Sometime back, earlier this year actually, I purchased a Lenox Tri Master half inch blade for my 17" Grizzly BS.
The blade broke at the weld shortly after installing it on the saw. I send it to a local Lenox dealer who re-welded it under warranty. However, the blade broke almost immediately after re-install it on the saw.
I had talked to the dealer that sold it to me and Lenox replaced the blade with a new one. The second blade has been on the saw for some time and so far has not failed. Of course I have not used the saw since last spring due to my recent medical problem, but it did run and cut extremely well for quite awhile.
In the meantime I sent the first blade back to the local Lenox dealer and he did a second re-weld on it.
At the same time that I bought the Tri Master blade I bought a Bi Metal blade from the same dealer. After the the Tri Master blade broke the first time I install the Bi Metal Blade and really like the way it cut, but in a relative short time it broke too and I sent it to the same dealer to have it re-welded.
Both blades came back at the same time but the replacement blade was working so well I had not reason to install either of the re-welded blades on the saw.
Recently Twoskies purchased a saw just like mine and so, since I didn't see any reason to keep the first Tri Master blade that had been re-welded two times, I sent it to him to and shortly after installing on his new saw, the blade broke for the third time.
Of course this has made me very courious about the quality of the welding jobs or is there such a thing as a blade being so defective that it will for some reason continue to break at the weld as this one has done.
If anybody has any comments they sure would be appreciated by myself and I'm sure that Bill would be interested in them too.
Jerry
Jerry
