melamine glue or polyurethane for mdf and particle board. You can patch it easily enough. Replacing it shouldn't be that big a deal either. We can get 2' x 4' cuttings of HPL at many of our hardware stores here for $5-7 dollars a sheet and mdf is cheap. Remember that if use use guide strips and work to the hole side of them that the only direction the router can get away from you is toward the center hole.
Thank you Charles,this is the first RT I have built & I appreciate your advice about which glue to use etc.
jj777746 is offline
post #15 of 15 (permalink) Old 12-10-2015, 01:10 AM
I just noticed that you are in Oz James so I don't know how hard it would be for you to get the Melamine glue. I'm sure the Titebond will work too but I find the Melamine glue doesn't get starved as easily by the composite boards as most conventional glues seem to, especially when edge gluing.
Metal Laminate JPF WOODWORKING General Routing 7 11-23-2014 12:21 PM
RTT - laminate flush with wood edging? cagenuts Table-mounted Routing 4 04-03-2013 04:18 AM
Routing laminate?? Bshmstr General Routing 8 04-01-2013 12:33 PM
flush bit damaging laminate ironhed79 Router Bits - Types and Usage 4 01-09-2011 12:11 PM
Laminate counter with oak edge kefjens General Routing 13 03-27-2009 04:37 PM
