The furniture maker gave me a piece of oak 3ft x 8" x 1", that I haven't yet had the nerve to saw up, and a beech door frame set that was damaged, which I have used to make some basic toy shapes. But the whole island scavenges wood all through the year ready for the winter. Theres nothing wooden ever left laying around. to the point if you have some, it has to be hidden or chained down.
That sucks...
I have found a couple of exotic woods (as far as I am concerned, being English) one is called mansonia, another is meranti. The mansonia is a very pleasing golden hue once coated with danish oil, the meranti looks good at first as it is gold and black flecks, but once oiled, the gold diminishes so much the wood looks a mucky gray.
Mansonia is seldom seen here but then only primarily as veneer when we do see it and not lumber...
it also used often as an alternate to Walnut... The stuff is very easy to work/tool and long term durable (rot resistant)...
BE ADVISED THAT IT DOES COME WITH HEALTH WARNINGS!!!...
Allergies/Toxicity: Mansonia is on the short list as one of the worst wood species in terms of toxicity and commonness of allergic reactions. Mansonia has been reported as a sensitizers, and though the most usual reactions simply include eye and skin irritation, the wood dust can also produce a wide range of other effects, including nausea, giddiness, sneezing, headaches, nosebleeds, infected splinters, and asthma-like symptoms. Additionally, both the bark and heartwood have been found to contain cardiac poisons, which can cause heart disorders....
(Red) Meranti is thought of as Asian Mahogany even though it isn't mahogany or any relation there of... since you said golden it may be white or yellow Meranti or even Balau - lending more to a Philippine Mahogany...
It's easy to work... those gold flecks you mentioned is actually silica (high content too) so plan on dulled cutters...
the interlocked grain can present problems during planing, and sawn/planed surfaces can be left fuzzy or ragged.. Sanding to finer grits will help smooth out the fuzzies.... Glues well.
I have half planks of sapele and mahogany,
Sapele ..... another fine looking wood w/ character...
Workability: Sapele can be troublesome to work in some machining operations, (i.e., planing, routing, etc.), resulting in tearout due to its interlocked grain. It will also react when put into direct contact with iron, becoming discolored and stained. Sapele has a slight blunting effect on cutters, but it turns, glues, and finishes well....
but all of them are rough sawn, hence my problems with getting smooth sides.
100% rough sawn surfaces??? or just the edges???
smooth straight sides w/ a router are cake and pie...
clamp a straight edge to your board set back from the edge so that the router w/ a straight bit installed just barely shaves the edge...
presto!!! one clean straight edge...
you may have to move the straight edge several times to get where you need to be depending on the irregularities of the edge...
now run the board through the TS w/ the trimmed edge to the fence to get both of your edges parallel......
this method produces very little waste...
I've just been out to the table saw, the riving knife can be removed easier than I thought. But I have no depth adjustment because of the multitude of safety interlinks on the saw. So I have a small plank of wood 90mm x 25mm that i want to rip into 3 off 90 x 6 , but the blade cuts 60mm.
you won't get 3 each cuts at 6mm because of the thickness of the blade and the material it removes/turns to saw dust......
I understand it is too dangerous to saw all the way through?
I do it all the time as long as the cut off isn't between the blade and the fence...
the riving knife in place for these cuts w/o the blade guard is a major plus...
try and hold the depth of your cuts to 55% of thickness in a pass...
I believe because of the nature of your woods, the scarcity of material and what have you a better band saw and hand planes will do you the most justice...
some of those woods you listed are prone to tear out... something you need to learn how to work around...
a band saw and hand planes (more useful in the long term) will give you far less waste and you'll pick up a skill set that'll look good in your resume...
Sharpening Angles for Bench & Block Planes | Virginia Toolworks
